loading
Step 3: Power Button Fix.
Power buttons on the Garmin nuvi usually fail because of the way they are constructed. The button itself is merely soldered to the motherboard, and there is nothing holding you back from pushing too hard, and snapping the connection. In most cases, you can resolder and put a piece of plastic that will reside between the SD card slot and the power button. You will need about 1mm thick plastic. We got ours from the top of a yogurt cup. Wedge the stopper in and put the nuvi back together.
<p>My Nuvi 350 suffered the dead power switch syndrome. Your tutorial gave me the confidence to open the device up - and after many missteps fix it. The ribbon connectors separated and it took several tries to reattach them (toothpick helped) and get it to work.</p><p>Thanks</p>
<p>You've been a great help, but you forgot to say that: once you open the case, there is a screw to be removed to release the circuit! thanks anyway!</p>
how did you installed windows on that gps plz
Thanks, made my life a lot easier.
Thank you for a great review! It helped me to fix my nuvi 300.
Can't thank you enough. Great job.
I looked at the pictures between step2 and step3, and read the explanation of each step, but it was not explained that the mother board has to be removed from the case half. Prying on the mother board is not the answer, removing the small Philips screw at the lower center of the mother board is the way to go. But guess what, my Garmin is working again. Thanks for these instructions, saved me at least $70.00.
The long torx screws under the aerial hinge refused to let go before rounding the faces of the screw head on one of the screws. (even using a torx). I removed the head with a mini-drill and diamond abrasive bit. The resulting stub at least provides a location stud. The long screws are not essential though as the unit clips together sufficiently tightly for most purposes.
The tiny clamps holding the connections from the front screen are very fragile and I managed to break one even using a camel hair brush to flip it. Probably increasingly brittle with age. To provide a degree of downward pressure on the contact I used a small piece of 35 mm negative trimmed out from a scrap piece and inserted it over the foil contact and under the pressure bar. This was again held in place with a tiny dab from the glue gun
As a possible alternative fix to the on-off switch issue to the PVC pot solution, can I suggest a hot melt glue gun - a tiny dab of glue in behind the switch after it has been returned to 90 degrees to the PCB seems to do the job. Too much glue and it will enter the SD card cavity so care is needed.
I got as far as removing the outer shells of the antenna without mishap - however the case screws as indicated in the photo did not want to let go and rounded off the tangs on the micro-screwdriver I was using. (even though held down on a table surface with the 'driver in the jaws of narrow nosed pliers) Where would I get a torx small enough for this? - the drive diameter is tiny.
Did not quite work for me... I have a 360T - and the fix is for a newer/wider unit - the single screw holding the circuit board in place would not budge - so I could not get access to the other side and fix the switch.&nbsp; <br /> <br /> Also the touch-screen ribbon cable (the smaller of the two) is on a hair-trigger - mine popped out of the connector as soon as I cracked the case more than 10mm open.&nbsp; No worries though <strong>it is </strong>possible to get it clipped back in position with a bit of fiddling!<br /> <br /> All back and working - apart from the switch - but I have alternate plans now that I have seen the inside<br />
I just used these instructions to fix a 360. <br><br>The screw you mentioned came out for me with just a little firmness. Make sure you're using a appropriately sized screwdriver, support the unit, and give it a little more torque.<br><br>BTW, thanks for the caution on the video power cable - I'd have missed that it was loose and had to reopen if you'd not mentioned it. Easy to pop back in as long as you know it's loose.
I recommend to everyone! very good help!
I would like to say thanks for the instructions! It helped me a lot!<br /> Very good tutorial!
About This Instructable
37,315views
6favorites
License:
More by vdude45:How to open a Garmin nuvi 3xx or 6xx. (power button fix instructions too!)
Add instructable to:
