loading
Having owned several Apple notebooks which utilize the MagSafe adapters I've seen my share of failures.
Anything in from stuck pins which prevent the computer from charging to my cats deciding the adapters are made out of some rare form of addictive kitty-crack and shorting out the cord by chewing on it.
I used to buy new MagSafe adapters but that got expensive fairly quickly. Then I decided to splice out the shorted sections of cord; which did work but left me with relatively short cords for charging the computer. Next, I decided to figure out how to crack open the adapter and replace the entire cord and that's the process I'll demonstrate with this instructable.
Be careful and make sure the adapter is completely discharged. Capacitors can hold a charge for a while so it's best to leave the adapter unplugged for a bit prior to working on it.
Materials/Tools needed:
Needle Nose Pliers
Soldering Iron
Solder
Desoldering Braid
Flux (optional)
Super glue
Clamp(s) or even a heavy book will do.
Replacement MagSafe cord- I found mine on eBay for like $16.
Step 1: Opening the Adapter
Some other tutorials online have used things like a Dremel and a cutting wheel to cut the casing apart or they used a screw driver to gouge the plastic apart. This not only makes reassembly more difficult but makes the reassembled adapter a bit ugly. We're actually going to use a pair of needle nose pliers and some leverage to crack open the case along its two halves. This leaves really no deformed plastic and makes the adapter much easier to reassemble.
Flip open the cord winding ears and insert the plier ends as the picture shows.
Open the pliers until you hear a satisfying pop and then do the same on the other winding ear.
This will typically separate the two halves almost completely but the case will still be held together near the wall plug and along that back seam. To get those to release you'll need to grab the two halves and pull them apart until those also pop apart.
Step 2: Ok So Now It's Open
Ok so now you've got the adapter open. You'll see two winding ears, two spring clips, the electrical internals and then the two halves of the outer case.
Take the internals completely out and set the case components aside so we can use them later for reassembly. Then you'll want to peel the 3M tape up so we can move some of the metal shielding out of the way so that way we can access where we need to solder.
Step 3: Removing the Current Cord
Bend the shielding out of the way to allow you to access the two solder points we'll need to desolder to be able to remove the current cord. These are labeled white and black in the picture below.
Use desoldering braid to desolder the cord and then remove the old cord from the main board.
Step 4: Solder in New Cord
Solder in the new cord. Pretty self explanatory really.
Then once you complete that bend the shielding back into place and retape the other flap of shielding back down.
Step 5: Reassembly
Insert the charger back into half of the outer casing and then reinsert the spring clips. These clips keep the winding ears either held open or closed so they don't just flop around on their own.
Next replace the winding ears in their little holes in the outer casing.
Then place little dots of super glue at the indicated spots, slide on the other half of the case and clamp them together.
<p>Use the snap-ring pliers, take the bits out and just use the body of the pliers. There was white silicone holding mine together from the inside, it took a good amount of pressure to pop this baby.</p>
I'm going to be without an adapter for a few days, so I'm going to put one together from my collection of parts I've saved over the years. I've got a good power adapter I can use with a spare magsafe cord I have. <br> There's no wire to splice onto, so I'll have to solder it to the board. I didn't unsolder the cord from the board myself, and its been long enough since i've done this, I thought I'd make extra sure I have each of the 2 wires going where they should...<br> It will be a normal apple 45w 24v t-connect magsafe adapter, from the core2duo era of macbook pros.<br>There's only 2 choices. Hot and ground. Labeled vo and gnd on the board. But since I didn't see with my own eyes, where each was soldered I thought I'd get a second opinion....the center 'core' wires carry the voltage (vo) and the outer 'sleeve' goes to ground (gnd), right?<br> Seems like a stupid question, but I keep thinking 'what if...?&quot;<br>What if I plug it into the wall, hear some crackling sound, then smell the sharp smell of burning resistors, diodes, capacitors etc. You smell it once and its easily recognizable for the rest of your life. doh!<br>What if... lol!
<p>Capacitors can hold a charge for around a year!</p><p>BE EXTREAMLY CAREFUL!</p>
<p>I recently soldered my charger back together however now it will stop charging within about 5 min but will start to charge again if i un-plug and plug it back into the wall. This is a bit of a hassle as it happens every 5 to ten minutes. Any idea what could be wrong? Thank you </p>
<p>I soldered it to the circuit board, but i also do not have the casing tightly put back together, need to go out and get super glue. Could the casing not being tight have anything to do with this?</p>
<p>Instead of a pliers, a standard bic lighter works wonders for opening the case. Just wedge the bottom in and twist.</p>
<p>This was way WAY easier than using plyers, for me at least. So THANK YOU! for this suggestion. I have done probably 10 of them and using plyers I always slipped at some point and managed to dig into the casing </p>
Right? Way better than gouging the plastic or shanking yourself in the hand.
<p>Hi,</p><p>I recently got a 60W MagSafe power supply with a broken cable. It came with few questions:</p><p>1. Will it work correctly whether I change the cable to MagSafe2 and use it as an extra charger to my new Mac Book Pro 13'' with Retina? </p><p>2. Will there be any difference in charging time?</p><p>3. Are they the same power supplies from the point of view of electronics? I think that I can do so since an adapter from MagSafe to MagSafe2 does not probably contains any electronics, does it?</p><p>Thank you in advance for all answers!</p>
<p>1. Yes you can install a magsafe2 cable in a magsafe charger and it works fine. I've done it to several.</p><p>2. No difference noticed.</p><p>3. Yes they're the same electrically, just the end is different.</p>
<p>Wow! I did it and it was so easy--way faster and fewer steps than changing my iphone's screen. Thank you! I'm not sure if you are the same person or not, but there's a good youtube video that goes well with these instructions. I was having a hard time prying it open with pliers, but seeing someone else did it helped.</p>
<p>I'm not the one who did the video, I think I know which specific one you're talking about though. </p>
<p>Thank you for this!!! I successfully replaced the damaged cable on our power supply. I wish I had solder wick though; I had a very hard time trying to install the new cable without solder wick.</p><p>The cable I got from ebay for somewhere between $5-$10. I wonder if it is a generic cable or if it is a genuine cable. It seems to be a genuine cable that was salvaged from a device.</p><p>There is a problem though... the cable has a chip inside that contains information including the type of power supply (45W, 60W, 85W) and serial number. The listings dont tell what type of power supply it is for (they just say it is for any power supply.) The cable I got was actually from a 45W power supply. So even though the power supply is 85W, the cable &amp; plug is from a 45W power supply so the cumputer thinks it is a 45W power supply and I think it draws less power. Though it still works fine anyway.</p><p>I didn't do the greatest job on this repair but this was my first and it is not too bad! It's better than the previous repair I did where I just spliced the new cable on the old cable.</p><p>BTW I used epoxy to glue the case together because super glue would harden too fast.</p>
<p>Thank you for taking the time to put this up! one lead replaced and charger fully repaired! </p>
<p>Tried this and found that accessing the solder areas where the cable is attached to the circuit board is quite tricky, and in my case it destroyed the unit. Fortunately I had another spare with a broken lead - so the second attempt I simply cut the wires on the old lead inside the case and soldered the new lead to the stub of the old one, taking care to insulate the joins properly with tape (or better still heat shrink sleeves). This made reassembly much simpler. However, take care - after the charger has been unplugged for a few minutes the capacitors remain charged and can give you quite a nasty electrical shock...</p>
<p>https://www.ifixit.com/Guide/Restoring+Apple+AC+Adapter+Broken+Cable/24487<br><br>this tutorial really fix my magsafe.</p>
<p>Thanks for the quick open trick. Our web guy needed his fixed 'ASAP' and we had it repaired before he got back from lunch. Got some personal satisfaction out of putting this thing in the vise while the glue dried... ;)</p>
<p>Thank-you so much. I have a several of these lying around, including a cheap Chinese knockoff version that shorted out. So far I've spent hundreds on these things with my 2 macbooks...The problem with these things is the stupid rubber shielding around the wires deteriorates completely after a few years. Electrical tape only works for so long before it dies at the ends... If they weren't trying to be so fancy and just gone with a simpler cheaper plastic like everyone else, it would have lasted better. The irony is that the cord for the Chinese knockoff is lasting longer then the real ones. My only problem was that I didn't know how to open them. Thanks for the pliers trick! That really is clever.</p>
<p>Bro i need your help.My magsafe got fryed with 440 volt.I opened that and i find some round Golden capacitor burnt .it is just right besides the poer cord connector.I took it to electronics shop to buy new.he said i could not recognize capacitor number or reading.I would be very thankful if you tell me reading of capacitor .mine is 85W magsafe L connector for 15 inch MBP.</p>
<p>Thanks for the nice instructions! If separating the plastic case proves to be difficult, you might try some nitroalkanes-based superglue debonder. This dissolves the glue, making the two halves separate easily, and you can probably do the job without even resorting to the pliers. I get mine from caglue.com, and use it for all kinds of superglue tasks, including when I get some on my fingers.</p>
<p>Acetone works well as superglue debonder - can be found in the hardware store. You can also use some nail polish removers - which are basically acetone. Some nail polish removers are not acetone - check the label.</p>
<p>Just tried prying open two of these (one where the power adapter is broken and one where the cable is broken), the one with the cable opened up easily as described. The other one however is really so sturdily glued together that there's no change prying it open severely deforming the housing.</p>
<p>I had this problem and liberally applied superglue remove / acetone. Then it came apart quite easily. Acetone is also used as nail polish remover, so if you can't find it look there. Note there are non-acetone nail polish removers, so get the right one to remove superglue.</p>
<p>Well, this seems harder than necessary, as noted below. I've repaired several Mac power supplies with defective connector cables/connectors by just slicing off the cable, and splicing a new one (with a new MagSafe connector on it) back on. If you slice it off close to the connector, once you splice the new cable back on, you have a cable that is twice the length. You don't have to crack the case open at all. Two wires to solder. That's all. Then some shrink tubing, and you're done! No glue. No cracked plastic. No Dremel/cutting wheel. Geez. </p>
&quot;Be careful and make sure the adapter is completely discharged. Capacitors can hold a charge for a while so it's best to leave the adapter unplugged for a bit prior to working on it.&quot;<br><br>Missed this part.. Those capacitors packs a punch, thats for sure.
<p>I used a pair of snap ring pliers, you can set them to squeeze the handle to open the jaws, much easier than pulling handles apart.</p>
<p>Hey, thanks so much for taking the time to put this up, I'm now typing this from my laptop with repaired charger, you've saved me a load of money! Cheers!</p>
<p>Hmmm, I have an old magsafe with a broken cable and a new MacBook Pro Retina using Magsafe 2. Is it safe to solder a Magsafe 2 Cable to the old power supply? </p><p>Any ideas? </p><p>Thx!</p>
Unfortunately this likely too late to inform you of this, but this may benefit others. One of the 'Best'-known retailers sells a Magsafe to Magsafe2 adapter. A lot easier and much more convenient. And if I recall correctly it's a Mac product.
Yup I did that with one of my magsafe 1 adapters when it needed a cable replacement since I got a newer Air. Apple also makes a little adapter for the end of a magsafe 1 cable too.
<p>Just tried it - and it worked great! Thanks! Cords are available on eBay or Amazon. A few slight variations that I did and wanted to share:</p><ol><li> I left the white and black cables connected to the board then cut and stripped the other ends.<li>I used shrink tubing to protect the two new solder connections.<li>I used clear packing tape to hold the case together when I was done. It works well, and makes it easy to open the case if I need to do this again someday.</ol><p>Again - thanks for the great pics and helpful instructable!</p>
<p>Was there enough room for the extra wire? i find most electronics are pretty tight for space. </p>
Any recommendation on where to get magsafe cords? I've got a few good power supplies with bad cords and would like to replace them.
They have them on AMAZON. $6.00 and change with free shipping
<p>Ebay has them for $6.00 currently.1.12.15</p>
<p>Yes,good instruction but ....BUM destroy the Macbook :(</p>
<p>Its pretty dangerous. Did it work for you afterward? I expect it did. My Magsafe power didn't work before and i didn't repire it.</p><p>thanks for the info. Was wondering about replacement adaptors. Thought it might be a cheap way to get the quality without having to deal with knock offs?Anyone heard of this site?<a href="http://www.eachbattery.com/magsafe-chargers-c-94" rel="nofollow">replacement adaptor</a></p>
<p>&quot;leave the adapter unplugged for a bit prior to working on it&quot; means for about 48 hours, and even then they have a little charge left</p>
<p>I tried this as a last resort before getting a new charger. I soldered on the new wire I got off ebay, but no power comes through it. There's a slight humming/buzzing from the charger though. Do you have any recommendations as to what I can do?</p>
<p>Thank you for your instructable, it is the what I was looking for. But why did you glue it? I assume you might need to open that adapter once again.</p>
<p>I only used small amounts of glue in the locations I showed. It's not enough to prevent you from cracking it open again. I have one I've had to do a few times now due to the cats. I've been able to crack it open after gluing and then re-glue it shut again after the 2nd repair.</p>
<p>Hi - I repaired two of these. The first one worked like a charm (Thanks!), but the second one did not. The configuration of the board on the second one was considerably different, and it looked as if printed circuits were much closer to the soldering - so it's possible that I fried one of them. DIY-ers should be aware that their power supply's configuration may differ, in which case the operation is a little tougher.</p>
<p>Thank you for this, I'm still waiting for my replacement cord to arrive so I've cut the existing wire &amp; soldered it directly to the board. You have saved me about &pound;30 thank you again.</p>
<p>I just repaired the power adapter for my wife's MacBook and it's now working perfectly. The case cracking method is inspired! Never would have thought of using a pair of needle nose pliers that way. I hate that cliche about &quot;thinking outside the box&quot; but it truly applies in this case. Thanks.</p>
<p>This was a great tutorial, thanks! I need to do something similar. I have a power adapter form an original mac mini.. 85 watts with a magsafe connection.</p><p>I want to use it on an ibook G4 which needs a 60 or 65 watt adapter and uses a 2.5 or 2.55 mm mini plug. I'd like to keep the power supply intact and not do any splicing if able. Can I either, remove the magsafe cable entirely and add the needed mini plug or build a short 6-8 inch adapter which goes from the magsafe plug to a minplug?</p>
<p>The Magsafe cable itself is only 2 wires, the negative and the positive. So, you can just cut the wire and splice the two together. </p>
About This Instructable
681,287views
187favorites
License:
More by AaronX2621:How to open and replace the MagSafe cord on an Apple AC adapter Sonicare Elite 7300 - Battery Replacement
Add instructable to:
