http://www.instructables.com/id/How-to-build-the-one-motor-walker/
There are trillions of tutorial like this, I know :-)
They where taking at school during lunch break with a Sony Mavica camera ( floppy disk )!
5 febuary 2001, 12:18:50
Remove these ads by
Signing UpStep 1How to modify a servo motor for continuous rotation ( One motor walker robot )
1 x safety glasses!!
1 x soldering iron
1 x desoldering pump
1 x wire strippers
1 x side cutter
1 x scissors, knife, x-acto, etc
You will need a set of screw driver to remove the four screws on the back of the servo.
Took out the stop key. Like cutting off the stop horn on a servo. Gotta love our toys.
These motors have some real b@lls too. I used one to open and close driveway gates.
Sorry to be off topic. Have a great Thanks giving!
http://www.scottsbots.com/videos.php
Just not to flood this site with the same questions over again, here is the link:
http://www.instructables.com/id/HiTec-Servo-Hack/?comments=all#C0MB712GJ289SX1
In brief, I'm looking for a servo that can be rotated more than 360 degrees, while maintaining it's accuracy.
Here is a guide I did a while back that has a little more information.
Controlling a stepper motor with an arduino
How is the size and the prize of a stepper motor compared to a servo?
The reason I would think they would do this is so they could still use the circuit board to control the servo. You could could give it a signal to start rotating in either direction and it would just keep going until you told it to stop or reverse. You would tell it to stop by sending the signal that corresponds to the 2.2k? resistor (90 degrees?).
Regards,
Dave T.
ATmega8535 | ATmega16 | ATmega32 | AVR USB ISP | Motor Servo Seller
Thank you so much!!!!
But you want a motor+gearbox+speed-control, then I prefer the modification below:
http://www.kronosrobotics.com/an116/GAN116_3003.htm
It's easier to do: no soldering iron and you only open one side. You don't waste the electronics. And you get electronic speed control. There's this video here that shows a minimal modification (no calibration after the servo is closed) but it's in a language most of you won't understand; nevertheless, it may help to understand the modification:
http://www.youtube.com/watch?v=VmLm1gl8glM
servo ES-30 JR warning, dutch website youll get it anyway
Anyway, the basic idea is remove the tab that blocks it and the Circuit board? so then you just have a motor with a gearbox... genious
http://www.hobbypartz.com/kahaoubrmo14.html
The point is to have a powerful motor to build all sort of project!
http://www.servocity.com/html/hsr-1425cr__continuous_rotatio.html
