Step 6Burning the Arduino bootloader
I cheated a bit cause i used a RBBB to simplify the connections. The schema is on picture #2.
If you use 2 arduinos use the picture #3 and connect the ISP pin to the ICSP 2x3header on the second(slave) arduino.Only connect the usb power to the first board.
The GUI way
This is a little tricky cause you can't just use Tools-> Burn Bootloader -> w/ AVR ISP cause the default speed is too big for mega-isp.
Find avrdude.conf that comes with arduino IDE (in arduino/hardware/tools/avrdude.conf) and change the boundrate for avrisp programmer from 115200 to 19200 (around line 312 )
Find and change in avrdude.conf
programmer
id = "avrisp";
desc = "Atmel AVR ISP";
baudrate = 115200; # default is 115200
type = stk500;
to:
programmer
id = "avrisp";
baudrate = 19200; # default is 115200
type = stk500;
Now you can use Tools-> Burn Bootloader -> w/ AVR ISP (after you select the proper board from the Tools menu)
Commanline
You can also use the commandline:
Edit arduino/hardware/bootloaders/atmega/Makefile
and change ISPTOOL/PORT/SPEED to:
# enter the parameters for the avrdude isp tool
ISPTOOL = avrisp
ISPPORT = /dev/ttyUSB0
ISPSPEED = -b 19200
no you can write
$ make diecimila_isp
to burn fuses and the bootloader.
Test
Now connect you new arduino to usb and burn the blinky!
Add Comment
