3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to recover an old bicycle seat
Step 8Final attachment of the cover
Gently pull on the cover to stretch it around the sides of the seat, being careful to pull uniformly and evenly while gently applying pressure to adhere the material to the seat.
Pull and wrap the vinyl/leather around the edges. The adhesive is usually strong enough to temporarily hold the edges that have been wrapped around.
Pull taught and using the staple gun, carefully staple the edges to the underside of the seat. Work your way around the seat until all edges are pulled and stapled. Staple toward the top of the seat (downward, when the saddle is underside-up) instead of outward to pull the material taught and so you don't accidentally pierce through the sides.
I generally find it easiest to start at the center of the back, with a staple dead center, and then work my way around either side. The same idea should be used on the front as well, pulling the center of the nose over first, then working around either side.
Be careful, especially if using longer staples, that you don't accidentally pierce through the sides of the saddle (and possibly the vinyl/leather).
I usually use an x-acto knife at the end to trim any excess material (if there is any). Usually, I'll trim the material around the rear seat-rail attachments to create a cleaner look (check the photos).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
34
Author:djeucalyptus
