loading
Why buy a replacement filter for $6 to $10 (or more) when you can refill your old filter cartridge housing for about 50 cents?!
Refilling is quick, easy and economical. If you can refill a salt shaker, then you should be able to refill a Brita, PuR, or other brand water pitcher cartridges. All that you will need is an old cartridge, some activated carbon, a polyethylene plug, a sharp utility knife or Xacto knife. A 1/2" drill motor and 1/2" drill bit are optional, but can aid in rounding out the hole.
Step 1: A bit about activated carbon and where to buy small quantities.
Activated carbon is also known as activated charcoal and is a VERY effective substance at absorbing many unwanted contaminants in drinking water and other liquids.
The History of Activated Carbon
Activated Carbon was first known to treat water over 2000 years ago. However, it was first produced commercially at the beginning of the 20th century and was only available in powder form. Initially activated carbon was mainly used to decolorize sugar and then from 1930 for water treatment to remove taste and odor. Granular activated carbon was first developed as a consequence of WWI for gas masks and has been used subsequently for water treatment, solvent recovery and air purification. The unique structure of activated carbon produces a very large surface area: 1 lb of granular activated carbon typically provides a surface area of 125 acres (1 Kg =1,000,000 sq. m.). Activated carbon can be produced from a variety of carbonaceous raw material, the primary ones being coal, coconut shells, wood and lignite. The intrinsic properties of the activated carbon are dependent on the raw material source. The activated carbon surface is non-polar which results in an affinity for non-polar adsorbates such as organics. Adsorption is a surface phenomenom in which an adsorbate is held onto the surface of the activated carbon by Van der Waal's forces and saturation is represented by an equilibrium point. These forces are physical in nature, which means that the process is reversible (using heat, pressure, etc.) Activated carbon is also capable of chemisorption, whereby a chemical reaction occurs at the carbon interface, changing the state of the adsorbate (dechlorination is an example of a chemisorption process). (You can read more here: http://www.carbochem.com/activatedcarbon101.html )
Activated charcoal is good at trapping other carbon-based impurities ("organic" chemicals), as well as things like chlorine. Many other chemicals are not attracted to carbon at all -- sodium, nitrates, etc. -- so they pass right through. This means that an activated charcoal filter will remove certain impurities while ignoring others. It also means that, once all of the bonding sites are filled, an activated charcoal filter stops working. At that point you must replace the filter. (You can read more here: http://science.howstuffworks.com/question209.htm )
Over 100 years ago Ellen White, a health reformer & pioneer of the Seventh Day Adventist movement strongly advocated the medical uses for charcoal powder. The modern medical establishment has only recently begun to use activated charcoal powder as the preferred method of treating oral poisonings and drug overdoses: "It is thought to bind to poison and prevent its absorption by the gastrointestinal tract. In cases of suspected poisoning, medical personnel either administer activated charcoal on the scene or at a hospital's emergency department. Dosing is usually empirical at 1 gram/kg of body weight, usually given only once. Depending on the drug taken, it may be given more than once. In rare situations activated charcoal is used in Intensive Care to filter out harmful drugs from the blood stream of poisoned patients. Activated carbon has become the treatment of choice for many poisonings, and other decontamination methods such as ipecac-induced emesis or stomach pumps are now used rarely." (From the Wikipedia entry for Activated Carbon)
You can find it at any fish & aquarium supply. If your concerned that the quality of the carbon from an aquarium shop might not be up-to-snuff, then go to a homebrew shop, or some other source that you are comfortable with. The granule size you'll want should be relatively close to 8 x 16 mesh size or smaller, but NOT so small that it falls out of the holes in your filter housing. I purchased the NSF approved carbon I used for my filters through an ebay merchant (here: http://stores.ebay.com/Carbon-Eze ). No, that's not me, & I don't know them. :) They describe their products well and have a good reputation & that's why I've included them here.
Step 2: The polyethylene plug
This is something you can find at a hardware store. They come in different colors and styles, so don't let that distract you... color isn't important and type is up to your own judgment. What is important is the size. You want a plug that is slightly over 1/2" at the widest point of the tapered sides. Vernier calipers would be a useful item to take with you to measure this dimension when you go to the store. This should cost less than 25 cents.
Step 3: Making the hole.
You will notice on the top of the Brita filter cartridge some radial slots for allowing water into the filter. The overall diameter of the slot pattern is just under 1/2". I've drawn a black line where you'll want to make your cuts. As the plastic is thin, be careful not to get too happy with the knife... stay calm. :)
Dump out the original contents. You will notice what look like little glass beads in with the charcoal... I believe these are resin beads and are primarily used to remove heavy metals. Have your water tested to see if you have heavy metals that you would want removed. If so, you'll likely want to go with a filtration system that includes these beads.
As a side-note, some of the PuR filters (owned by Proctor & Gamble) now (as of March, 2008) come with a timed release version of sodium fluoride, which is toxic to mammals. You can read up on the fluoride controversy here ( http://www.fluoridation.com/ ), or you can Google the terms fluoride + poison. (2013 Update: PuR no longer sells their filters that "adds benificial flouride to your water")
Once you've got the hole roughed out, you can smooth it round with your knife, or you can use a 1/2" drill bit to ream out the hole. If you use the bit, set the drill on the higher gear range, as the faster bit speed will make a smoother, rounder hole. While you want a fast bit RPM, you want to insert the bit into your rough hole slowly so that you don't end up with tears in the plastic. You can actually use the fast moving bit to melt the hole, which will preserve the integrity of the plastic. Reversing the drill will provide friction/heat & help prevent tearing the plastic.
Finish up this step by trimming any excess plastic from around the hole and dry-fitting your plugs. Adjust the hole diameter with your knife as necessary... this isn't rocket science, the hole simple has to be tight enough to retain the plug so that the rim/shoulder of the plugs sits parallel with the surface, as shown in the photo.
Step 4: Filling & using the housing.
Before filling the housing, you may want to wash it then soak it in a bleach solution to kill any cooties that may have formed in the housing. Chlorine bleach, sodium hypochlorite, is a VERY potent antimicrobial, which means "a little dab will do ya". 8 drops of bleach per gallon of water is a stronger solution than any public pool or spa that I've ever been in and is the ratio that the World Health Organization recommends for purifying pretty ugly water for drinking. Personally, I think that ratio is overkill, but they probably want to err on the side of safety.
Rinse the housing thoroughly when done soaking... there's no need to dry it. Place the funnel in the hole and fill with activated carbon. You may want to tap the housing on your counter to settle the granules and top it off, allowing room for the plug. Once plugged, you now have a filter that is more than likely more effective at taking out impurities than the original. Why? because you filled it fuller and you used ONLY pure carbon with no fillers. It should filter more water before needing changed than an original filter.
You also may want to poke some holes in the "dome" on the top of the housing to allow water to flow into that area of the housing. A hot pin or needle works well for this. This replaces the holes that we cut out and plugged in step 3.
Treat this filter just as you would a new one... soak it in water for 15 minutes to make sure the carbon is saturated. Expect that there will be some fine charcoal powder that settles out in your first couple of batches or so. This won't hurt you to drink it with your water or let it settle out.. :-) When your filter is not in use, put it in a ziploc plastic bag and store it in the fridge to prevent it from growing funk. I haven't tried storing them in the freezer yet... that would definitely slow any growth down, but I don't know if it would cause the ice to break the carbon into finer particles that could escape the housing. I just haven't tried it yet.
This is my first instructable... questions, comments and critique are welcome and encouraged. Enjoy.
Step 5: ADDENDUM
ADDENDUM... MICROBES, FEAR, AND OTHER TOXINS....
I appreciate all of the comments... even the ones that ask the hard questions or bring up shortcomings or potential shortcomings in this instructable.
First off, let me say that this filter makeover is NOT intended to do ALL that the Brita filters claim to do, but just do what the activated carbon portion performs, which meets my needs very well. I live in a small community of about 50 individuals in the high plains of N.E. New Mexico, and the water hardness is just under 1000 parts per million (ppm), which are largely sulphates with some sodium, so we don't use that water for drinking or cooking. We distill some of our water in solar and electric distillers, and also collect rainwater from our metal roofs. Because of the quantity of dust, pollen, algae spores and other organic matter (bird poop, etc.) that settles on our roofs, we filter our water through a multi-stage filter bank that concludes with a .5 micron carbon block filter. Each week we consume about 250 to 300 gallons of rainwater alone, so water filtration is a requirement, but at the same time, we're not going to lose sleep over what get through the carbon. The filter pitchers that we use are primarily to remove any off-flavors that may not be entirely removed by the carbon block, and this the granulated carbon does remarkably well. Refilling these filters amounts to a substantial annual cost savings for us. In the last two months I've refilled over 30 of these filters with the NSF certified granulated activated carbon that I linked to on page 1 <http://stores.ebay.com/Carbon-Eze >.
Everyone should have their water tested and judge from the test results what type of filtration you NEED. Be intelligent. Why pay for something you don't use? Use your own judgment as to whether a carbon-only filter is suitable for your situation. I hate fear/ignorance stimulated marketing tactics that are used by some water filter companies (or any company) to get folks to buy their product out of fear and ignorance. I will try to dispel the concerns that some have suggested in the comments.
For those who are concerned that the quality of the carbon that they might encounter at an aquarium shop, and feel they need FDA "food grade" certification or on their activated carbon, I WOULD ENCOURAGE YOU TO FIND A SOURCE THAT YOU ARE COMFORTABLE WITH AND BUY FROM THEM. YOU MAY EVEN WANT TO SHARE WHAT YOU FIND... POST THEIR CONTACT INFO HERE in a comment. The carbon source I linked to sell NSF certified carbon. Really, though, I think the amount of concern over this point is overstated, as aquarium fish tend to be very sensitive to certain impurities and the folks that make the carbon for that application are very aware of this... they don't want anything in the filter media they sell, as it's not good for business. Personally, I would trust a vet supply (or aquarium shop) over the FDA any day of the week. The FDA approves toxins for food additives (sodium fluoride, Aspartame, MSG, etc.) while forbidding beneficial or benign ingredients (stevia, numerous medicinal herbs, etc.). It's usually about corporate money & bribes.
Anyone with a source for alternate or superior filter media are encouraged to post their findings and URLs in the comments.
For those with a concern about medications that may be in your city water supply (I'm assuming from the city recycling the waste water), if it's a carbon based/organic medication, then carbon should filter that out. Do your research, be responsible, be wise. Do what works for you.
If you have a concern about the carbon becoming a medium for microbes to flourish, one of the best ways to slow that process down is to lower the temperature of your filter by keeping the pitcher in fridge. Keep in mind that carbon removes (adsorbs) organic, carbon based impurities as well as chlorine... which also includes what decomposing residue that results from the organic impurities "rotting" that get caught by the carbon... molds, fungi, yeast, mildew... microbes in general. In other words, the "fresh" stuff that gets trapped by the filter and begins to decompose remains to be trapped by the carbon UNTIL the carbon has reached saturation. Unless your olfactory senses are totally fried, you should be able to tell by the taste of the water when the carbon is spent and in need of replacement. If you're one that is ultra sensitive to this kind of stuff, find out what works for you and stick with it. If you sleep better by using a corporate, consumer grade product, then by all means, do that.
If you're filtering water that has chlorine in it, the chlorine will likely reduce/retard/prevent the growth of microbes. The chlorine probably already killed all of the cooties BEFORE you ran them through the filter. Myself, I wouldn't worry about it unless you truly have a real and not imaginary need for additional filtration.
A WORD ABOUT DISCLAIMERS:
I purchased a book several years ago titled "The Egoscue Method of Health Through Motion" which had a disclaimer that really impressed me... it is included below and applies to this instructable, as well as life in general. Personal responsibility isn't for everyone, just those who appreciate freedom and don't care to blame others. :o)
"Ours is a highly litigious society. Which means, in plain English, we like to sue each other, blame each other, transfer responsibility to others.
Since, as you'll see, responsibility is a continuing theme of this book, the space which is usually reserved for what the lawyers refer to as the "disclaimer" is being used to make an additional and, I believe, more important point.
You've seen the words many times: "The following material is not intended as a substitute for the advice of a physician. The reader should consult a physician before embarking on this or any health program..."--- or words to that effect. The all-purpose liability firebreak.
Disclaimers are a legal necessity, but they are a cop-out. This material is no substitute for the reader taking responsibility for his or her own health. Therefore, I have an important recommendation to make: If you really need a disclaimer, close the book and put it back on the shelf unread.
I hope you don't, because what I have to say in the pages ahead will change your life. Pete Egoscue"
A COUPLE FINAL THOUGHTS/OPINIONS:
Anyone who is truly concerned about their health and is still eating meat and diary products are either ill informed or are not really concerned ENOUGH about their health. I would say the same thing applies to living/working in the city environment... it's not physically or spiritually healthy. I haven't been to a hospital for an illness in over 24 years, and the last 17 of those years I've been a vegetarian. I haven't been sick for almost three years... ever since I gave up eggs and dairy. I know about 50 other vegetarians who also stopped eating eggs and dairy products at the same time who also haven't been ill in almost three years. Be wise with what you do with your life.
