iImage Information
Before going backpacking it is important to know how to properly pack your backpack. Backpacking is an amazing experience but can be very difficult. To get the most out of your backpacking experience make sure, before starting your trek, that you back pack is properly packed. By following these easy steps you can have an awesome time backpacking enjoying the view while relieve the stress on your back. The first thing to do is stet out all the stuff, that you will be taking on the trip, out in front of you to see. Make sure that everything is in visible sight.
Step 1The Pack
iImage Information
Set your pack out and make sure that nothing is in it. Make sure that it is completely empty. Put the pack in a place where you can easily put things into it.
Usually, where I hike ( the back country of New Zealand) there's abandoned soap around the place and sometimes shampoo as well.
It is important to pay attention to the type of pack you are carrying. I use an Aarn Bodypack and therefore water is stored at the front of balance pockets which attach to my shoulder straps and counterbalance the pack weight.
With a regular backpack, water is best stored behind the pack against the back in a camelback or similar, or inside the pack at about the shoulder blades, right against the back. This will not only keep you stable and help transfer weight to the hipbelt but will also keep the water and plastic reservoir cool.
Drinking 32oz of water an hour is for desert or extreme scenarios. Try that up in the BWCAW during march and you will just be stopping ever 20 rods to urinate.
I like to use a backpack on all of my trips (even if I do rarely hike, but most often use planes and trains) as it is the easiest way to carry your stuff around a crowded train and even on a short walking distance in a town.
From my own experience:
- put anything slightly liquid inside a (possibly sealed) plastic bag. Even if you just put your sun screen into the plastic bag from the convenience store or not - it _will_ make a difference if the security control procedure (or your mis-step on the trail - or whatever) opened the sun-screen-container (trust me, been there, done that )-;
- if you have to carry your backpack a lot/a long time (i.e. real hiking) put the heavy stuff low and as close as possible to your back
- on the other hand - if you just use a backpack for convenience (i.e. no real hiking): put the stuff you'll need the most often (your pyjama, your tooth brush etc.) close to the surface (easily accessible) and bury the stuff you will not need often (or perhaps not at all). You wont probably need any water/liquid in that case (airlines wont take it anyway).
- put any liquid/creme into a sealed container or bag! (Just in case I do repeat myself: Yes, some spilled sun screen _is_ a nuisance.. :-)
- if you take a plane: don't put anything you will need on your destination into your backpack / checked in luggage. Keep it in your hand luggage as the checked in stuff might be delayed.
Keep on travelling/hiking!
