3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to prevent thefts steal your motorcycle for less than US$ 2
This is my first Instructable. It will teach you to how to install a secret interrupter in your motorcycle and prevent the engine to start without your knowledge.
It can be useful to prevent theft to steal your motorcycle. It works as an additional lock system.
Here in Brazil, it's very useful.
The principle is simple: The Engine need the Ignition coil work to make the Spark Plug to Work and make possible the engine to run... All we will do is to create a way to disable the Ignition coil and, by consequence, disable all the Engine.
NOTE: This instructable is available in Brazilian Portuguese in my Blog.
Step 1Materials and Tools
Materials and Tools
You will need:
- Some Tools (The tools that come with the motorcycle can do the service well)
- 1~2 meters of double wire
- An Small Interrupter (black or other Dark color if possible)
- A Cutting Tool
- Electric Tape
Most motorcycles come with basic tools, that can be very helpful in an emergency situation. These tools can handle this job, but if you have better tools to work, use them.
The wires will be connected to the interrupter and to the Ignition coil of the Motorcycle.
The Cutting tool is necessary to cut the wires and the Electric tape to isolate them.
70 comments
1-40 of 70next »
Jun 3, 2009. 11:50 AMMadrias357 says:
Worked great for dad's car. As if being stickshift wasn't bad enough (clutch down to start it) you had to flip the switch hidden in the ash tray. Otherwise, it won't start.
Mar 27, 2011. 3:35 AMMa77h3w says:
A "stickshift" isn't normally started with the clutch down..
Feb 17, 2012. 2:27 AMgraydog111 says:
I must have the clutch depressed to start my GMC stickshift PU.
Feb 16, 2012. 2:38 PMlperkins says:
It's not necessary unless the vehicle has some kind of safety interlock. However, disengaging the clutch before starting does slightly decrease the wear on your starter motor since it doesn't have to turn any of the transmission beyond the clutch. Whether or not this is significant depends on the vehicle.
Feb 16, 2012. 1:15 PMcriggie says:
Like everything, it depends. Modern cars have all sorts of electronic jiggery pokery to force the driver to do things in a certain way.
Mine's a late 60's holden (GM to americans) and it starts better in neutral with the clutch out (connected), because the weight of the flywheel helps keep the gubbons turning over.
You can still start it perfectly well with the clutch in (separated) but its easier on the motor the other way.
"Stick" is a silly word... here we refer to them as manual or automatic.
An automatic transmission generally still has a gearstick... I've never seen a pushbutton automatic outside of a Bus, but google says Chrysler made them for cars.
Apr 18, 2011. 6:37 PMJJrulz says:
Uhm. Do you drive? Because I think youll find you cannot start a stickshift/manual car unless the clutch is in. Not only is it not abnormal, its the only way possible
Dec 22, 2011. 9:21 AMlalunette says:
Modern manual cars have a sensor that forces you to completely depress the clutch pedal or the starter won't get power to crank the engine.
The 2011 Chevrolet Spark I drove in France this past summer and my '91 Honda Civic wagon had this feature... my '91 Lada wagon doesn't.
Cheers !!
Jul 21, 2011. 9:50 AMMa77h3w says:
You can start the car with the clutch down, but normally you put it in neutral is what I meant
Jul 21, 2011. 5:12 AMbpfh says:
Never heard of this feature on a manual. Ever. You either put it into neutral, or get a big jerk when you turn the key on every manual I've been in.
What make/model has this feature?
Aug 12, 2011. 6:56 AMjsgraham says:
All vehicles manufactured for use in the United States after 1990 were required to have a switch to lock out ignition of the vehicle, unless the clutch was fully depressed. I had a 1984 Honda Prelude with a 5-speed manual transmission. It had lock out switch on the clutch. But then again, Honda is known to implement safety features that most manufacturers don't do until forced to by the Federal DOT.
Now, that's not to say that the switch hasn't been bypassed. People do that, and there are videos on YouTube that show how to do it.
Sep 27, 2011. 2:49 AMbpfh says:
I did not know about this. Ok, on an auto, yes, you cannot do anything to the car unless you are in "N", but here in Europe, where most cars are manual, you have no sort of cut out like this...
