Introduction: How to Ollie on a Skateboard
Step 1: Materials
All you need is a skateboard and a helmet (optional)
Step 2: The Stance
Place your front foot in between the middle of your skateboard and the front trucks. Place your rear foot on the tail (back) of your board putting most of your weight on the ball of your foot.
Step 3: Jumping
Crouch down on your board the more you crouch the higher you will go. Push off of your back foot to jump. Wait until the tail of your board hits the ground.
Step 4: The Front Foot
After you've jumped slide your front foot up to the nose (front) of your board. This will make your board come up with you.
Step 5: The Back Foot & Getting Higher
Lift up your back foot so the back of the board goes higher. Also tuck your legs up when you are in the air. (it will make you go higher)
Step 6: Level It Out
Level out the board buy pushing down on the board slightly.
Step 7: Landing
Put both of your feet over the bolts so your board doesn't break if you ollie really high. Extend your legs so they are slightly bent and land.
Step 8: Troubleshooting
These are some things that might happen to you when you ollie.
Credit card
This is where your board comes up and hits you in the groin. This hurts really bad.
Chickenfoot
This is when one of your feet keeps on landing on the ground instead of on the board. Just pretend your feet are attached to the board and this will go away.
