3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to mix 2 stroke gas
hi this is my second instructable so please forgive me if i made a mistake.2 stroke gas is used in many things from weed eaters to motor cycles.I will show you how to mix it for a weed eater. My weed eater has a 40 to one ratio. if you have sone thing witha different ratio i will put upa chart for different ratios.
Step 1Materials
Materials
ECHO 2 stroke fuel mix (best one i tried)
1 gallon gas can
gas
Where to buy the stuff
gas can -canadian tire
ECHO 2 stroke oil- home depot
gas- gas station (duh)
4 comments
Jul 9, 2009. 12:48 PMadmin says:
Hey, this is a great instructable and is very informative. Just one thing is missing... pictures! It really helps a lot when trying to follow directions so you should consider taking some photographs. Once you do that and leave me a message when you have so that we can publish your work. Thanks! Thanks for the cool instructable and we hope to publish this soon!
Nov 25, 2009. 11:13 AMPhil B says:
Thanks for your instructable.  I use a 35mm plastic film canister to measure the oil.  A canister holds about 1.1 ounces.  If I want 1 ounce, I just underfill it a little.  I also pour my measured oil into the gasoline container first.  Then I take the container to the filling station.  When the gasoline runs into the container from the hose, it is mixed quite well.  I have used an oil container like the one you show.  It works, but I am not sure it is that much handier than my film canister.  I do not need to worry about cleaning out the film canister, nor about keeping it clean.  I just put the cap back on it until I need it the next time.
Nov 25, 2009. 11:15 AMPhil B says:
As an afterthought, I also make a label with a labelmaker to indicate the ratio for each 2-cycle machine we have, and we have two.  That makes it easier to get past remembering which is 1:24 and which is 1:32.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:2 stroke
i am a kid who likes to make stuff out of metal and likes stick welding and putting weedeaters and chainsaws on bicycles. i own a 70 amp stick welder from princess auto and many small 2 stroke engines
