How to modify an airsoft magazine
 by Brandon121233
So heres the deal. Your out with your friends having a friendly and safe airsoft battle. You have a spring powered pistol (a crossman P30 in this case) and you quickly use up all 15 rounds. You forgot to bring extra BB's with you so now your body is going to be used for target practice. Unless of course you use this instructable to modify your magazine so that you can hold more than 80 BB's. If that sounds good to you then read on.
Quick details:
Cost- free if you have all the tools and the gun
Items needed- Crossman P30 (or gun with similar clip) airsoft gun
Tools:
-Small Phillips and flat head screwdrivers
-Small abrasive files (an emery board might work too)
-(optional) Dremel Tool with 6mm BB sized tip (this will really speed up the process not to mention make it much better looking)
Step 1: Remove and disassemble the magazine
First you want to remove the magazine from your gun by pushing the button located near your thumb on the gun. After you have removed that, get a screwdriver and remove the screw on the bottom of the magazine. This will cause the bottom piece to come off and the spring to pop out, make sure you don't loose any of the parts. Next remove the two screws on the side of the magazine and pry the magazine open gently with a flat head screwdriver. You will see a large heavy lead weight that gives the magazine its heft, if you don't worry about the magazine weighing a couple ounces less then proceed to remove it. If you like your magazine to be very heavy then stop now and put it all back together, this is not for you. This open area is where the extra 65 BB's will be held. You are now done with the first step. Go on to modifying the magazine.
1-40 of 88Next »
ilpug says: Sep 28, 2011. 11:06 AM
this is great! i never though of this. my friends have a bunch of these guns. i will do this mod ASAP!
Landon Sullivan says: May 9, 2008. 8:04 PM
(removed by author or community request)
trentmulrich in reply to Landon SullivanApr 19, 2011. 6:47 PM
i like crosman to Landon Sullivan its like the best brand ever!!
nice photo by the way the cat is really cute
Landon Sullivan in reply to trentmulrichJun 2, 2011. 9:28 AM
*facepalm*
Nice necro-post. Crosman sucks. I have seen the light.
Sigy says: Aug 13, 2008. 10:15 AM
It is not a clip!it is a magizine.there is a difference!other wise good idea.
nerfer192 in reply to SigySep 4, 2008. 2:06 PM
im not entirely sure wuts the difference
DIY Dave in reply to nerfer192Apr 28, 2011. 12:41 PM
If I remember correctly magazines are what handguns use, clips are what rifles use.
Sgt Niesen in reply to nerfer192Apr 15, 2011. 2:56 PM
clips are reallu known as striper clips and you insert them through the action where the empty cartridge comes out after you open the action and then you put the stripper clip in and iloads the gun when you are out of ammunition the stripper clip flys out of the gun but guns with stipper clips are rare but here are a few Kar 98, M1 Garand, Styer M1911 and some M14A1
trumpkin says: Mar 2, 2008. 3:28 PM
umm, what video?
trentmulrich in reply to trumpkinApr 19, 2011. 6:37 PM
the video that was right there how the heck did you miss it well with the name trumpkin i guess you could
Brandon121233 (author) in reply to trumpkinMar 2, 2008. 4:38 PM
The one in the introduction
DIY Dave says: Feb 25, 2008. 6:58 PM
great idea, I think I will try this on one of my guns spare clip.
epic sonic in reply to DIY DaveApr 19, 2011. 1:42 PM
i tried it and it works great its an awesome idea
DIY Dave in reply to DIY DaveFeb 25, 2008. 7:01 PM
My little brother's gun has a clip that is made that way.
epic sonic says: Apr 19, 2011. 1:40 PM
thanks for that it works great
fireFEIND67 says: Mar 22, 2008. 6:10 PM
actually it's called a magazine, not a clip
acesk8erboi in reply to fireFEIND67Apr 4, 2009. 8:31 PM
A clip is something that is internal. A magazine is one that is visible on the outside for instance a M4 Hi-Cap Magazine.
Hitman227 in reply to acesk8erboiJan 31, 2011. 1:54 PM
Sorry to bring back a dead comment, but a magizine is bullets on a strip that would load in from the top on a lee en field mk.1 rifle ect. A clip is somthing that is detachable that is used to feed bullets.
Bisquick the ninja in reply to fireFEIND67Oct 13, 2008. 12:47 PM
Actually it can be called either.
fireFEIND67 in reply to Bisquick the ninjaOct 21, 2008. 5:35 PM
only if it's an actual CLIP for a revolver or a bolt action rifle
Hitman227 in reply to fireFEIND67Nov 30, 2010. 1:48 PM
A revolver uses a drum thing.
Sgt Niesen in reply to Hitman227Apr 15, 2011. 2:34 PM
Its called the cylinder
Hitman227 in reply to Sgt NiesenApr 17, 2011. 8:42 AM
OK.
Father Christmas in reply to fireFEIND67Mar 29, 2008. 1:34 PM
thebluemartyr in reply to Father ChristmasSep 10, 2008. 5:30 PM
Father Christmas in reply to thebluemartyrSep 10, 2008. 6:56 PM
thebluemartyr in reply to Father ChristmasSep 11, 2008. 2:50 PM
thebluemartyr in reply to thebluemartyrSep 11, 2008. 3:00 PM
thejrb in reply to Father ChristmasAug 2, 2008. 9:52 AM
The first one in this link is a clip the second a magazine.
fireFEIND67 in reply to Father ChristmasJun 12, 2008. 2:39 PM
a clip is a litteral clip of bullets usally for some sort of bolt action rifle, a magazine is a detachable piece of equipment that you can reuse so therefore i win
Father Christmas in reply to fireFEIND67Jun 12, 2008. 4:47 PM
Mr. Bean117 in reply to Father ChristmasJun 18, 2008. 7:47 PM
ok a clip feeds a mag a mag feeds the gun the closest thing in airsoft to a clip is a speed loader the m1 garand has an internal mag, so it looks like it's clip fed it's not empty clips are usually a flat piece of metal with little bend ridges on the sides looking at one being held upright from above would look something like [__]. in conclusion. fireFIEND is right.
Father Christmas in reply to Mr. Bean117Jun 19, 2008. 7:13 AM
CapnTac in reply to Father ChristmasAug 8, 2008. 7:55 AM
Lolz, you lose.
luigisf in reply to Father ChristmasJul 21, 2008. 9:02 PM
oohhh got pwned
Jr Hacking kid in reply to Father ChristmasJun 25, 2008. 6:58 PM
heres your answer
Trace II in reply to Jr Hacking kidJul 9, 2009. 11:57 AM
Oh... so clips are like those things that they had in that one WWII movie. You know, the one with the hillbilly that becomes religious, tries to not go to war, still does, captures a bunch of Germans and is a hero. And there was a shooting contest to win a cow. I don't know what it was called... BTW, this mod is useful and semi-easily do-able. Good job!
pyro man in reply to Jr Hacking kidOct 19, 2008. 6:42 AM
oh thank god u found that
Mr. Bean117 in reply to Father ChristmasJun 21, 2008. 1:47 PM
for airsoft the closest thing to a clip is a speedloader and magazines are the same
DrWeird117 in reply to Mr. Bean117Aug 30, 2008. 12:47 PM
Well, your name is Mr. Bean. So I have a question. Have you seen Mr. Bean's Holiday?
1-40 of 88Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
