Step 6: Make some decisions and make some molds
I did some research and ultimately landed back where most DIY toy makers do, Urethane resin.
turns out if you process it in a standard silicone mold under rotation with a little bit of heat you get really good results.
The simplified version of building a silicone mold:
-spend a lot of time prepping your master as discusse din step 4 of this project
-define the parting line on your master with a clay wall
-1 important thing to note about a rotational casting mold is that it does not need vents or a gate as you will simply load material when the mold is open.
-build walls around your master
-mix up and degas your silicone and pour it over your piece
-wait
-remove the walls flip the mold and remove the clay wall being careful not to disturb the portion of the master now encased in silicone.
-coat all surfaces of new silicone with mold release
-build new walls
-mix, degas, pour second side
BOOM!!! Mold Done
The mold making process is standard and should be documented in it's own instructable
Oh look... it already is thanks bofthem
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
