Step 2Making the mega-isp programmer on a breadboard
You can plug your avr chip to a breadboard and connect 5v and GND to the respective pins (check the datasheet!) + a pullup resistor to reset and wire pins from you arduino to the chip.
These are the lines on Arduino and their function
13 - SCK
12 - MISO
11 - MOSI
10 - RST (Reset)
Or you can make a 2x3pin ISP header that you can plug into a board that provides one (another arduino board).
The pinout for the ISP header is on the third image
There are 3 leds to indicate the status of the programmer.
pin 9 - blue led - its the hearbeat of the programmer.
pin 8 - red led - indicates an error
pin 7 - green led - indicates that the programming is taking place
(i was lazy so i didn't match the colors in my setup)
Here are the drawings made in Fritzing
You can alsa make a MEGA-isp shield. Yaroslav Osadchyy designed the shield in eagle. You can get the eagle files on his site: http://drug123.org.ua/mega-isp-shield/
First of all: Great project :-)
You said, all we need is the chip, 3 leds and 3 resistors (and the arduino of course).
I understand the additional 10kΩ resistor to prevent the chip of resetting, but what are the two capacitors at pin 9 and 10 for? Can I omit them? If I need them, what value should I use for the capacitors?
Bye from Bavaria :-)
Thanks.
the two capacitors are 22p for the crystal oscilator. it will probably work without them but its a good design to include them. You do need the 16mhz oscilator if you're going to program the chip on a breadboard.
If you have a Ceramic oscillator (this one has 3 legs) you don't need them cause ceramic oscilator has them built in.
the 16mhz oscilator (with the 22p caps) and reset resistor is used on the second soon-to-be arduino (Its the minimal number of needed components on an arduino)
Because I get my oscillators not until friday, I tried without the caps and clock crystal, but when I try to test my attiny2313 with avrdude the heartbeat-led freezes and I get an "The programmer is not responding"-error. Same with attiny45 and atmega168...
Do all of the atmel chips (esp: attiny2313 and attiny25/45/85) work with an 16MHz oscillator?
HTH
On the Fritzing-Graphic the Reset-Pin of the ic is connected (over the 10kΩ) to the ground -> the chip is nonstop resetting... Instead it should be pulled high to to the 5V, shouldn't it?
Well I will test it tomorrow and give feedback...
cya
I'll update the drawings when ill be back home
Well I couldn't wait until tomorrow and gues what: I was right :-)! just connect the 10kΩ resistor to 5V instead of ground and everything is working fine!
But thanks to this mistake I learned myself a lot by reading all arduino sites in the web to solve the error ;-)
