I ride a large cruiser motorcycle, and it has a Lexan brand windshield on it. I have researched online, and it turns out I can only find people who will polish and repair Acrylic windshields. They say Lexan windshields need to be replaced. Phooey to that.
A new windshield alone can run upwards of $200.
These days times are hard for all sort of people. Your 50 MPG motorcycle that costs $5 a month in insurance may just be your best bet to get around. There's no reason why you should have to drop more than $4 to get a clear, safe windshield.
A bottle of polish is under $4.
The windshield on my motorcycle is slightly yellowed from age, scratched up from the harsh desert environment where I live, *and* someone apprently had taped a sign to it at one point.
(NEVER tape a Lexan windshield, it removes the protective covering!)
I would have to look over the windshield, or around it, when I am offroad, to avoid rocks, ruts, etc. I couldn't see through it, and that is dangerous on a motorcycle.
Read on and see what I found out worked to make it clear again.
Remove these ads by
Signing UpStep 1Removing the windshield
My windshield is held onto a bracket by 4 bolts, two on each side.
Each bolt took a 12MM metric wrench. You cannot reach them with a socket, so grab an open end or box-end wrench.
http://meguiarsdirect.com/detail/MEG+G12310
Great job, thanks!
The bike I ride has a top and bottom windscreen that both are lookingrather ragged. I'll give this a try, probably using anold handheld electric shoe polisher I have.
I wonder if a mixture of baking soda and something else might work as apolishing compound. Any thoughts anyone?
Enjoy,
Liz
Every time I use the above method it comes out looking a little better.
Here's something you might find interesting:
I recently tried to polish a helmet visor (Scorpion).
I polished it many times with the No.4 polish but it was mediocreat best. So, I took some 1100 grit sandpaper and sanded the frontof it (Trust me when I say, the visor was unusable anyway, Ithought what the heck).
I proceeded to polish it like the above method after sanding (Thesanding left the visor barely translucent) and it is coming out GREAT.But, it has taken me at least 35 separate times to polish it.
I think if you have the motivation and time, you can make just about anyplastic clear again. It would be very interesting to see how baking soda(And water?) would polish the windshield.
Thanks! I'm going to give it a try. Thepolishing and all might happen over the winter though. Up here inVermont it's been snowing already. Although I might run awayfor a couple of months when it's slow in the winter, maybe ride to thesouthwest or something where it's warmer.
One thing I thought of when I was reading about you washing thewindscreens in the bathtub is that I've been putting mine in thedishwasher. Yep, silly maybe, but the two pieces come outspotless. I took the top drawer thingie, that the glasses go in,out of the dishwasher, so I had more height for the wind screens. Does that make sense?
I'll try the 1100 grit too.
Enjoy,
Liz
If I was you I would try the straight polish first.
Honestly, the sandpaper method is for plastic that is so far gone...I have invested much more than $30 in my time (The cost of thevisor) to make my visor usable, and I have no doubt you will bepolishing your windshield for a few weeks to get it so you can seethrough it again after the sandpaper.
I actually do not have $30 so it is worth it for me to have investedliterally 10 hours of polishing so far into my visor (My visor is 1/20ththe windshield, so it may take 100 hours of polishing to get mywindshield to this level of clear) to make it usable in these coldwinter days.
Plus, the visor isn't Lexan, I cannot say how sanding Lexan andthen polishing it 50+ separate times will make the windshield come out.
What I am trying to bring out here is that IF you use the sandpaperroute (I recommend a much finer grade, I just had 1100 at thetime) you MAY be on a MUCH more involved road to making it clearthan you are willing to endure. However, if you are snowed in for weeksat a time, by all means, go ahead!
You could sand a teeny tiny spot on the lower windshield and see howlong it takes to make it the level of clear you want.
However, the dishwasher idea is fantastic, because you are almostguaranteed to getting the bugs off. I almost wish I had adishwasher for this purpose. Well done! :)
I think I'll stick to using your method of polishing the windscreen. It's really not that bad that I'd want to take onthe task of sanding it. I might try polishing my faceshield too.
Cool that you like the dishwasher idea. Someone oncetold me a good way to get the bugs off is using hydrogenperoxide. They said it literally eats the bug up, like itdoes when it bubbles in a dirty cut.
Enjoy,
Liz
