How to Put a Custom Image on Your Xbox 360 Dashboard.(Pre Fall 08 Update)
14,580
Posted
Introduction: How to Put a Custom Image on Your Xbox 360 Dashboard.(Pre Fall 08 Update)
In this instructable im going to show you how to put a custom image as your background on your xbox 360.
there are the same steps for doing this with the new and old dashboard. when i get a chance i will update the whole thing with new pictures.
Step 1: What You Need
To do this instructable you will need a few things:
a usb memory device
computer
xbox 360
an image
Step 2: The Image
You should have an image that will fit over the whole dashboard.
A 7X7 inch picture will fill the whole main dashboard but will not fill whole menus like your videos list.
To make the picture cover every thing I would use a 10X7 inch picture.
Step 3: Format
When you save your picture to your usb device as a JPEG. JPEG is the only format i found that works well.
Step 4: Plug It in Plug It In
Plug you usb device in to your xbox. Not hard stuff here.
Step 5: Media Blade
Go to the media blade then pictures.
Step 6: Saving
press A on pictures then chose portable device. Hilight the picture you want and press Y.
Step 7: Are You Sure?
This will set the picture as the background. Are you sure you want to use this picture?
To change the background later, open xbox guide, select personal settings, and select themes.
Yes use this picture.
Step 8: Done
there you go your done. The picture applies to every blade except the guide blades and the marketplace blade.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Gluten Free Challenge
13 Comments
You can still do this after the update. All you do is put in a CD with pictures on it and go to the pictures tab, select the picture and select set as background.
i know it still works i just had pre 08 update because i did not know if how you do it would change im working on updating this instructable
you can also do with an Ipod it works the same
does the ipod have to be set up for disk use?
no it should already be set up just follow the same step on here
when does the update come out?
november 13
ok i was off by a bit glad its sooner cant wait to play with the avitar creator.
i think november 21 but i dont remember i know its late november
