You could just boil the water but this would n't get sand and other particles out of the water and the chemicals will also remain in the water after cooking it. Which in turn could affect your health.
So the best way to purify your water is to use a filter.
Often you can build a water filter with the resources you have available, this gets the particules, dirt and some of the chemicals out of the water.
It is wise to boil the water after you filtered it so that all bacteria and viruses are killed.
Step 1: The Filter
and put the following materials in the bottle.
- pebbles
- Sand
- a piece of cloth or bandages
- charcoal
- Sand
- pebbles
The cloth or bandages are used to ensure that all the different materials do not mix.
The pebbels and sand filter the particules and the dirt out of the water.
The charcoal gets a big portion of the chemicals out of the water, but it won't get it all out. (You can use charcoal from your campfire).
This filter will not remove any viruses and bacteria from the water so you have to boil the water after it is filtered.
Step 2: How to use your filter
Pour the water from the pool or pond in top of your water filter, catch the water at the bottom of the filter in a clean cup.
it is best to throw away the first bit of water that comes out of your filter it often is cloudy and not that clean.
If the water that comes out of your filter is clear it is good and you can use it.
Boil the water at least 1 minute before drinking it, cooking will kill bacteria and viruses that are still present in your water.
If you put some spruce needles in the boiling water, you'll also have a tasty tea.
Visit Our Store »
Go Pro Today »
so thanks for the tips :)
Sometimes our city water stinks and taste's like Chlorine and is almost impossible to drink.
I've had to add Hydrogen Peroxide to my water just to get it down. Boiling it did not help much...I plan on making a filter like this one but using a 5 gallon bucket. instead. ALSO.. I am thinking of pouring something through it FIRST to kill any bacteria that may be living in the filter...Since our water is safe to drink I do not want to add bacteria to my end product in the filtering process.. I would think a small amount of house hold bleach poured through the filter then flushed out with fresh tap water may work but to much at one time may soak into the charcoal and ruin it's effectiveness.. Does anyone have a better idea ?. Also IF I make a filter how often should I need to toss the sand and charcoal out and replace it with fresh..? Can you go by taste ? OR is there a tell tell by looks ?
In your case it can help to vaporize your water and than condence it again.
When you boil salt water the salt in the water won't evaporate and you can get rid of the salty tast, but as you can imagine this is a intensive way of cleaning your water and i don't know if it wil get rid of calcium.
Thanks for your reply, much appreciated.
T
Cedar tea will stave off scurvy.
Not a bad article.
A coffee filter can filter out debris nicely.
A good source for activated charcoal is aquarium filters.
How to make Activated Charcoal would be good also.
Take wood, paper, or bone, you can even use nutshells or corn husks.
Seal it in an airtight container.
A glass jar with a tin lid will enable you to watch as the material changes to activated charcoal.
Poke a vent hole in the lid and heat over a fire.
The smoke and hot gasses will escape out the vent hole leaving behind the activated charcoal.
Let cool slowly if you use a glass jar or the glass may shatter.
Activated charcoal used for filters is burned in a container that does not allow air into the container to contaminate the carbon with carbon dioxide or other contaminants. It is pure carbon for a better term.
Activated charcoal used for filters, absorb carbon dioxide and other contaminants, this wont happen if it is already contaminated.
it is true that charcoal and all that would be a lot better if you did not heat the water as it would remove some chemicals whereas the wire mesh would not. But when you boil the water you are removing the chemicals and killing the germs anyway.
