loading
Step 2: Download the Wii iso to your usb device.
This next step explains how to load a Wii ISO to you usb device.
The first step is to get a Wii iso backup file. (I can't tell you where.)
Plug in your usb device in your computer . Click on the WBFS Manager 2.5 icon on your desktop. A new scree n will open. Use the drop-down tab under "Edit" in the upper left corner to choose your usb device drive letter.
(WARNING: Be very careful not to format your hard drive! Make sure you're drive number is right!)
Now click format to delete the contents on your USB device and change the format to WBFS.
(Note: You will not be able to use the USB drive only to store Wii isos because the computer operating system doesn't recognize the WBFS format).
After you're done formatting click the "Load button to load the contents of your USB device. It's empty.
Click the "Browse" button in the lower right corner to open a new window, locate your Wii ISO, click it, and click "Open" in the lower right corner.
It will take a few seconds to load. You should see it in the right half of the WBFS Manager window. Hover your mouse over it to see it's game cover.
Now click "Add to Device" to compress your Wii ISO and add it to your usb device.
It will take about 5 minutes to upload the file to a usb device.
After it's done, either close the program and take your usb device out of your computer and go to the next step, or add more games to your usb device.
<p>I am trying to format my usb on my mac and I format in ms dos fat and then load the wbfs files onto my usb and try and load onto usb loader but it doesnt seem to work. any ideas? </p>
<p>Can Gamecube isos be used?</p>
<p>Just download the Nintendont channel for homebrew and download iso's onto usb or hard drive</p>
<p>are you able to do this on a chromebook?? i only have a chromebook</p>
Does this work on SD card or does it have to be usb
<p>Not sure if anyone else has had this problem but i followed the instructions, however when i go to load USBLoadermodBrisma.wad - it doesn't appear in the available WAD packages. Can anyone help?</p>
I bought a modded wii on ebay. It came with all the retro games and 15 wii and gamcube games. Evrything loaded on a sd card. I am trying to play games from Usb but i cant figure out how to get usb loader to recognize the usb also instead of just the sd.<br>Please help
<p>Hi, in case you haven't got this sorted I had the same problem-I had the external drive in the wrong usb slot. It needs to be in the one closest to the edge of the wii. I have yet to get a thumb drive to work but my external hard drive works perfect now ;--)</p>
<p>the mega upload links are down can you reupload</p>
<p>So I did everything correctly, (As far as I can tell), I used USB Loader GX,</p><p>When I try starting up my ISO files it just somehow redirects me to the Homebrew channel. Help?</p>
<p>hi i dont know how to get iso file can anyone tell me how?</p>
Search on internet: (game name) wii iso
<p>He's right. You can get iso games from NicoBlog.com.</p>
<p>I am using usb loader gx. I followed all the steps perfectly. However, the channel does not recognise my usb drive. I'm using a 16GB Kingston Pendrive. What should i do? The whole thing used to run well when i used my hard disk.</p>
<p>wii only recognizes 2gb or less</p>
<p>actually it should work because i have a 500gb drive on my wii and have 220 games stored.</p>
<p>i cant find my files in wbfs please help me :(</p>
<p>If you have the iso file and need to convert it, Wii backup manager can convert it.</p><p><a href="http://www.wiibackupmanager.co.uk/" rel="nofollow">http://www.wiibackupmanager.co.uk/</a></p><p>Then on the root of the hdd make a folder wbfs and stick the game in there.</p>
<p>i did all of this just to realise the darn thing crashes upon startup...</p>
<p>I'm stuck on step 3; I couldn't download the <a href="http://www.megaupload.com/?d=TIP20JIM" rel="nofollow">rev 10 installer</a>, the link seems to not work. I tried other sites but I also couldn't download from them. I do have the latest version of it (cIOSX_rev21-Installer), though I don't know what to do. I tried to install it, but some attempts ended up failing and some left the Wii frozen. Do I have to install rev 10 or can I just load my backup games on USBLoader without installing it? Any detailed instructions would help.</p>
<p>i have installed it correctly and the HBC sees the games on the HDD, but if i open a game and click on play, i see a black screen and the wii freezes. I have to disconnect the power cable and reattach it.<br><br>Can anyone help me with this?</p>
<p>Yo, I hear the the WBFS manager has the option to download covers from the internet. This is not working... Am i supposed to use a .Png file? Or Something else?</p><p>I'm very confused...</p>
I get an error when I try to format the usb drive. Help?
<p>How do I get more games</p>
Thx so much I have been trying this and kept failing
Thats extremely good...
I'm new at this. I have my black Wii with 4.3U modded with Homebrew and am able to play games loaded onto a 16 gb USB Flash drive. I use WBFS Manager to load the games. I have loaded two games ISOs which are 4.5 GB no problem. But I have other ISOs the same size that will not load. I know the WBFS are partitioned. I had three games loaded and all three runs. Why do some load and others not?
I really want to be able to play free games but I have a couple questions before I do it...do i have to mod my system in order to play downloaded games? and if i do mod my system will i still be able to do everything i could before on it? such as play store bought games? please somebody help :(
Must I downgrade from 4.3u to get a USB Loader to work? Please can someone help me either way with a step-by-step tutorial.<br>
Does anyone want me to make a tutorial for the 4.3 wii or can you easily follow the website I posted in here previously...in this ible previously...
