loading
Step 4: Step 4: Folding the pod
This is the trickiest part, but I promise it's easier than it sounds at first.
Take an edge of the coffee filter and fold it just to the opposite edge of the pod holder, leaving just the tiniest gap (you can barely see a line of coffee in the picture). From there, grab the corner you just created on the right and fold it inward until the outer edge of the filter has a slight gap. Continue taking the far right corner and folding it inward all the way around until you have no more of the filter hanging off the outside. At this point, you should be left with a little sail on top of the pod.
Take the measuring cup one last time, place it on top of the pod with the folds, and press down (don't be afraid to use some pressure). This will help to seal all the folds as well as compact the coffee within the pod to create a more perfect fit for the coffee maker.
Now, you will still have a little fold left on top. You can choose to leave it be, like I did (it doesn't affect the performance of the machine just to leave it there), or you can tuck it under the folds, or you can trim it down if you like. If you choose the latter option, be very careful so as not to cut too much or pierce the rest of the filter, or you will end up with a big mess!
After this, you can simply turn the cup over in your hand and pick it up to remove the pod.
This is a clever solution for Keurig-style coffeemakers, and possibly other designs as well, but I hope no one ever tries it with a Tassimo coffeemaker like mine. They would be swept away in a tsunami of coffee and grounds! In a Tassimo, there is no perforated cup to hold your type of pod and direct he water through it. Also, the hot water is pumped upward through the Tassimo pod, permeating the grounds, passing through the filter at the top of the pod and then dropping through the spout.
<p>I am lucky I've read your comment. I have a brand new Tassimo, and I am looking for a method for making my own Tassimo-compatible pods. I still think this is a very clever idea, but it will need some further adaptation in order to make it work for the Tassimo. Beside the comments you made, this Tassimo also has bar codes in each pod that tell the machine how much water, how long, etc.</p>
Thanks. Did you get the other comments I made today about refilling your Tassimo discs?
<p>Hi, Lourdes. I can't seem to find the comment that you refer to. Did I mention that you can now go to my-cap.com, click on Tassimo, and buy a kit for around $20 that will let you empty and refill all of your used Tassimo discs? I bought a kit, and for the last 6 months about 1/4 of my brews were made with recycled discs. In short, you hand-drill a hole in the disc with their special drill (be sure you order it with the kit). Then you stream water into the hole and shake the old grounds out. Finally, you use a roll-up funnel to pour in new ground coffee. Finally, a rubber plug seals the hole. I have never had a modified disc leak!</p><p>You can continue to re-use a modified disc until the built-in filter gets too clogged, and that takes quite a while. All you need to do is select a fine grind for each disc that is as close to the original flavour as possible - eg. Colombian coffee in a Colombian disc, a good espresso in an espresso disc. The bar code ensures that it brews properly. The results have been excellent - I really couldn't notice any difference in the flavour. The only issue is that the Tassimo is intended to provide convenience, and the refilling process takes extra time and effort. Lately I find I am slipping back to using mostly purchased discs.</p>
<p>it is own comment from one year ago, &quot;I hope no one ever tries with a Tassimo coffee maker. They would be swept away in a Tsunami of coffee and grounds.&quot;</p>
Any suggestions on a hack for the Tassimo?
<p>Step 1: Throw out your Tassimo machine to follow these instructions</p><p>Step 2: Buy a POD machine...... not Tassimo/Nespresso/Keurig</p>
<p>I agree with 66% of your recommendations, AndrewB11. Throw out your Keurig (humdrum flavours) or your Nespresso (tastes like instant coffee), but keep your Tassimo. I have had one since 2008, and would not part with it. I started with the original model 1000, but now have a T55. Great coffees, lattes, cappuccinos and more, all in one affordable machine. Now that the discs are refillable, no hacks are needed. PS I do not work for Tassimo!</p>
<p>Step 1 not possible. I just got the Tassimo. Step 2: I'd rather get it as a gift. (blink!).</p>
<p>No need for a hack anymore, repguy2020. my-cap.com now has a Tassimo refill kit for about $20. I bought one in September and have refilled dozen of discs with nary a problem. See my reply to Lourdes to find out how the kit works.</p>
<p>Could potentially work for the teabag-style system too, just fill the filter up to a level you want it at, bunch it up at the top and tie it off with string, and cut off the excess filter. lol</p><p>Would work for loose-leaf tea too.</p>
This idea is very time efficient saving prep time and cleanup time for fast morning coffee! I am not sure why this qualifies as energy efficient though. The time and energy and resources it takes to make the paper alone should disqualify this entry. Further more I'm not sure if you are making coffee or espresso you mention pressurization which sounds like espresso in which case using pre-ground coffee is sacrilegious. I grind fresh and french press for maximum flavor using no disposable filters.
Thank you for commenting! <br/>I'm actually working on a form of a permanent filter as I have time; the only ways this is saving energy now are that a) it saves me a looong drive to the nearest walmart to pay $6+ for manufactured coffee pods and b) this particular machine uses less resources and energy than the 12-cup coffee maker my roommate uses, where she runs it for hours every day to keep the whole pot hot and ends up throwing out anywhere from 1-4 cups of coffee. The only reason I even put it in this section yet is that, for me, the paper is technically recycled since my roommate was going to throw it out anyway.<br/><br/>A coffee press is the *best* way in my opinion to make completely energy-efficient coffee (all I have to run is my electric kettle), I just hate having more than a mug to wash in the morning.<br/>
The mesh on the pod holder <em>looks</em> quite fine - what happens if you just put the coffee in without the filter? Anticipating that you might have a problem with this - how about just cutting a disc of paper to put in the holder before the coffee?<br/><br/>L<br/>
Lemonie, Trust me, I've tried it all. Putting straight coffee in the filter without a pod results in grounds getting into every orifice of the machine. Because it works on a system of water pressure, not having paper all around the coffee forces bits of the ground coffee up into the machine itself, and results in an extremely messy cleanup. The ultimate coffee machines are the ones that require no paper filter at all (one of my old roommates had a fairly cheap one that worked great for about three weeks until another roommate broke it), but sadly this type does.
Perhaps if you line the pod part with a reusable filter, hemp or some sort of nylon. This would require some additional cleaning of the filter but may be worth it in the long run. Also a small French press could make single cups, uses no paper filter and has no heating element. If you can boil 2 cups of water, even using an existing coffee maker, then you can make French press coffee. Just a suggestion.
I get it, I can see the coffee going everywhere. Thanks L
About This Instructable
129,578views
16favorites
License:
More by rpaxton:NES Bedding set
Add instructable to:
