How to open an XBOX 360 controller without a special screwdriver.
 by BuffaloNickel
anarchia666 says: Dec 14, 2011. 2:36 PM
Very thanks for tip man! It's working very well :)
sdally says: Sep 28, 2011. 2:55 PM
If you have pushed down the center button in the screw use a 5/64 Allen key and you should be able to get the screw out you may even be able to use the Allen key even if the screw is not pushed down I just did this yesterday so I know it works.
kwest2 says: Mar 20, 2011. 9:08 AM
ya but what happens when the little thing sticking out of the screw in the middle brakes should i use a T8H screwdriver?
1337pino in reply to kwest2Jun 3, 2011. 9:24 AM
I had a couple of mine break. I then switched to a 2.4mm flathead. If you can get it lined up with the middle, and you keep at it, it will come out.
melanton says: Apr 20, 2010. 9:00 PM
It's a good read, use this method at your own risk.
My bit snapped on the fourth screw. Thank you Lifetime guarantee....
I'm going to replace it and buy that special one.
tyeo098 says: Oct 23, 2009. 8:50 PM
ಠ_ಠ
Torx T8 was 2.99USD on ebay, shipped.
But im always a fan of using the flathead to open stars.
Thats how I open HDD's!
bwpatton1 in reply to tyeo098Oct 28, 2009. 3:02 PM
LOL you actually use a screw driver to open hard drives, I take a powerdrill and drill through the screws.
Works great!
BuffaloNickel (author) in reply to tyeo098Oct 24, 2009. 8:08 AM
this is more so you dont have to go and buy one, you can use a driver you already have. (hopefully)
lemonie says: Oct 24, 2009. 3:55 AM
You should edit the tags to include references to T8H screws, as this doesn't just apply to XBOX 360 controllers it's got wider usefulness.
L
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
