3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to re-key a door knob
Have you ever given someone a key to something but then later on decided it wasn't such a good idea and you fear that they have copied it, I recently had that problem. There are plenty of lock smiths that will re-key a lock for a fee or you could go out and buy a new door knob. I was running low on cash and decided to take the knob apart and see if there was a way to change the pins (and my key) in a way that the original key wouldn't work. This is my first instructable and is based on what I did. But first, I am NOT responsible for any damage you do to your door knob.
Step 1Remove the knob
Remove the knob
My door knob has a small hole between the part that rotates and the part that attaches to the door (refer to picture). All door knobs can be taken apart, yours will probably be different than the picture. When the door knob is turned the correct way there is a button that can be pushed to release the knob. Remove the knob but remember how it came off.
13 comments
May 18, 2012. 12:56 PMlostkano says:
I'm a locksmith and I credit you with being intelligent enough to figure this out and not loosing parts.
Mar 16, 2009. 10:42 AMw2sqr says:
Home Depot & Lowes sell re-keying kits for about $10 that allow you to
re-key about 6 locks to the new key in the kit. I keep all the old keys and
pins from the old locks and can now re-key just about any lock I find.
Try looking at http://changealock.com/
Will
Jul 17, 2011. 12:22 PMdll932 says:
Good luck if you run into a Sargent commercial grade knob or a WeiserBolt. :) Corbin/Russwin knobs aren't real fun either. Don't even TRY this with a Medeco or other high-security lock.
May 1, 2011. 3:25 PMstuuf says:
looks like one of those cheap mountain security knobs... i bought one the other day to play around with but couldn't figure out how to take it apart. i guess i was expecting too much from a $9 walmart lockset to think of pulling the cylinder by shoving a screwdriver in the SECURE side knob.
May 3, 2011. 8:18 PMstuuf says:
insecure side i meant obviously...
Aug 3, 2010. 6:50 PMsturmey says:
not all door knobs are removed this way.
This didn't really help for my door knob.
Jun 16, 2009. 10:35 AMA.C.E. says:
i have an older kwikset lock but i cant figure out how to get the thing that spins to lock the door out so i can remove the tube.. any ideas?
Jun 18, 2009. 7:36 PMjpoarch says:
See this link. (http://www.kwikset.com/Trade/Literature/default.aspx). Look for the "Rekeying Manual".
Mar 17, 2009. 11:35 AMSYMMETRY says:
Good now I can change the lock before my girlfriend gets home
Jun 16, 2009. 10:34 AMA.C.E. says:
lol
Mar 15, 2009. 12:55 PMDIY Dave says:
Cool I have a lock that I am going to take apart and rearange the pins to fit another key that is exactly the same but with a reversed order
Mar 15, 2009. 7:30 AMScott_Tx says:
I was wondering how you'd add material to the key when I saw this but just removing the pin works too. Good idear.
Mar 15, 2009. 2:13 AMSkip says:
very clever. Nicely explained too.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:Jason-B
