3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to pack a bike with S&S couplers
My bike has S&S couplers (also known as S and S Machine Bicycle Torque Coupling) that allow it to be broken apart and packed into a normal-sized checked luggage box that flies at no additional charge. Getting it to fit is always a challenge, so I took photos to help me remember.
Your S&S-enabled bike will probably pack in a slightly different configuration, but you can still use this as a starting guide.
Step 1Disassemble bike
Take off the brakes, the rear deailleurs, the cranks, the handle bars, and fork.
8 comments
May 19, 2011. 7:45 AMBtheBike says:
Are there any diy S&S couplers ? those things are Way costly . Love to be able to do that with a similar cheaper pipe connector .
Jun 3, 2010. 4:00 PMmwarren_us says:
Hopefully the expiration of Steve-Frank Smilanick's patent 5586652 Bicycle torque coupling in 2013 will make these couplers more readily available.  They're extremely clever, but currently apparently only available to qualified bicycle frame builders. Which frame does your bike use?  Also, are the bottom portions of the white supports attached to the bottom of the case somehow?  Thanks for the clear pictures and detailed steps.
Jun 23, 2009. 6:18 PMYerboogieman says:
How do you ship a regular bike?
Jun 24, 2009. 7:14 PMYerboogieman says:
I've heard by a bunch of people that they treat large cardboard boxes not very nicely and you can end up with something broken.
Dec 13, 2007. 6:52 PMPunkguyta says:
Wow, Houdini probably wouldn't be able to fit a bicycle in a luggage bag that well. Good stuff chap. -Punk
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
703
Author:ewilhelm
Eric J. Wilhelm is the founder of Instructables. He has a Ph.D. from MIT in Mechanical Engineering. Eric believes in making technology accessible through understanding, and strives to inspire others ...
more »