Cheers,
Daniel
May 28, 2011. 1:20 PMttibbenham says:
Some 'stick shift' cars have a 'brake applied or clutch down' "safety feature" which prevents the engine starting while a gear is engaged: I own one at the moment.
I have also driven lots of 'stick shift' cars without this feature so whether you need 'clutch down' to start just depends on which car you have.
Dec 22, 2011. 8:05 AMHammerhead46 says:
A lot of automatics are now making you put the brake on to move the shift lever to a forward or reverse gear.
LONG overdue.
May 25, 2011. 6:11 PMGtrPngn says:
anyone who has driven and understands how a manual transmission car works would know that it can be started both clutch in or just in neutral.
Apr 22, 2009. 6:47 PMxfirexstarzx says:
I did something like this a few years ago to my moped, because it didn't have a keyed switch. I used a reed switch and soldered it in parallel with my ignition switch. I stuck it in the headlight, so it wasn't noticable, and had a chrome rare earth magnet to make the switch open because my kill switch needs to be open in order for the bike to run. The chrome magnet blended in with the chrome headlight. When you get off the bike, just pull the magnet and the bike won't start.
Feb 16, 2012. 9:01 AMToolboxGuy says:
I *LIKE* IT!
Even if you drop or lose your magnet, you can leave yourself a spare just about anywhere on the bike (or car) for that matter - even use an EMPTY spare key box's magnet as the spare!
Now all we need is a micro cell phone+GPS to get powered up and autodial you should someone attempt to start the vehicle without said switch in place!
Since I drive a minivan and a Subaru Forester, my cars are not nearly as big of a target as the BMWs and Mercedes Benz making up 40% of the vehicles in the parking lot at work.
Feb 1, 2012. 3:07 AM7070x says:
I ve seen this 'hidden safety switch" trick. But frankly, for less than $2 I guess I would :
* get a medium duty lock.
* put the lock leg in between chain-eyes. Bike can not and will not roll.
* dont lose the key
I live in a region where bikes are stolen at least 5 units every single day. Most of them are already booked/logged, meaning the preps have a laundry list of "would-be-stolen-bikes" based on model, year, and MSRP. Ironically, many of these stolen bikes are being sold in the black market for parts down to nuts and bolts. Common methods are using fake/duplicated keys, T-shape smart tool, re-wiring etc all done within minutes. I had once ran on two blokes pulling a stolen bike by hand. So, when you're bike can roll without could not even start, it stil is steal-able. (is this is even a word?!)
Feb 15, 2012. 1:06 AMpro5200 says:
you are right, I agree with you, but it just slow down a thief.
in my place at least there is two popular ways is quite effective in preventing theft:
1. using the padlock, sometimes also coupled with the large chain LOL :D
2. If your have motorcycle with conventional ignition key, replacing the original ignition key, with the key form of nazi or E form, or replace the ignition key with smart key shutter
Feb 9, 2012. 8:40 PMabadon says:
I use heavy high carbon steel chain and a high grade padlock i keep in my backpack whenever I park my machine. The padlock's shackle and the chain is too large for most ordinary bolt cutters and the high carbon steel in the padlock shackle and chain links really slows down grinders and saws.
Jun 3, 2011. 2:20 PMTSC says:
Just take the spark plug out then stick it in you pocket then when you come back just put it back in and start it up!
Feb 8, 2012. 11:16 PMpro5200 says:
i think a simple & better way, you can deceive theft with unplug your main fuse & replace with a dead fuse as a camouflage...
Feb 9, 2012. 8:47 AMTSC says:
hahaha
Jan 30, 2012. 2:27 PMSecondTime says:
The Yamaha YZF series (and the Suzuki GSXR series and most other thing I've owned) has the spark plugs under the tank. I would expect to spend 2 hours or so changing the spark plugs on a supersports. You can't just whip them out when you park up.
Feb 1, 2012. 5:09 PMTSC says:
Yeah well I know alot more about engines and stuff now and I'm starting to think that was not such a smart Idea!
Nov 1, 2011. 3:27 PMdarkstar$ says:
you might get water in the motor
Nov 1, 2011. 5:02 PMTSC says:
True but you could put a rag or something in it then when you come back just take it out then put the spark pulg back in.
Sep 18, 2011. 10:37 AMGingerMonkey says:
Although that would work, opening up the cylinder to crud getting in is probably not a good idea for the engine. Plus, my scoot's spark plug is miserable to get at.
May 30, 2011. 10:35 PMnin99 says:
First off, Great tutorial!
I was thinking of this same concept for a car. Interrupt the battery-to-starter wire. Same concept.
Jan 2, 2012. 10:31 AMac-dc says:
It's not the same concept, practically speaking even if technically possible. The battery to starter wire is very heavy gauge to carry hundreds of amps current. It would require a relatively huge switch and wire to do it.
There is going to be a wire between the ECM and ICM or ICM and ignition coil pack that you could put the switch on instead. That's the equivalent of what this instructable did to the motorcycle.
Oct 27, 2011. 10:34 PMcdonnally says:
you could always just remove your spark plug cable. I used to travel a lot and I would put a padlock through the disc brake.
Aug 15, 2011. 11:20 AMMisterInnovation says:
around here that wont stop someone from stealing your bike. Here they drive up in a van, four guys pick your bike up and throw it in, close the door and they are gone.
Sep 8, 2011. 11:37 AMwolvmarine says:
Yep that's how they did me. I live in a quiet dead end neighborhood too. My wife of the time was at home and they stole her from right in front of the house. While I was at work. Now my bike is gone and the wife has been Ex'd ; <
Aug 15, 2011. 11:33 AMMisterInnovation says:
the easiest way to prevent it is to put a Lo-Jack gps locator "24 hour recovery, guaranteed" sticker on the gas tank. It's not worth the risk to steal a motorcycle with a gps tracker on it.
Aug 6, 2011. 9:37 AMabadfart says:
if you put it on the battery then you could use it to disconnect the batter when your bike going in to storage
Jun 27, 2011. 9:54 PMrreinert says:
This doesn't really prevent someone from stealing your bike, unless their plan to steal it was to ride it away. This prevents unauthorized persons from STARTING your bike... But someone could still roll up in a truck or a van, and throw your bike in and be gone....
The best way to prevent theft is still the good 'old fashioned lock and chain!
May 25, 2011. 7:11 AMMankut says:
I followed your instructions on my Yamaha SR400, but I started having problems starting the bike afterwards. It eventually starts after 5mins of kicking...
After asking for help on another forum I got this response:
"You have probably partially destroyed the capacitor in the CDi box.
If you dis-connect the feed to the coil while the engine is running the capacitor has no where to discharge to - but is still being charged. Basically the voltage builds until the capacitor's insulation starts to break down. Once that happens its good bye CDi unit.
The only way to shut off the ignition is to kill the voltage that charges the capacitor - this is what the kill switch does when the black/white wire is shorted to the frame."
I'm no expert regarding electrics, but something's definitely not right here.
Be careful
May 8, 2011. 6:54 PMmrcurlywhirly says:
Did you think of putting a quick release bolt on the gearshift spline? just stick the gear lever in your pocket!
Pretty hard to go anywhere in neutral.
Seriously, i think the cutout is a good, cheap solution, but doesnt stop the bike from being rolled up a ramp into a ute. Maybe you could combine the cutout with a mercury tilt switch that earths the horn, that way if its moved off its sidestand (or centrestand if you have one) it will alarm.
Mar 21, 2011. 11:12 AMGsE-Lance says:
Nice job, now you have to find out a way to stop them terrorising them :S
Oct 4, 2010. 12:21 PMbynternet says:
nice.
keep 'em coming!
Jul 18, 2010. 6:29 PMcromas says:
What would happen if the switch were to be toggled while the bike was running/in-motion? Would it seize up dangerously, or just slow down quickly, similar to running out of gas?
1-40 of 70next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:Shadow Brujah
A motorbike rider who loves all about motorcycles and technology.
