3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to purify water in the wild with 2 water bottles.
This is a entry to the "Keep the bottle" contest. Please take the time to vote if you think my instuctable is worth me getting a prize. I would really enjoy the prize, so please vote.
In this instructable, I will show you how to purify abit of water when you are in the wild and trying to survive with 2 water bottles.
Step 1Things you need
Things you need
You need 2 water bottles. (If you find any in the wild)
Some duct tape or masking tape ( always carry some in any kind of outdoor trip)
Some dirty water or urine (really!)
Alot of sunlight
32 comments
Jan 19, 2009. 5:15 PMjeff-o says:
How do you clean the bottle that you drink from?
Jan 25, 2009. 7:12 AMClanky says:
Heating a bottle over a fire will melt the bottle before the usual bacteria are roasted. Also, if you have a bottle that can resist enough heat to kill bacteria, why not just put water in there and boil it? Much faster than waiting for the sun to evaporate it.
Feb 6, 2010. 11:47 PMLight_Lab says:
Actually most bacteria are destroyed at lower temperatures than required to melt a PET bottle (270C) or even distort it (~80C) in fact they use thick PET milk bottles in Germany and heat sterilize them - same for some baby bottles. Even the UV in sunlight will kill some bacteria.
Nevertheless the point made elsewhere that if you have a source of heat to evaporate the water is a valid one, much quicker than the Sun. I think though that if you were dying of thirst you would risk a few of someones bacteria. (Probably safer than a kiss.) Or you could discard the first collection.
What worries me is why the water would selectively condense in the clean bottle. The primary bottle would always be cooler because of evaporation. I would cover the contaminated bottle with something black and cover the clean bottle with a wet cloth or wet soil (wet with contaminated water would do). In the wind this would evaporate and cool the clean bottle.
A tried and true trick is to cover a small container of dirty water standing in a bowl with a closed cylinder cut from a plastic bottle. Standing in the sun; the water condenses on the plastic and runs down into the bowl. This can be tuned with bits of damp cloth to be quite efficient.  Except for the bowl you can make this all from one 2 liter bottle.  Obviously several of these would be required to keep a person alive.
Nov 3, 2011. 1:15 PMscreeching crow says:
the water condenses in both it just evens out, and you can slightly tilt the bottle to collect more evaporation
May 8, 2009. 2:41 AMtheRIAA says:
May 8, 2009. 3:43 AMjeff-o says:
Cooooool! I shall remember that trick, and will amaze my friends with it the next time we go camping.
Feb 22, 2009. 9:16 PMbowhunterhall says:
i know how to start fires and i have a flint...
Jan 25, 2009. 11:47 AMClanky says:
Well, seeing as I am in a Scouting group... I was just commenting on your previous comment about using a fire to sterilize the bottle. Since a person is using fire to sterilize the bottle, I just assumed he or she had fire to boil water with.
Aug 5, 2010. 8:04 AMracopa says:
Hello A simple variant would paste the two plugs for the outside and then make a hole. Greetings from Spain
Jun 29, 2010. 2:10 PMmaxman says:
I really like this instructable. Short, and to the point. It's one of those things I'll file away in the back of my mind for some day.
May 16, 2010. 12:35 AMLoserima says:
this design could be improved upon if you found a tube to connect the bottles or if you were mtn biking/ backpacking use the camelback tube and go strait to the bladder. also mirrors/foil/metal/cut open pop cans (you get the picture) could help direct sunlight at the bottle.
Mar 12, 2010. 8:39 AMcrajakum says:
Put some foil in an arch under the dirty water bottle to focus the sun's rays.  This'll help the evaporation rate.
May 23, 2009. 5:23 AMmikaelthemycologist says:
I would put a handkerchief or something so that the clean water bottle is in the shade. This will help prevent re-evaporation.
May 21, 2009. 5:51 PMmikaelthemycologist says:
I LOVE YOU!!!!! Ive been trying to figure out how to make a simple still in the wild without the plastic sheeting that everyone says to use or without the use of a T-shirt or sweater!!!!!! YES!!!! VICTORY!!!! I Wish that I could still vote for you (its to late) YES!!!!!!!
Feb 2, 2009. 7:44 PMandy221 says:
good one
Feb 2, 2009. 7:40 PM3232123 says:
i tried it ..and it worked!!!XD
Jan 31, 2009. 9:08 PMA good name says:
I liked it. 4 stars cause it was a bit short.
Jan 29, 2009. 3:11 PMtrike road poet says:
lay a rag or something over the empty bottle and the lower temp. will increase the condensing action and shorten the time of distillation.
Jan 25, 2009. 10:38 AMikenovak says:
yea idk if the water would condensate on the "clean" water bottle or very much at all. Its possible that some of the water would travel to the other bottle but traditionally distillation works because it evaporates upward and through some sort of tube to a cooling element where it collects. Your method doesnt provide any cooling for the water to convert to liquid form and there is no logical reason for the evaporated water to prefer the other bottle. good try but needs some refining
Jan 22, 2009. 6:40 PMBrowncoat says:
Why would it collect in the other bottle instead of just in the original bottle?
Jan 23, 2009. 10:39 AMBrowncoat says:
Wow, rude much? Did you not notice "We have a 'be nice' comment policy"? Anyway, yes, gas rises, but you show both bottles being level, so how does gas rising help it collect into the clean bottle? If anything, I'd think it'd be more likely to condense in the dirty bottle because there are already so many water molecules for the gas molecules to attach themselves to...
Jan 21, 2009. 7:36 PMfun bun says:
good one. =)
Jan 21, 2009. 7:32 PMiddqd221 says:
wow! This is a great way for surviving! Great instuctable!!!
Jan 20, 2009. 2:59 AMbruc33ef says:
Good job! This is the well-known "solar still" method, but using PET bottles is a useful idea when plastic bags or sheeting isn't available. And, if you don't have a source of even dirty water, you could stuff leaves and other vegetation in a bottle, screw the cap on, leave the bottle out in the sun upside-down, and the moisture from the leaves will evaporate and condense into water at the neck of the bottle. Then just unscrew the cap and drink.
Jan 20, 2009. 3:28 AMPKM says:
As this works much better when the clean bottle is cold, I would leave the bottle with the dirty water in the sun but bury the clean end bottle under a small mound of soil or something to keep it cool. This is pretty much the simplest take on the solar still I've seen, good work.
Jan 19, 2009. 4:34 PM21GeeOff21 says:
you could also run your dirty water through some sort of cloth and into your bottle aand if you can get a fire going you can actually boil the water in the bottle as long as the flames only barely touch where the water is but if you cant get yourself a fire i suppose this would work
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:dkfa
I'm in Highschool. =] Love paintball. Old Instructables member. Have been featured on the homepage and most viewed award. =]
