Introduction: How to Mix Hydraulic Cement for Sculpting
Picture of How to Mix Hydraulic Cement for Sculpting
You will need:
Hydraulic cement mix
Water and a robust water container
A tub for mixing the cement
Disposable gloves
Step 1: Make a Small Mound of Cement in the Middle of Your Mixing Tub
Picture of Make a Small Mound of Cement in the Middle of Your Mixing Tub
Step 2: Make a Well in the Center and Fill It With Water
Picture of Make a Well in the Center and Fill It With Water
Step 3: Scoop Dry Mix From the Edges Into the Well
Picture of Scoop Dry Mix From the Edges Into the Well
Step 4: Pick Up and Knead the Blob of Partialy Mixed Cement
Picture of Pick Up and Knead the Blob of Partialy Mixed Cement
Step 5: Add Water or Dry Mix Until It Reaches the Consistency of Play Dough
Picture of Add Water or Dry Mix Until It Reaches the Consistency of Play Dough
You will only have five minutes to use the cement before it begins to harden.
KyleB122 (author)2016-07-15
looks like this is the product you are using:
https://www.amazon.com/Quikrete-112611-10lb-Water-...
empathy44 (author)2016-06-26
Citric acid acts as a retarder in regular cement, will it work in hydraulic cement?
natpodu77 (author)2014-01-06
Hello, I have a question with hydraulic cement. I am building a form with styrofoam which will ultimately hold a terafauna filter and a small pool for my box turtle and want to cover it with hydraulic cement instead of multiple layers of grout and then sealer. I know I will not be able to make enough cement and work with it to cover the whole piece in approximately 5 minutes-before it hardens. If I do this in increments, will the wet cement bond to the hardened cement? I do plan on covering the whole thing in one day, but like I said, I know I can't do it all in one batch of cement. I have asked a few people, but they don't know. I would assume so since this is usually applied to regular concrete as a patch, but want to be safe.
Will this be water proof enough to have water in it all the time, or would you recomend a sealing with silicone for added durability?
Also is there a way for me to color this? I wanted something terra cotta or brick colored, not white. That was my last question :)
Thank you for your help
weiblen.c (author)2010-09-06
While the cement is curing (after about five minutes from when you start mixing it) it will get HOT. This is part of the chemical reaction that hardens the cement. If you water it down too much, it will not react properly, it won't get hot, and the finished item will be weak.
About This Instructable
13,141views
42favorites
License:
Bio: I am a former zookeeper. One thing you may not know, zookeepers often have to make their own specialized tools, enclosures and supplies. It's ... More »
More by weiblen.c:Aquarium plant number 2Build a better aquarium plantQuarantine tank for amphibians
Add instructable to:
