How to overclock Intel CPUs?
First of all let me make it clear that overclocking basically means to over-work your hardware and make it operate beyond what it was designed to do. This can sometimes result in permanent damage to your hardware. But don't be afraid, if you carefully follow these instructions, be patient and calm, overclocking will become second nature and you won't end up damaging anything. Trust me!
Let me also make it clear that there can be no definitive step-by-step guide to overclocking in this world, each individual component has different limits and each motherboard has different options and BIOS versions, meaning that OCing (I'll refer to overclocking as OCing from now on) is more of an art then it is a science. This instructable is strictly for Intel CPUs, AMD OCing is drastically different.
Step 1Requirements and considerations
First of all, I would like to mention that OCing of Intel CPUs can be done in two main fundamental ways:
1) Increasing the Front Side Bus (FSB), which means to increase the data transfer rate between the CPU and RAM
2) Increasing the multiplier, this option isn't available to most users since almost all Intel CPUs apart for the Pentium Extreme Edition and Core 2 Extreme have their multipliers locked.
Another thing is that we would be using the BIOS to perform all our tweaks, there are various softwares out there, but they only support a limited number of motherboards and are not that reliable. Also note that when you OC CPUs, you are also OCing your motherboard (in which the FSB is implanted) and your RAM. OCing RAM is notoriously tough and risky, but you can deal with this issue by decreasing the FSB:DRAM ratio we will be discussing later.
Ideally, you'd want these motherboards to OC on:
Intel P35
Intel X35
Intel P45
These motherboards are not so good at OCing:
Intel 946 chipset (though I personally have it and managed a 25% OC without any problems)
Perhaps the biggest problem with OCing any component is overheating. If you want really high OCing capacity of 70%+ then nothing other then a water or liquid cooling system will do. mid-range to high-end air cooling is known to be able to OC to around 60% while stock cooling can only reach 30% at max (my E2160 has stock cooling and a 25% OC). There is no exact temperature limit for any CPU. But as a general rule, you wouldn't want your temperature at any more then 75 (degrees celsius) under load. Having it at above 60 degrees shortens the lifespan but that shouldn't be a worry if you don't plan on using your CPU for more then 2 years.
Recommended software
To check for basic statistics regarding your CPU, I strongly suggest that you download the CPU-Z utility from:
http://www.filehippo.com/download_cpuz/
And get Speedfan for closely monitoring your temperatures, but before this, look around the CDs your motherboard came with for a specific utility for monitoring them. ASUS motherboards for example, come with ASUS PC-Probe which is far more accurate then universal monitors. But here's the download link if you don't have one:
http://www.filehippo.com/download_speedfan/
Also, download a simple application called SuperPI, which essentially gives your CPU a task to do and times how long it takes for the task's completion. Note that this application doesn't support multi-threading meaning it can only utilize the power of one core even if you have 2 or 4 But the purpose here is to check for basic stability and performance increase. You can get it form here:
http://www.techpowerup.com/downloads/366/Super_PI_Mod_v1.5.html
77 comments
1-40 of 77next »
Sep 12, 2011. 10:58 PMjj_alukkas says:
As long as you dont have an Intel original motherboard, your multiplier wont be locked. I use an Asus and vary the multiplier base frequency to hit the speeds I need. I dont run it overclocked, just take a couple of screenshots and go back.
Jun 7, 2011. 12:19 PMasoo1 says:
can u make tutor how to clock intel gpu's i need to clock intel gma 4500mhd for better performance :)
Mar 9, 2009. 6:14 AMMuscelz says:
very nice instructable :) im running my Pentium D 945 which is stock at 3.4ghz @ 3.65ghz--(idle 34oC, full load 45oC. using the Cool Master V8 heatsink), very stable obviously becuase of such of a minor OC. i decided to put my cpu to the limits. i hit 4.4ghz (idle 40oC, full load 60oC) and had had trouble doing most things without getting a blue screen :S i had to set my core voltage to .1V over its stock rating which alowed me to gain stability. which i DID NOT like doing. but it waz only for a short time damnit it wont let my add a pic. uhm... if u wanna see add me on msn bloodhound73@gmail.com
Apr 12, 2009. 7:55 AMMuscelz says:
the pics
Dec 31, 2010. 9:32 AMzack247 says:
wow, you got a pentium D that high? my board doesn't even allow overclocking, too bad since 4.4ghz is pretty fast.
Jul 6, 2009. 6:36 PMReCreate says:
Wow, 4GHz!
Aug 22, 2009. 11:23 AMMiles Tails Prower says:
Lol, I overclocked my computer to 4.8 GHZ. It was 3.0 ghz. It did not get hot, or malfunction. But still I stopped it because i did not want my computer to die.
Aug 22, 2009. 2:40 PMReCreate says:
If it does not overheat it will not kill your computer XD Was it stable? I noticed that when my CPU nears 170 Degrees My OS starts going unstable, At about 150 it sets the fans to high speed, and cools down again. I remember on an oldie laptop, the CPU will tolerate temperatures up to 200 Degrees! 190 Degrees is the standard temperature XD It has a passive heatsink...
Aug 24, 2009. 11:26 PMMuscelz says:
they can tolerate that for a very short time, running @ 100oC for a cpu is like taking 1000 hours off the cpu's life. its ensentially wearing them out, think as it as redlining your car 500rpm over "redline starts" for a small OC, there for just a small jump over redline means increased heat, meaning will tend to wear more therefore taking hours off the engine and in this case hours off the cpu if you can understand it that way
Aug 25, 2009. 9:37 AMReCreate says:
Well...No...if the overclock doesn't overheat the CPU, it would last as long as any CPU would last(pretty much forever)
Aug 25, 2009. 7:01 PMMuscelz says:
yes, some overclocks don't make components over heat, what im trying to say is its being flogged, they are only designed and tested to run at a persific frequency because they will have longer life etc etc, its the component internal strength will be diminished over time, and once over clocked, the cpu WILL lose expected life FULL STOP overclocking increases the break down of the structural integrity of a cpu/component
Aug 26, 2009. 10:09 AMReCreate says:
By the tiniest bit.
Aug 27, 2009. 3:36 AMMuscelz says:
lol no, some cpu's 100mhz over stock freq can 1/2 its expected life, they are made to a degree where they reach "WEAR POINT" where the cpu will dramatically lose life due to the overclock for eg. lets take a E1400 LGA775 They are fine to 25% over clock where the CPU sits at CORES:2.5ghz FSB: 1000mhz it will be losing approx. 1/2 of its life at that OC But when we jump up to a 30% which will be CORES: 2.6ghz FSB: 1040mhz the "wear rate" of the cpu is almost 1/2 over the previous OC due to the geometric rate of break down inside of the CPU. meaning it will take around 3/4 of its life off low OC's on tough CPU'S will last just as long as they where running on stock freq, for EG the E1400 is a very strong cpu and will easily take a beating, running at 20% OC will hardly take any life off it, its just when you jump up just that little more things start to brake down 10x faster its sort of confusing. i hope you understand
Aug 27, 2009. 11:16 AMReCreate says:
Oh well...My CPU won't last a 1000 Years, just 500. >_> Your right.
Aug 23, 2009. 3:50 AMMiles Tails Prower says:
Yeah, my pc said that there was an error but it was just windowed after startup, but not a blue screen. It didn't smoke or overheat though. I won't do it again just for sure. XD.
Aug 24, 2009. 6:48 PMReCreate says:
Error?
Jul 6, 2009. 11:21 PMMuscelz says:
only a 600mhz OC, isn't to great. but its pretty good for me
Jul 7, 2009. 8:37 AMReCreate says:
Well 600Mhz Overclock seems pretty good for a first timer, was it your first time doing this?
Jul 9, 2009. 8:34 AMMuscelz says:
ive been overclocking for a few years now, that wasn't my 1st. i was just seeing how high i could get my 945 up to till i was causing damage
Jul 9, 2009. 9:29 AMReCreate says:
Oh...XD i got a 500 MHz Overclock on my first time ;) i think its pretty good :)
Jul 12, 2009. 9:07 AMMuscelz says:
the Pentium D failed on my a few days ago, it lost stability on stock freq, so im using my spare Dual Core E1400 till i build my new rig, its clocked to 2.66ghz, thats 662mhz above stock freq. no voltage changes, still stable as
Jul 12, 2009. 10:15 AMReCreate says:
Stable as what?
Jul 13, 2009. 12:15 AMMuscelz says:
stable at its stock frequency and that was 3.4ghz. my dual core is out performing it now lol
Jul 13, 2009. 7:12 AMReCreate says:
It was probably overheating, Was it a laptop or desktop?
Jul 14, 2009. 3:29 AMMuscelz says:
no, it wasn't overheating. it wasn't going over 35oC on full load, its a desktop and and its got a massive Coolermaster V8 Heatsink on it. so definitely not over heating
Jul 14, 2009. 9:28 AMReCreate says:
Well i don't know, it was perhaps a defective processor.
Jul 14, 2009. 7:54 PMMuscelz says:
yea, im going I7 now. my new build will cost me 6grand lol
Aug 22, 2009. 2:41 PMReCreate says:
Wow, I heard that some extreme processors from intel are costing up to 1000$! WOW!
Aug 23, 2009. 4:34 AMMuscelz says:
lol yea, myne cost me 1.3grand, i got a 975 atm
really?
Jul 14, 2009. 10:55 PMReCreate says:
6 Grand? You might as well buy a mac, a pc does not get that expensive while being worth it what are the new pc's specs?
Jul 14, 2009. 11:51 PMMuscelz says:
rofl, not a mac, I despise them. here's the specs, I'm ordering the parts next month, i shud have the money by then
EVGA X58 Classified E760 Motherboard
Intel Core i7 950
Corsair TR3X6G2000C8GTF 6GB (3x2GB) DDR3 (x2=12gig)
EVGA GeForce GTX 295 CO-OP Edition (x2 for SLI)
Corsair P256 SSD(256gb) (For Games and OS)
Western Digital RE3 1TB WD1002FBYS (Media etc)
Corsair HX-1000W 1000W Power Supply
Lian Li TYR PC-X500
Xigmatek Thors Hammer Double Layer HDT CPU Cooler (CPU H.S.)
Corsair Dominator Airflow 2 Fans (RAM FAN)
Lian Li TYR PC-X500 (CASE)
My idea is to get good quality gear so you won't be replacing faulty parts and it will last
so around 6grandish $AU
Dec 6, 2009. 2:54 AMfnnw7777 says:
 =[ whats wrong with mac, u could get an 8 core mac pro or wait until intel releases it i9
Jul 14, 2009. 11:54 PMMuscelz says:
and i got a pre-order for Windows 7 x64 :D she's gona fly
Jul 15, 2009. 7:05 AMReCreate says:
Nice windows 7, Pre ordered, I would if i had money, the prices are pretty good now, but they are gonna go up :( Sky high I would be a little careful about Installing vista's brother 64BIT , though 7 is better than vista in many levels Especially being fresh out of the oven...Ahem...Microsoft you remember how the first vista beta was? and 64 bit...
Jul 15, 2009. 8:56 AMMuscelz says:
lol yea, as buggy as hell. but that dnt phase me, i got XP PRO x64 and Vista Ultimate x64 as back up oh and Debian. the serial for Win 7 is all i want
Jul 15, 2009. 9:46 AMReCreate says:
XP 64 bit? Debian? Vista? How big is Your HDD?
Jul 15, 2009. 9:31 PMMuscelz says:
i got close to 2tb of storage
Sep 13, 2011. 6:30 PM-max- says:
i can see you having a supercomputer soon and have the ability to download the internet to you computer!
Jul 15, 2009. 9:39 PMReCreate says:
Wow, Pretty sweet i got an itty bitty 80GB -_-
1-40 of 77next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Ali_Athar
