3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to neatly solder (without loads of wires!) decoupling caps on SMT microcontrollers.
This instructable is written to teach you how to use a neat and tidy method of prototyping with SMT microcontrollers (or other devices) on an adaptor board.
After struggling to make a neat job of effectively decoupling the power pins on my PIC18F I decided something needed to be done!
This instructable shows what I did.....
This is my first instructable (I thought it was time to give something back!) so go easy on the comments ;-)
S.
The first picture (below) shows the completed board - looks neat (apart from the burnt flux!) doesn't it....read on!
Step 1Lets begin...
Lets begin...
The first step is to solder your device onto the adaptor board as can be seen in picture below.
I find that the best way to solder these fine (ish) pitch devices is to use plenty of good flux and some leaded solder (dont tell the environment though ;-) !).
23 comments
Feb 28, 2010. 8:29 AMM4industries says:
(removed by author or community request)
Sep 4, 2011. 6:30 PMTheWaddleWaaddle says:
I hate to be the one correcting the Grammar Nazi, but your suggestion is incorrect. If you remove the parenthesized words, it spells the 100% gramatically accurate sentence of "How to neatly solder decoupling caps on SMT microcontrollers.", rather than your suggested "How to solder neatly decoupling caps on SMT microcontrollers.", unless he is using a special form of decoupling capacitors called "neatly's" which I have yet to hear about. You could also add the parenthesized words at the end of the sentence, which would read "How to neatly solder decoupling caps on SMT microcontrollers without loads of wires!", which is still 100% gramatically correct... Now I feel like the Grammar Nazi :-(
-TheWaddleWaaddle
Sep 4, 2011. 7:35 PMM4industries says:
I posted this more than a year ago, and I have since then learned a bit more about grammar. I saw that I was wrong a little while ago, but never really cared to take the comment down.
Jan 28, 2012. 7:06 AMciroman says:
And thus you got owned for posting a comment before thinking it through. Good job.
Apr 30, 2009. 12:11 AMomnibot says:
Good ible. Also I have the same multimeter.
May 2, 2009. 3:49 AMomnibot says:
Same here. Been thinking of getting something a bit better later on but currently it's all I need.
Apr 29, 2009. 1:44 PMrachel says:
This is super clear about how... but as a fairly new electronics hobbyist, I'm not at all clear about Why. What's a decoupling capacitor and why do you need them on smd components?
Apr 30, 2009. 5:16 PMosgeld says:
i suggest you read this
http://en.wikipedia.org/wiki/Decoupling_capacitor
it basically acts as a noise suppressor
Apr 30, 2009. 9:18 AMWhatnot says:
Copper tape eh, yeah I'll get some at the copper-tape emporium on the corner.
Apr 29, 2009. 5:25 PMosgeld says:
very handy trick, and it does look nice and neat thanks for sharing!
Apr 29, 2009. 1:15 PMjeff-o says:
Shame they didn't just slap a ground plane on the back of the PCB for this purpose! For an even more rugged solution you could glue a thin piece of PCB to the back instead of the copper foil.
Apr 29, 2009. 12:39 PMjeff-o says:
You forgot to mention that a decent soldering iron is also required. Something with a nice fine tip and ideally temperature control.
Apr 29, 2009. 1:12 PMjeff-o says:
Mmmmm, Metcal are nice - we have them where I work. Also lots of nice Hakko stuff. I'm spoiled! All this nice stuff makes it hard to go back to my $40 Weller at home...
Apr 29, 2009. 5:19 PMosgeld says:
we have Hakko's at work, i get home and look very mad at my radio shack el cheapo, hoping one day it will morph but after after a decade with that RS i can work some magic with it, but its still tricky
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ste5442
