3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to paint foam latex appliances
Shock! Horror! It's flat, opaque and looks nothing like skin whatsoever. When compared to its translucent cousins, gelatine and silicone, that foam rubber nose could look like an unwelcome option.
But foam latex does have its advantages. It is durable, absorbs perspiration rather than collecting it in pockets and it doesn't dissolve or melt. Best of all, you can repair, re-glue and re-colour knowing that it's opacity will hide a multitude of sins- that is if it's well painted! This article will cover a simple procedure for colouring a foam appliance on the face.
Incidentally, if you like this kind of thing why not check out the free mini ecourse on my site-sign up quick and easy at LearnProstheticMakeup.com!
Step 1Get your materials together
You will need:
" Pros Aide & remover
" Acrylic paints (I like liquitex, but most brands will work fine)
" Rubber Mask Grease Paint (RMGP)
" Alcohol activated makeup (Skin Illustrator/Stacolor/Kryolan)
" Plastic cups
" IsoPropyl Alcohol
" Cheap bristle brush/chipbrush (12mm/1/2)
" Cotton tipped buds such as Q-Tips
39 comments
Oct 28, 2011. 1:46 PMscry says:
What appliance did you use? this one looks amazing - perfect buffy style vamp!
Oct 28, 2011. 3:29 PMscry says:
ah bugger thats a shame - tis exactly what i was looking for too lol - typical really :) thanks for letting me know though.
Oct 19, 2011. 3:39 PMrandys42 says:
Hi all...
I'm using latex over my upper body. I was going to stop the latex under my jawline and use paint on my face which will cover a latex appliance. Is there any way I can apply the latex paint on the appliance? If I can will I be able to re-use the appliance? I need to use it twice and I'll be done with it. If I can do it I can eliminate the slight color difference between the latex and the paint.
On a related note...same costume...I'm wearing tights that are the same color as the latex (teal) but I'd rather have my legs not feel like fabric. I was thinking of covering the fabric with the same latex as on the rest of the body. Would that work? And would the latex affect the elasticity of the fabric to the point that I couldn't remove my foot without tearing the latex?
Thanks in advance for any advice!
Randy
Oct 21, 2011. 11:36 AMrandys42 says:
Thanks for your reply. I'm using a foam latex appliance and spirit glue to attach it to my face except for the edges which I use latex. If I put latex on the tights, I'd do it while wearing them.
I thought that latex might not work well to cover fabric that was tight on begin with since it shrinks as it dries anyway. The alternative is to live with the teal color of the tights and use paints for the details on the legs.
Matching everything will be hard but if people will be looking more at my upper body anyway so it might be okay to not mess much with the fabric.
Oct 26, 2011. 10:01 PMrandys42 says:
I gave it a shot tonight. I found latex to be extremely difficult to use when applying on yourself. You will invariably move a certain way so that latex from one part of the body touches another part and then tears. The bend at the inside of the elbow is a common problem spot.
I'm sure the order in which you do it matters. I did my arms first and that was a mistake. It seems that the best way would be to complete whole sections with all the layers and then apply a fixer to the surface. Then you can move on to the next part and do the same thing. That way the arms won't stick to the side of your body.
So I'm thinking do the torso first to completion. Do one arm to completion, Then the other arm to completion. The question is WHEN should I apply the appliance? Before I do the body or sometime in between doing sections? After applying several layers of latex and using a hair dryer to speed up drying, I started to perspire and the latex just pulled away from the skin in different spots.
I put latex stripes on the tights. That worked out okay, of course the latex did grab a good hold through the fabric and onto my skin. When I removed them they were puckered where the latex was applied but otherwise looked re-usable.
Thanks!
Oct 26, 2011. 2:07 PMmholbrook1 says:
Hey this is more of a question than a comment. Since I have purchased foam latex prosthetics from multiple online stores for halloween and no one there will answer me in a timely matter (Weeks) thought id ask u...
My question is... I want the prosthetic to be skin colour, and HATE the feel of grease paints, could I use a foundation for skin tone instead or would this ruin the mask? The prosthetic is quite large, takes up my whole face, and I dont want to paint it, my face, my arms, neck, back etc just to have it look real. Any sugestions would be greatly appreciated!!
Oct 16, 2011. 1:56 PMBeerBellyJoe says:
Do you know of anywhere in the US that sells Alcohol activated makeup that's cheap? That stuff seems expensive!!!
Oct 9, 2010. 6:29 PMthedonquixotic says:
I have a question. I hope this isn't a dumb one, but it is it possible to paint it with oil based paints?
Oct 9, 2010. 11:27 PMthedonquixotic says:
Oh yeah, and I am not using the oil paint to blend the prosthetic, just to get it closer to my skin tone. Its a little pale..
Oct 9, 2010. 11:26 PMthedonquixotic says:
Yeah. I do mean artists paints, hahaha. What if I am using mineral gum instead of Pro-Aide though?
Oct 10, 2010. 10:02 AMthedonquixotic says:
Cool thanks! I will look into that.
Feb 15, 2010. 11:55 PMPeroxide says:
This is probably the nicest vampire prosthetic I've seen! If you don't mind me asking, what brand is it?
Feb 16, 2010. 2:10 AMPeroxide says:
Wow, very impressive!
It looks beautiful.
I'm trying to get into sculpting for FX makeup, and boy it's hard.
Nov 20, 2009. 10:28 PMaborior says:
Was I the only one that thought of Angel or Buffy vampires when they saw this?
May 7, 2009. 11:02 AMrachel says:
Very interesting, I had no idea how this was done. As someone utterly new to this, I'd benefit a lot by some pictures of the materials, the mixes, the tools, and of course if you had someone around to take pictures of you doing the painting. But even so, highly informative.
Oct 23, 2009. 8:31 AMan_artist says:
Wow! From a cute guy to a neantherdal... But how comfortable is it? Can you really do normal expressions with that? :D
Oct 21, 2009. 6:16 PMSunny124613 says:
you look like an albino gorilla
lol
5 stars
May 7, 2009. 9:47 AMscoochmaroo says:
Looks great! I was first introduced to PAX while working for the Blue Man Group. We used it to cover the mouth and nose, as well as the transition from bald cap to skin. It's a great way to ensure continuous coverage even on areas that get a lot of wear!
Oct 19, 2009. 8:07 PMANTQNUT says:
Wow! that would be so cool to work for the blue man group! they are epic!
Jul 19, 2009. 4:30 AMamakerguy says:
awesome!
May 17, 2009. 2:26 AMFashim says:
wow that picture looks like one of my friends XD.
Jul 7, 2009. 7:39 PMANTQNUT says:
LOL
May 21, 2009. 4:03 AMcoolo52 says:
nice
May 15, 2009. 8:31 PMANTQNUT says:
That is soooo cool!! PS i don't think the pics are that small! :P
May 8, 2009. 1:32 PMrobomaniac says:
Nice instructrables but yours pictures are very small!
May 7, 2009. 2:24 PMSinAmos says:
valuable stuff here. Good work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
104
Author:stuartbray(Learn Prosthetic Makeup)
I create and teach makeup effects and prosthetics for a living. I love The B52's, good sarcasm and boring things like history, science and Radio 4.
