How to Redo a Guitar With a Broken Neck and Terrible Paint Job
8,676
39
6
Posted
Introduction: How to Redo a Guitar With a Broken Neck and Terrible Paint Job
so i got this cruddy Japanese guitar from a friend and (playing guitar) I naturally I wanted to fix it...... I know my grammar stinks "it is not my strong subject" I was having a hard time with the website so if you are having a hard time with a step click on the picture and it explains more. F.Y.I this is my first instructablehttp://youtu.be/uD_P46cE9wg
you will need
sander.
vice.
gorilla glue.
loctite.
fret wire
wood stain.
teak oil
Hobby saw.
Step 1: Sanding
sand once and then go back and get the edges and clean up.
Step 2: Fixing the Neck
the pictures are pretty self explanatory gorilla glue, ect. afterwards sand the gorilla glue off
Step 3: Fixing Frets (If Needed)
sand of whole two frets off that lost a fret.  Cut fretwire to a certain length repaint "with acrylic paint" loctite and...... Boom
Step 4: Stain
stain.... mine didn't set right "because of the cheap wood" but after the teaking step it looked pretty cool!!!
Step 5: Teaking
So take your teak oil apply a couple coats let dry and your almost done!!!
Step 6: Finishing
add all of your hardware strings and...... bam you have got a fixed guitar.
thanks for reading!!!
click this hyperlink to see it in action
  • Gluten Free Challenge
  • Epilog Challenge 9
    Epilog Challenge 9
6 Comments
A product like Tightbond would be better for the repair. I personally use hot hide glue, but that's hard to work with. Also, the strings you have pictured are meant for an electric guitar. You'll get much better tone from actual acoustic strings.
As an amateur guitar repairer to another: Nice work! Sanding everything was a good move. Probably the gorilla glue will hold and it is OK but in the case of wood instruments a special glue is required such as Titebond. This type of glue produces a crystalline transparent result and the glue itself can be removed by heating. This is necessary for example in order to replace a bridge.
I have repaired a few guitars acoustic and classic and other chord instruments myself, including my daughter's cello . In the following instructable I have included an example in step 14
https://www.instructables.com/id/Woodturning-with-a-drill-press/step14/Wooden-wedges/
A suggestion for improvement of your instructable: Replace the photo of the finished guitar avoiding the flash because it covers everything.
The repair work work will not improve the sound of the instrument but the value of this guitar has increased because you worked on it.
thank you for your input!!! i will do that
Removing the bridge would make your life easier for sanding. The two white plastics probably cover two screws. The bridge glue can be removed with a long knife parallel to the guitar surface. I have done this quite a few times.
