3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to refill HP ink cartridges in two minutes.
video How to refill HP ink cartridges in two minutes.
How to refill HP 21 27 56 inkjet printer cart in less than two minutes.
For more detailed info, check my blog:
http://refillhp.blogspot.com/
7 comments
Apr 6, 2012. 5:51 AMwilliam31613 says:
Hi. Although refilling a ink cartridge is a good idea but i prefer buying ink cartridges. Its true that buying them costs more than refilling, but refilling requires a professional help & a slight mistake can damage the cartridge. So, i advice you to buy ink cartridges from a good, cheap & reliable company like absolutetoner
Mar 29, 2012. 8:20 AMbrrjns says:
Refilling ink cartridges can be tricky. If the printhead has dried up the refilled ink will not flow through and this will result in printing blank or the print will have white lines.The best way to make sure you get good prints from a refilled ink cartridge is to refill it white it is still working and before it becomes empty.
Jan 9, 2012. 2:34 AMshengtot says:
Refilling is not an easy task. One should really know how to do it to avoid messing up.  I thought that refill ink quality is less than our typical genuine ink jet cartridges but I was wrong.. It is just the same..
Apr 17, 2011. 9:17 AMLordPeti says:
What type of ink do you use?
Feb 21, 2011. 3:15 PMshabaki says:
where can you get the ink?
Feb 22, 2011. 12:41 AMRanie-K says:
I usually buy at eBay. Get a double kit: One with three bottles of black and one kit with all four colors. It's sometimes incredibly cheap to get stuff like this mailed all the way from Asia!
Feb 26, 2011. 8:10 AMshabaki says:
sweet i actually have had many occasions where i needed ink and harvesting it from gel pens just doesnt quite cut it :P
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:gm79jf
