3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to recycle an old sweater (or a botched one) into usable yarn
Do you have old sweaters laying around? Is the yarn simply gorgeous or do you just want to re-use it? Is the sweater to mishapen to wear or just plain ugly, but the yarn is excellent? Did make an absolutely marvelous sweater, only to try it on and discover you should burn the pattern? Well then, recycle that yarn!!!
There are two methods of recycling a sweater into re-usable yarn. The first method is done from a work-in-progress (wip), the second method is done from an already finished-object (fo).
Step 1Remove the needles
Remove the needles
Here, we will begin by removing the needles from the offending sweater. This is done by simply sliding the stitches off of the needles.
Then, lay the offending sweater flat sew you can begin frogging. Frogging is the process of ripping the stitches out: As in, "Rip it, rip it, rip it!"
8 comments
Jun 19, 2011. 12:10 AMtsmith27 says:
Awesome! I never could find the end bit! Thanks for the excellent photo with the Vs marked. I work at a thrift store and have so many lovely yarns to salvage!
Dec 2, 2010. 11:42 AMGreetaSue says:
I love doing this. It is very soothing and fulfilling to turn old, unwearable sweaters into lovely stuff. I made a scarf that I get tons of compliments on and everyone is surprised when I tell them I ripped apart old stuff to make it!! YaY for direct recycling!!
Nov 12, 2010. 10:22 PMteaellen 2003 says:
a comment about recycling a wool sweater that you are having problems frogging: If you really have a problem with the yarn being glued together & having trouble getting the yarn out of it then instead of fighting it, just use its qualities. Just like using like the lemons that life gives us to make lemonade. It is ultra easy to felt a wool sweater and the fabric is wonderful to recycle and use! There are so many things that you can do with a felted sweater.
Oct 12, 2009. 8:26 PMporcupinemamma says:
I do"botched" really well, lol.  Good idea.  People in THE Great Depression did this all the time
Jun 12, 2009. 11:09 AMtnielsenhayden says:
If you're ripping back your own knitting, you know what's in the yarn and how it's been handled. Unravelling second-hand sweaters can be more problematic.
Watch out for commercially produced sweaters that have cut-and-sewn sleeve seams, shoulder seams, or front plackets, unless you *want* a bunch of short bits of yarn.
You also want to watch out for sweaters made of wool, mohair, or other animal fibers. Once the fibers start felting -- i.e., sticking together Till Death Do Us Part -- your chances of a satisfactory yarn-recycling experience go into a nosedive. Mohair and shetland wool are especially prone to this.
Take heart, though! A seriously felted sweater is by definition not going to unravel on you, so you can cut it up and use it as lightweight, slightly stretchy felt. You can even look up a set of instructions for deliberately felting knitted wool fabric (see also: "boiled wool"), and turn your old sweaters into much denser felt that has all kinds of uses.
Aug 2, 2008. 10:28 AMnennikers says:
A little hint here...on a commercial sweater you can usually find a chain of stitches on one side of the seam. Look for the point of the "V" in the chain, rip one link, then pull out in the direction of the "V". Makes much quicker work of ripping the seams!!! :)
Apr 18, 2008. 8:49 PMmyrrhmaid says:
Very resourceful! I'm going to have to try it! Thanks for the great idea!
Apr 11, 2008. 4:09 PMPatrik says:
If you really can't find the cast off stitch and are getting frustrated, you can always grab your scissors and snip off the entire edge. Sure, you may lose a few feet of yarn, but it's only a tiny fraction of the entire sweater anyway. If you do this on an old sweater, chances are this is the part that's the most frayed anyway...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
47
Author:tldudenhoeffer(Frozen Tundra Fiber Arts)
