With Instructables you can share what you make with the world and tap into an ever-growing community of creative experts.
share step-by-step photos with text instructions
share one or more photos in one step quickly and easily
share your how-to video
1. Download Pandora File Recovery http://www.pandorarecovery.com/download/
2.Run and Install Pandora Recovery Setup.
3.Follow the Pandora Recovery Wizard for first time use.
3a. Use the wizard to find the deleted file in the recycle bin and follow the instruction to restore it in the recycle bin
3b. If not found in the recycle bin, it asks the user where was the file was last seen.(Default is Drive C:)
3b-1. Choose an option what best suits your search type for
3b-2. Select file type to be searched for and choose which disk drive to search in. Press "Start Disk Surface Scan"
3b-3. When desired file is found, right click and "recover to".
3b-4. Choose a desired location to where it will be restored to, then click "Restore Now". (Preferably save it into differe...
3b-5. A popup window will appear once it restores successfully.
3b-6. After pressing close in the pop up window, the location where the file was restored to will pop out and you can check ...
Tag files as:
Upload Files
2 favorites
Posted:Aug 20, 2011
License:
How to Get Started with Pandora by prajguru
How to rip Pandora music by edward2011
How to use Pandora by prajguru
How to recover deleted data by hellrider75
File Recovery Tutorial by ccss21b11
Undelete them deleted files, Very easy and user-friendly. by jason-2590
Basicon MP- Basic photoshop tools by Lars7706
Create and use ISO Image Files by joshology
TUT: Gun Effects using After Effects by lordd466b
How to Your Custom Firmware MOD Your PSP by littlechef37
See More
PDF DownloadsAs a Pro member, you will gain access to download any Instructable in the PDF format. You also have the ability to customize your PDF download.
(forgot username/password?)
I believe both downloading and installing software like this on a flash-drive would be best to avoid this.
