The downside of this unit is that if you try to use the rack that they give you for mounting, it will have to sit on the ground in a place that would be temporary. The wind could easily knock over the panels. There are no instructions in the package to mount the panels permanently and calling the support number got me nowhere. After considerable thought and experimentation, I have come up with a solution that works. The purpose of this instructable is show how I did it.
The goal was to mount the solar panels to the roof of a shed out in a country garden which does not have electrical power. The system would generally be used to charge battery-operated tools but other AC tools could probably be used via an inverter.
Remove these ads by
Signing UpStep 1: Approach for mounting
Based on what I saw in a 5 watt panel that I had bought from Harbor Freight, I realized that if I could get a nut inside the channel, I would have a way to screw a matching bolt into it. The 5 watt panel used a metric nut called an M8 (the 'instructions' for that unit were printed on the back of the box). After a long search for an M8, I gave up (the US doesn't do metric) and chose a 5/16th inch nut. However, a regular nut won't do due to the vertical clearance of the channel. I went to Ace Hardware and found a half-height 5/16th inch nut. The guy at Ace pointed out that since the frame was aluminum, I should go with a stainless steel nut because, otherwise, the steel will interact electrically with the aluminum. From that point, I purchased only stainless steel hardware for any piece that would make contact with the panel.
The overall approach that I followed was to slide two nuts down each side channel and then bolt three inch aluminum plates to these nuts. The plates would then be used to anchor the panel to wood rails that ultimately would be mounted to boards screwed into the joists on the roof.
Visit Our Store »
Go Pro Today »
Also: a little advice with your charge controller. I've seen many of these controller fail and fry batteries. Your best bet is to buy something like a Xantrex C12 or C35. Not only is it more reliable, but it offers three-stage charging and PWM charging.
Again, I'm not trying to criticize your work! Great job on such a steep slope!
As for the charge controller, I hadn't wanted to spring for anything more expensive at this point. I am worried, though, about the quality of the controller that came with the Harbor Freight kit. Right now this is just an experimental system and don't want to spend too much money on it. What I would ultimately like to do is put in a serious solar panel system and sell electricity back to Duke Energy, something that they won't permit right now in Indiana.
Thanks for the suggestions.
