3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to open a jammed CD/DVD drive
Drive release mechanisms can be very sensitive to the condition of your discs, so they sometimes get stuck. If the open button doesn't respond, you must use this trick.
What you need:
1. A stuck cd/dvd drive
2. A paper clip
First, turn off your computer before doing this!!
Step 1The paper clip
The paper clip
Straighten out one leg of the paper clip.
6 comments
Dec 10, 2011. 7:30 AMschumi23 says:
Another method i have found is using a magnet. I found it completely by accident, as i took a DVD drive out of a broken laptop, laid it on my desk, on top of a HDD magnet, and it popped open. i then did again, and when i put the magnet under, and a little behind the button, it would open the DVD player.
Jan 3, 2011. 12:06 PMAl3xX90 says:
Thx for posting this tutorial my cd/dvd drive start to block with no cd/dvd inside but now it works!!! And i have done it with computer ON
Mar 1, 2009. 9:33 PMShane1163 says:
haha our computer's DVD/burner drive always gets stuck when there's a disc in it! no disc it opens up.. a disc in it gets stuck! I think what's causing it is bcuz there is so much dust and dirt built up in the gears that it jams but I'm not sure.. dirty discs don't cause that I never knew about the hole until someone come over to fix other problems with the computer and he told us about it! We also have a DVD recorder that has a stuck drive! can't find any small hole ANYWHERE on the DVD player for that one tho.. :(
Apr 8, 2010. 1:21 AMkomo.tan says:
I sure hope someone could help on this. I have similar problem but double as each of my  2 Phillips DVD players has got a disc stuck in.
Oct 20, 2008. 11:10 AMmicroman171 says:
Leave the computer on, that way when you press it it will open all the way. There is no danger to the CD's themselves. WE have a faulty CD drive that almost ALWAYS get stuck. This is how we do it (computer ON)
Oct 20, 2008. 9:17 AMCartermarquis says:
Simple and easy 'ible. Except in step 4 you say that you can prevent this by keeping your CDs clean? I would be more worried with warped discs than fingerprints and scratches.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:magnus0
