3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to mount and balance mirrors for spirograph project
Motor-mounted mirror is a critical part of spirograph project which greatly affects final appearance  of whole device: www.instructables.com/id/Laser-show-for-poor-man/
Usually I use cooling fan as prime-mover for mirror. It's affordable part, easy to work with, plus it cools down electronic guts of hard running spirograph ;-)
Only drawback that we cannot change  direction of rotation but it's not significant feature for laser show.
After many trials and experiments, I've finally developed  simple and reliable method to mount and balance acrylic mirror in order to achieve smooth and quiet performance and want to reveal it in this instructable.
All described below is applicable only to plastic/acrylic  mirrors !!!
Step 1Rough shaping
Rough shaping
Usually mirror material comes as a sheet so we need to cut square piece of proper dimension, corresponding to size of fan.
Next, mark circle on your raw mirror then form round shape using  file.
It's not supposed to be perfect circle we are going to finish it later with aid of some machinery....
BTW. I always have some leftover pieces of  mirror sheet so I can provide it upon request.
17 comments
Apr 12, 2012. 3:02 PMugman77 says:
Why are you not able to change the direction of the rotation of the fans? Wouldn't a simple current reverse switch accomplish this?
I have a spirograph using regular motors and I find that the rotation change increases the number of possible patterns tenfold.
Oct 24, 2010. 9:25 PMFJMSoft says:
Hey friend, where can I get this kind of mirror?
Very interesting!
Thank you.
Jan 28, 2010. 1:36 PMajam123 says:
Oh my... I love your laser show machine! I just got my dvd burner laser and I'm definitely building something like this now! I'll try to use my arduino for it. Thanks alot for the great idea!
Oct 17, 2010. 4:08 PMpaul30003 says:
I've alread done that with an arduino. Still working on the code a bit, but its come a long way now, If your stuck for ideas, let me know and ill send you my updated sketch. http://www.fxlasers.co.uk
Aug 16, 2010. 2:11 PMbratan says:
Great tutorial! 2 questions. 1. Since I don't have drill press, is it possible to get by with just handheld dremel instead? :) 2. How do you know when to stop filing the piece? Is there any clear indication?
Aug 18, 2010. 7:05 AMbratan says:
Thank you! I guess I'm getting a small drill press :) BTW, what happens if mirror wobbles, or even if it's square? Does this affect laser beam, or might detach from the fan?
Jan 21, 2010. 9:10 AMmiketwo says:
You seem like the guy who would know...
I'm trying to mount a mirror to a servo, to turn my IR sensor into an IR scanner.  Your instructable gave me some great ideas, but I might as well ask -- how would you do it?
(The mirror has to be weight-balanced on the servo and mounted at a 45-degree angle.)
Cheers!
Jun 3, 2010. 5:06 PMskowerr says:
for a scanner i'd use a hdd head with a mirror attached to it so there would be a nice inline movement of the beam. head could move the beam in horisontal  plane and a servo could rotate the head vertically. if you would use only  servos it would  be quite hard to scan an object in straight lines. you would get a sinusoidal line which would diturb the scale of scanned object, and that you would propably like to avoid.
Nov 22, 2009. 10:34 AMT3h_Muffinator says:
Great idea!
Got any videos of the finished product?  (The spirograph, that is!)
Nov 22, 2009. 12:07 PMT3h_Muffinator says:
Ah!  Totally missed that - my bad!
Nov 22, 2009. 3:30 AMAndyGadget says:
Clever idea. I made my own version of your laser show some time ago (but never got around to making it into an Instructable).  I cut discs from an old shaving mirror using a hole cutter, but getting them centred was a trial and error thing and because they weren't front silvered, I lost a lot of light.  I'll do a rebuild sometime using proper mirrors and your method for setting them up.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
90
Author:AP Digital light
