Step 9: Charge your new battery pack
if you end up not calling the fire department
take yourself out for a beer
and brag about your experience!!
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
I have one question, though. Should I get the 2900mAh or the 1600mAh sub-Cs? What's the difference?
I have one question, though. Should I get the 2900maH or the 1600maH sub-Cs? What's the difference?
nice instructable
I did this last year to an old drill I got from a 'flea' market.
The local B&Q had several battery packs for various drills on sale at £5 each (around $7-$8, I think), so I bought a couple to make up the voltage I needed, but also made sure I used 1800mAh rather than the 1400mAh originals. The slight downside is needing a couple of extra hours to recharge (with the original charger), but that is balanced by the reduced likelihood of overheating.
I ended up cutting an old household power lead for my 'tabs', as I was concerned about the potential heat generated - and I couldn't think what else to use. It was a bit of a pain to close the pack up again, but I've had no problems since.
The drill has worked fine ever since - VERY powerful and almost, perhaps, a little too fast for screwdriving.