I hoping you have a tut and the links to download tools for installing the usb loader for 4.3u, this tutorial(which I have tried hoping it works) doesn't and gives my the blank screen and controller goes out of sync, when I try to run the IOS36-64. I have soft mod HBC 1.0.8 created through letterbomb method. and have had no other issues. I have used the HomeBrew Browser to download many appz some which also have an issue with the v4.3. Any help would be greatly appreciated
Can i have a tut for a 4.3e wii please. i am using wiiflow and have a 1gb usb stick i have a 8gb sd card with wiiware on and i am getting a 1tb hard drive to plug in to usb port 2 but i want a tutorial that tells me how i can run the wii system off the 1gb usb stick as i don't know how to transfer the data to the usb stick and get it to read from it .....please anyone can you help a noob
I made it :)<br><br>Here is the link :<br>https://www.instructables.com/id/Softmod-any-Wii-Version-10-43/<br><br>Hope you will like it
cheers for that :) <br>i dumped my nand on to the 1gb stick last night but it appears there are no gamesaves or channels on the dump. i want my 1gb stick to have to have channels and gamesaves on so when i boot up my wii it loads all my channels and gamesaves from the usb stick 1gb is ample for what i need.<br><br>the 1tb hard drive im buying will be for my wbfs game files, how many would i get on a 1tb about 200?<br><br>thanks again for your help
*Try comment on the ible coz others might have similar problems so they can solve it by the answers thanks :)*<br><br>In 1 TB hard drive about 350 games can fit, as I have a 500 GB hard drive and by using wii WBFS manager, I can fit about 200 games and it just depends on the game :)<br><br>Super smash bros takes 7.2 GB where as wii sports only takes 700 MB .<br><br>Using WBFS manager is good coz it scrubs the files before adding them to the dirve (Removing unwanted junk as publishers add extra junk to get the capacity to standard wii disk of 4.3 GB) and then it will add it to the disk which saves a lot of space :)<br><br>On my ible could you recommend me some good wii games like 10 -15 thx :)<br><br>
on a different matter my brother in law soft modded his wii but some reason priiloader enabled system updates so when his daughter put the wii on she accepted the disk update, the wii is not bricked, however neogamma no longer works and i don't think he has a back up nand. is it possible to fix?
OMG HELP <br>have been at this for 3 days now an keep getting stuck... <br><br>Am running Wii 4.3E &amp; 2TB external hard drive &amp; 2GB SD card <br>have already got the homebrew channel installed :)<br><br>am trying to install the usb loader....<br><br>i try an load the WAD Manager v1.3 (keep getting Error code RET = - 1029) :(<br><br>i try an load custom ios installer v1.7 (keep getting Error code RET = - 1017) :(<br><br>also when looked at USB Loader comes up <br>NO WBFS partition found need to format ( I already did this via my computer then formatted and then WBFS formatted) wii tries to partion an i get RET =-6<br><br><br>also after i have downloaded games from (Piratebay, wiiiso &amp; isohunt )<br>i extract them to WBFS an they still show as a winrar sysmbol but show as iso at the end and after using WBFS i look at my harddrive thru computer an it shows empty... <br><br>WHAT AM I DOING WRONG<br>HELP.... Kids r home on hoildays an driving me nuts <br><br>plzzzzzzzzzzzzzzz<br><br>
This doesn't work!!!<br>My screen goes black, for infinity hours, when i load the clos3610 thing, and with the WAD Manager!!!
I have used WBSFS to upload an iso file into my usb but it wont install in my wii. What else do I need to do? I already have homebrew installed.<br>ijaredguard
What do you use for it?! wiiflow or configurable usb loader or what?!
I use wii flow because I thought it was faster and more awesomer...<br>Now they have realeased a new softmod...its letterbomb, works for Wii version 4.3 and no game disk required!!!!
Letterbomb works great, but good luck getting wbfs games to run on 4.3
i have 4.3 and wbfs works fine in every way,just to let those who have 4.3 know my wii is a black one
How did you do it? With this guide? Can you please post info?
Here is the solution for 4.3 without game disk mate!<br><br>http://www.wiihacks.com/recommended-faqs-guides-tutorials-only/60921-guide-softmod-any-wii.html<br><br>In chapter 1 part 1 go to letterbomb!<br><br>AND IF YOU LIKE VIDEO TUTORIALS THEN GO ON YOUTUBE and type in letterbomb 4.3 wii<br><br>Hope it helps!
THANKS!!!!!!!!!!!!!! That tutorial worked perfectly! I downgraded to 4.1U and Configurable USBLoader worked great the first time!
Glad it helped! :)<br>
What I did was installed letterbomb then in the installation downgraded my Wii to 4.1, and then I could easily install WiiFlow and then I just download wbfs files and convert them into ISo files or just download ISO files and then use WBFS manager to put them on USB!
I keep running into the black freeze screen as well. I have no idea what else to do
About This Instructable
1,616,906views
281favorites
License:
More by Solderguy:How to extract Wii games to your computer using a usb stick. How to play Wii backups from a usb stick with no modchip. How to play Gamecube backups on your wii without a modchip.
Add instructable to:
