Step 6Misc stuff about rivets
-since you only need the first 3/8 or less of a nail usually, buy them in the shortest size you can. you'll get more per pound that way.
-the large head on a roofing nail acts like a built in washer. that makes them good for riveting metal onto fabric, leather or plastic.
-duplex nails can be used for pins & posts.
-for most uses a 6d nail will work fine. but carriage bolts are handy if you ever need a rivet bigger than 1/4 inch.
-for articulating rivets use a holes a little larger than the rivet, use a washer under the end you are peening, and peen it over a rivet spacer. A rivet spacer is just a piece of pallet banding or something similar with a slot cut into the end. it makes sure that your rivet is loose enough to allow the pieces to articulate.
Thanks.
1) Take a rod of hardenable metal, the diameter of the final rivet head you want to make. Shape and polish to the form you want to end up with. (This need not be a simple spheroid - you can make something more decorative.) When finished, harden it by heating red-hot, then quenching. We will call this the forming positive, because it is the same shape as the rivet dome we want.
2) Take a larger-diameter rod of hardenable metal. Flatten one end, then fasten it in a metal vice with the flattened end protruding quite a bit. This will become the forming negative. Heat the end of the negative red-hot with a propane torch, then drive the forming positive into the end. You'll wind up with a hollow in your negative, the shape of the final rivet head.
3) Step 2 will push metal out to the side. (Think of the rim of a meteor crater.) File and smooth it down. Quench the forming positive to keep it hard. Heat the negative red-hot again, and hammer the positive in, in register with the last strike if you are making a decorative head. Repeat until satisfied. Polish.
4) Heat the negative red-hot, then quench to harden. Preserve the positive - you might find it convenient (if you are in a shared shop) to make several negatives. Then shaped rivets could become a trademark of sorts for your shop.
To use this tool, put the rivet through the metal as in this instructable. Then put the forming negative over the end of the rivet, and use it to beat out the rivet head into the shape you desire. Have the forming end of the negative rod hardened, but the end struck with the hammer should be a bit soft so the hammer won't bounce.
Masonry nails are excellent and affordable hardenable steel. I make all kinds of things with them: rivet formers, maker's-mark stamps, scratch awls, chasing tools, specialized chisels. They come in a range of sizes and shapes suited to a lot of jobs.
Some forms of knowledge are in your head; others are in your hands. I can rivet quite well, but all I know is in my hands. I can't tell people how to do it. Sorry.
Ellen
Please?
Pretty please?
With sugar on top?
Ellen
In any case, if they do need to be normalized or annealed you can strip off the galvanizing safely by soaking them overnight in a bucket of vinegar, or if you opt to burn off the galvanizing then just do it outside on a breezy day and you should be fine.
