How to Prevent Rust on Your Car
216,688
47
25
Posted
Introduction: How to Prevent Rust on Your Car
Keeping your car rust-free prevents serious damage and maintains the look and value of your car. If you choose to try us, Jig-a-loo, as part of your car maintenance routine, you can find out where to pick up a can here: http://www.jigaloo.com/us/e_store_locator.php. Here are 6 detailed steps and a few extra tricks for preventing rust on your car.
Step 1: General Maintenance
a. Wash your car every two weeks; once a week if it is wet with salt on the roads.
b. Wax your car once every four months.
c. Keep the inside clean as well, being sure to clean up after any spills which can start rust from the inside.
Step 2: Take Extra Care Around Salt
a. Salt speeds rust, so be careful to keep your car clean if you live by the ocean or in the winter when there's salt on the road.
b. Clean the underside of your car and your wheel wells when filthy or at least once a week during the winter when salt is out.
c. If your car is seriously at risk for rust because of regularly exposure to salt, etc. you can clean it and then spray it with a lubricant appropriate for cars (we recommend Jig-a-loo, of course!) or even paint it with a proper coating for the surface (this should be done by a professional).
Step 3: Rust Coating!
a. If you are in a very salty climate or are already fending off rust problems, you may want to consider coating your car with a rust-preventing spray (like Jig-a-loo)
b. Key is to keep metal surfaces dry- whether you wipe them off after use, or protect them with paint, lacquer, lubricant or wax.
c. If you are going to spray your car with anything flammable. make sure the engine is cold and give it some time for the vapors to clear up before you fire it up again. Try to avoid spraying on your exhaust or mufflers so they don't get to smelly when hot.
Step 4: The Extra Steps
a. Before any long periods on inactivity, wash and spray down a rust-preventing spray.
b. Drive further behind other vehicles to prevent knicks from pebbles they kick up.
c. Cover your car with a car cover whenever possible.
Step 5: Inspect Regularly!
a. Examine your car for rust often. External painted parts will show rust when the paint bubbles or blisters up. On other metal parts, just look for the beginnings of rust.
b. There are 3 areas to look for rust: the engine and trunk, the undercarriage of the car and the external painted parts.
Step 6: The Worst Case Scenario- If You Do Get Rust Anyhow
a. Fix small problems in the paintwork quickly.
b. If you have existing rust on the underside of your car, you will need to remove it. There are sprays that do this.
c. Treat any rust that pops up immediately and aggressively.
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
24 Comments
If my car had this many rust spots I'd just get rid of it. However, my car only has one small but noticeable rust mark. I would like to prevent anymore from happening. It's good to know that general maintenance usually does a good job at preventing it, thanks. http://www.valugard.net
I wouldn't use any solvent based silicone on anything I wanted to keep. The silicone itself, once the solvents or carriers are dissolved, remains pretty much forever. Your paint is water proof. The e-coat and primer under the paint and the galvanizing usually used on modern steel bodies also prevents rust. Once all of these are chipped or scratched through, there's nothing protecting the bare steel, then you get rust. Hydrocarbon solvent carriers for silicone will accelerate dry rot and won't prevent rust from forming on bare steel.
If you put Jigaloo or Armor-All or Rain-Ex on a car, don't expect to repair the car's paint if it gets damaged. Silicone pretty much repels everything, and silicone can't be removed by solvents since the bonds require very high temperatures to break. So if you get in an accident and need to repaint a panel of your car's body, it will be very difficult to get the paint to stick. Cheap magic car treatments are usually not very well researched and do more harm than good.
Natural wax is the only thing that should go on your car's paint.
plastic won't rust! yeeee!
My dad's Mercedes rusted more in the last 11 years than my Alfa Romeo in 22.
POR-15 works better, its rust preventative PAINT...
These steps will not prevent rust, they will only slow down the process. This instructable seems like a shameless plug for the jig a loo product which is not a "rust-preventing spray" regardless of whether they market it that way.
You would have to spray it on displacing all water immediately, every time the car got wet, and that would be very costly and exposure to the ingredients bad for health. Any bare metal areas where rust would be a problem should be painted, and silicone sprays like jig a loo should NOT be used because they are difficult to completely clean off so the paint will adhere well.
would WD-40 work? random thought.
WD won't hurt, but it washes off/dries out after awhile. Boeing makes Boeshield T9, a spray that comes out liquid, penetrates, then turns into a waxy solid. Works real well, not cheap. Sprayon makes PDRP Waxy Film Protectant that seems identical but much cheaper. I've used both with success. You can even spray them into electrical connectors to keep them from corroding/oxidizing.
