loading
Step 2: Cut the Rod
This shouldn't be to hard :)
Pick up your selected brass rod, and cut it to desired length, maybe just leave a Cm or so more than you need.
This will help should you mess up the shaping process.
For my first needle , I used 6mm diameter plain brass rod and cut it to a ~8cm ( ~3 Inches ) blank.
Dont bother making the cleanest cut yet, this will be ground down later anyway.
<p>Thanks for the Instructable, I saw this years ago &amp; it always stuck with me. So tonight I finally made it! The few differences were I used #4 copper wire &amp; used a screw to tap it because I didn't have a tap set.</p>
<p>Looks great !</p><p>Nice improvisation with the screw too.</p><p>Thanks for sharing the results.</p>
I found a much simpler way was to just go get a rifle cleaning rod for 8 bucks already with hole and threads the rod I got had three ends with holes so I got three needles and with the others I sand them down so a lacing needle without the lace works great and took me about 20 30 min from buying to finished product
<p>Not much more I can add but thank you. I love it when someone gives me some new knowledge/technique that I can pass on to others and use myself. LLAP</p>
Glad you liked it :)<br>I learnt so many little tricks on this site throughout the years, it's only fair I give some back.<br>I have a couple more in an upcoming machining instructable.It should be ready near the beginning of next week.
<p>Made from tent spike, didn't have those screws....haven't tested it yet but can't see reason why it shouldn't work (cord are still on their way....)</p>
I saw a how-to a while ago where aluminum binding posts (http://www.amazon.com/Aluminum-Screw-Posts-Chicago-Screws/dp/B003O9J3GG) were used. they are already threaded on one end and solid on the other (after you cut off the flat head). You chuck the threaded end (not too tightly) into a drill and use your preferred file &gt;&gt; emory paper to create your desired tip
<p>I made 2 of these with my metal lathe last night. It was so simple, thanks in part to this 'ible, that something tells me I'll have a full set of Paracord lacing needles in 64th inch increments by this weekend. ;)</p>
InstructAble Mobile Has Horrible Keyboard, Meant Make This A Million Times Easier
BuyMillion Times Easier, BuY Some Knitting Needles In A Large Diameter,Cut To Size With Dremal.
oncenteric should read concentric. My bad. I am a horrible typist. <br>
Nice idea! try this trick for shaping the ends- using a hand drill, put the rod in the chuck. go over to a bench sander. turn sander on, pull trigger on drill and GENTLY apply gradual pressure of the spinning rod to the sander. the finish and poit will come out very nice. You can put a really smooth oncenteric tip on using this method. NOTE 1: Do not use a grinding stone for this. it WILL clog up your stone. NOTE 2: Same technique can be used to re-point punches. Just remember to hold the hand drill up at the desired angle and adjust the speed of the drill and the pressure against the wheel. Remember, less is more.
Recently had a couple made by my mothers boyfriend, instead of copper or brass rods he used some old discarded knitting needles. They are lightweight, come in many different sizes, take threads very easily and can be bought by the fistful at most thriftstores for about a buck per bakers dozen. <br> <br>...note though that he is used to working with metal and lathes and stuff and I only have his word for it that they are easy to work with. I am very happy with them though.
Wowow, that is a great idea for center drilling small diameter rods. I'd have never thought of that. Thanks so much!!
AWESOME! I love the upside down drill bit trick! Keep up the good work!
Great Instructable. I but knitting needles, which are hollow aluminum, cut to size, then just a quick threading with a tap. I can usually find a pair of needles for $0.50.<br><br>Paul
you'are great !
Brilliant!
Great stuff! shoulda made one of these ages ago :D<br>I was thinking, since I don't have a drill press, maybe i'll get a brass tube and tap both ends. One end for the paracord, the other for the tip. <br>For the the tip I'll just shape it somehow (with lots of elbow grease!) and then put it in a die to make a threaded end. <br>This would allow me to change tips too! Whadya think?
I love this instructable.<br><br>on a side note for some that might want a thinner needle:<br><br>a few years ago i bought some &quot;portable&quot; stainless steel chopsticks online for like $5.00 usd shipped. these chopsticks unscrew from each other. the pointed end being the part where the paracord would screw into. i used these to make a few cases for my phone and it was very easy to thread with.<br><br>that said - i will be making some of those fatter diameter ones to have more options :)<br><br>thanks for the instructable.
Great instructable, very thorough instructions. Thanks!
Very interesting. I like specially the step 4.
Yes, step 4 is very creative. <br>
Excellent! I have wanted to do this for a while and your instructable helped immensely!<br>
Your needle is also called a fid. You can find them in various hardware stores and boating/maritime suppliers. I noticed a couple of different sized plastic ones in my local hardware store the other day.
Read yours right after posting mine, Man.. I hate reposting something someone else said.... Sorry! <br>
Ohhhh.... I was trying to figure out what a &quot;permalock needle&quot; was, I think I remember them being referred to as a &quot;fid&quot; basically a hollow needle you weave ropes with (not just hollow braid either)
Really good idea! Great follow through.<br><br>I was struggling with an idea on how to make my own Permalok needle a few months ago. I dug through my Box-O-Stuff where I toss things that might come in handy in the future and came across some proprietary IBM cable male/female gender benders. They had stainless steel screws that held 2 cables together. I cut the thumbscrew off the female screw and sharpened the tip. it works fine, but is a little short. I like your idea much better.<br><br>Kudos.
Nicely done -- a thorough instructable with a few good fabbing tricks.<br> <br> There is a (IMO) simpler procedure over at <a href="http://khww.net/articles.php?article_id=121&rowstart=0">KHWW</a> (but when was simpler better for a weekend project?).&nbsp; Involves small gauge copper tubing, a self tapping screw, a hammer and some finishing supplies.&nbsp; It's little less machine intense, but I've got a feeling yours is a bit sturdier.<br> <br> <br>
About This Instructable
159,798views
427favorites
License:
More by ch5:Easy lathe projects : Brass glow in the dark paracord ornaments How to make your own permalok needles Paracord Bullwhip
Add instructable to:
