heres another on its ben out there a while just decided to put it on instructables
This one also has better skins that i made and i am considering on makin an ible on it if u want me to comment on it
Remove these ads by
Signing UpStep 1HMT or HHT
I personally use HMT 3.5
HMT download : http://halo2.filefront.com/file/Halo_Mapping_Tools_Version_35;37863
your gonna want the plugins they allow you to mod more things
Plugins : http://halo2.filefront.com/file/HMT_35_Plugins_Pack;65046
Put the plugins in the HMT plugins folder (makes sense)
I also made the banshees go disturbingly fast.
Another fun thing is to add colored fog. :D
Um... What do i do?
When I'm entering negative numbers, I get this error only when the hyphen is in the data field alone. As soon as I add the numbers, it is fixed.
"C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\mscorwks.dll could not be loaded"
what do?
And now I can't find the download again...
all i wanted to do was turn up the rate of fire of the pistol in the bloodgulch file
so here is what i did
"open file" (bloodgulch.map) then i went to +[weap] weapons/pistol/pistol
the drop own menus that say "clip" and "projectile" i put to 0
so all the original numbers came up
then i just changed the clip size a little bit and turned the ROF up a little bit
now what do i do?
click the "save" button under "tag information" ??
cuz when i do that and try to play, it says i need to reinstall halo
