How to Put a 4x4 Rubik's Cube Together
40,280
Published
Introduction: How to Put a 4x4 Rubik's Cube Together
Did your 4x4 fall apart, mine did! Here's how to put it back together.
Note: the 4 different types of pieces are the centers, Right edges, Left edges, and corners.
Step 1: White Centers
This step is a bit tricky, because the centers fall out easily. Put the corner of the hook in the center, see pictures.
Step 2: White Edges and Corners
Now put the pieces back in as shown.
Step 3: Second Layer
Follow the pictures to put together the second layer.
Step 4: Third Layer
Follow the pictures. Put the other edges in after you put the centers in.
Step 5: Fourth Layer
Follow the pictures to finish the cube! When you put these edges in, put a portion all the way in, and snap the other side in.
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    2 Comments
    My 4x4 core has square panels with inserts instead of triangles. Any suggestions on how to reassemble it?
    Thank you! I've found the 4x4 is far more prone to falling apart than the 3x3, but that is expected due to the size
