3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to open and replace the MagSafe cord on an Apple AC adapter
Having owned several Apple notebooks which utilize the MagSafe adapters I've seen my share of failures.
Anything in from stuck pins which prevent the computer from charging to my cats deciding the adapters are made out of some rare form of addictive kitty-crack and shorting out the cord by chewing on it.
I used to buy new MagSafe adapters but that got expensive fairly quickly. Then I decided to splice out the shorted sections of cord; which did work but left me with relatively short cords for charging the computer. Next, I decided to figure out how to crack open the adapter and replace the entire cord and that's the process I'll demonstrate with this instructable.
Be careful and make sure the adapter is completely discharged. Capacitors can hold a charge for a while so it's best to leave the adapter unplugged for a bit prior to working on it.
Materials/Tools needed:
Needle Nose Pliers
Soldering Iron
Solder
Desoldering Braid
Flux (optional)
Super glue
Clamp(s) or even a heavy book will do.
Replacement MagSafe cord- I found mine on eBay for like $16.
Step 1Opening the adapter
Opening the adapter
Some other tutorials online have used things like a Dremel and a cutting wheel to cut the casing apart or they used a screw driver to gouge the plastic apart. This not only makes reassembly more difficult but makes the reassembled adapter a bit ugly. We're actually going to use a pair of needle nose pliers and some leverage to crack open the case along its two halves. This leaves really no deformed plastic and makes the adapter much easier to reassemble.
Flip open the cord winding ears and insert the plier ends as the picture shows.
Open the pliers until you hear a satisfying pop and then do the same on the other winding ear.
This will typically separate the two halves almost completely but the case will still be held together near the wall plug and along that back seam. To get those to release you'll need to grab the two halves and pull them apart until those also pop apart.
16 comments
Dec 23, 2011. 6:11 AMsnods says:
Aaronx2621
Thanks for the instructions. I got my early MBP t-connector MagSafe adapter apart, but the circuit board is completely different than the one in your photos. The wires go deep underneath the PCB instead of connecting right at the edge where the wire goes into the brick. I can't figure out where they go. If I send you a pic, can you help?
I'm not an electronics expert, but I can solder a wire if I can find the right spots. I'm worried if I rip the whole power supply block apart, I'll break some shielding solder points and other connections that I won't notice when I do it.
Any help would be greatly appreciated.
Nov 10, 2011. 11:21 PMdkollin says:
Apple just settled a class action lawsuit and is now replacing these for free: http://cnet.co/tl5p4W. I walked into the Mac store with my crappy one, they made me sign a document and then handed over a new one. Simple as that.
Oct 13, 2011. 4:09 PMmkuplens-ewart says:
What temperature soldering iron did you use? The solder doesn't want to release with a 25W.
Sep 11, 2011. 7:52 PMhghalib says:
Great tips, can you tell me how to fix the other end? which goes to charge the macbook pro? I have an old adapter, its other end wire got loose, i was travelling to Pakistan and had it repaired from a local electrician, but it got torn again, any tips? i can send u some pics~
Sep 11, 2011. 9:06 PMhghalib says:
I know, i wanted to know if you can post some tips if the magsafe end that plugs into the MBP, can be repaired, if one of the internal wire has broken?
Sep 4, 2011. 2:35 PMcgosh says:
When I find any device with a thin cord, I know it's going to (eventually) fail. Repeated bending NEAR EITHER END OF THE CORD will cause the fine wires inside to break, even though the plastic insulation is OK.
If you wrap the cord around the device, start wrapping a few inches away from the end and leave a loose loop; don't pull it snug to "look nice."
I put a glob of silicone caulk, some Shoe Goo, hot-melt glue, masking tape, scotch tape -- anything -- that will spread the bend further along the cord. Make sort of a pyramid shape, with the peak an inch or more away from the end. You'll find a "strain relief" on many cords -- just duplicate the effect.
Kinking the cord right at the plug or power supply is what you'll avoid. By making it bend gently there, then gradually flexing along the next inch or two, you will never have a cord fail this way.
You should never pull any cord by the cord itself. That's why they put a grip on the end. It was not designed to be pulled by the cord.
As for pets, don't give them rubber chew-toys.
Sep 2, 2011. 12:47 PMjuanpanet says:
Hi:  Thanks a lot for this instructable.
Aug 26, 2011. 5:16 PMr54070 says:
Aaron, well done. One question though, using this same procedure, can I take an old iBook power supply and convert it to a Magsafe power supply? Always nice to have a spare power supply for my Macbook. Thanks.
Cary
Aug 26, 2011. 7:30 PMr54070 says:
Yes, I will have to check on that as I don't recall the wattage of the iBook power supply. Thanks for the info Aaron.
Aug 21, 2011. 2:07 PMwkjiii says:
Sorry - forgot to mention that you did a very nice job instructable !
Aug 21, 2011. 2:04 PMwkjiii says:
How can I avoid this problem in the first place?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:AaronX2621