<p>No way are enough people going to start sourcing carbon and plugs and getting out the drill in enough numbers to worry Brita about changing their filter model.</p><p>I think refilling the filters is a great idea, but it would be even greater if they actually just sold refillable filters, with a top that you can open and refill. The easier it is to do, the more people will do it. (Especially since it would also save you money!)</p>
<p>I bought a new Brita pitcher with a filter last night and they have done exactly that! lol</p>
<p>If you either need (as determined by chemical analysis) or &quot;really totally need&quot; (as determined by feels) the Ion filtration you can always buy and mix the resin beads in with the charcoal yourself. The exact ratio really depends on your personal water chemistry. I get Nuclear Grade mixed bed DI resin beads (findable on amazon and ebay) and fill the canister about 1/5 of the way with the beads and the rest of the way with activated charcoal and that works well enough for my tastes.<br><br>Having drunk reactor grade water in my navy days (literally some of the purest stuff on the planet as reactors are really picky about what is in the water.) I prefer some minerals to &quot;flavor&quot; my water but to each their own.</p>
<p>Here is the newest and easiest way to not have to pay for those expensive Brita filters - www.clear-genius.com Fits directly into your Brita and Pur pitchers. Now you just buy the REUSABLE two piece cartridge once and replace the Filter Pod refill every 40 gallons! More eco-friendly and less costly than Brita or Pur!</p>
<p>It still not clear... Would you please to explain what do you mean &quot;buy the reusable two piece cartridge&quot;? I NEVER saw reusable cartridges at stores and on internet AT ALL. Can you give me the information where can I get them? You can e-mail me at sergeypugach@gmail.com Thanks in advance!</p>
<p>www.clear-genius.com</p>
<p>I can't find any way to purchase those units on that web site. Nor any referral to stores that might carry them. ???</p>
<p>Good article.. I was going to blaaaah at you for not giving instruction to make your own fireworks grade charcoal..a.k.a. activated charcoal . But i re-read the heading . and great job.I made my own activated charcoal last winter and used it for air / water filtration and saved a ton of money for my fish n'tanks..so check out diy charcoal on you tube..it's very cheap and really interesting.GO SCIENCE.!!</p>
<p>You can get the plugs at most medical stores and at fastenals </p>
<p>I sell <a href="http://www.aquapurica.nl" rel="nofollow">water filters</a> in the Netherlands, and I would definitely not recommend Brita waterfilters. They hardly do anything. Sure I understand this cheap way of replacing the cartridges, but if you really want you water without toxins there are real solutions out there that do that. There are charts that give a good comparison. I think Zero Water offers the best Brita like filter, that actually works. You can also look up on youtube: Brita vs Aquaphor. It's quite interesting</p>
this is EXACTLY what i need - and i didn't even know it! <br> <br>our town water is, frankly, shyte. it's horrible. bad enough that it smells like pure javex, but it's hard enough to chew. when we bought the house, the documentation said the bathroom fittings had been replaced 2yrs earlier. We've been in the house two years and already I had to shell out $100 for a new showerhead: even 24hrs in CLR did nothing to get the rocky buildup out of the showerhead. It was so bad, it would send water shooting up and over the shower doors - we had to put bath sheets on the floor to mop up the water when we showered. I use sand to clean the crust off the inside of the shower stall, bath tub, shower doors, toilet bowls, and sink - it's the only thing that works. <br> <br>needless to say, potables prepared with this rank effluent is not exactly &quot;the pause that refreshes&quot;. <br> <br>since we know the water is safe, it's just to address the flavour and odour and this, brita does very well but the filters in no way last a month - 2-1/2 to 3wks at the most - and it gets really expensive. <br> <br>instructables to the rescue! <br>
<p>You may never see this since you posted over a year ago, but just in case. There is a product called &quot;Works&quot;. It can be found just about everywhere (dollar stores, Walmart, grocery stores). It is very inexpensive. I have horribly hard water with a lot of iron that turns everything orange here. It is actually a toilet bowl cleaner but I have used Works in the shower, tub, sinks, washing machine and toilet. I have soaked the shower head in it, didn't even take it off, just held a cup with Works in it over the shower head (mine is standard small). It is great stuff. I even used it in the toilet tank, it does not damage the plastic or metal parts, but cleans super efficiently and very fast - within minutes.</p>
have u tried dual water brine tank water softening system. this is the set up that we use, cause we have iron hard water. when 1 tank is being cleaned. it uses the other tank. then it switches back an forth.
that's definitely on my list of future household upgrades!
depending on where u live. it can be costly. my parent spent like 5k in cash getting it set up right but well worth it. we also use a iron pre-filter as well.
<p>TIP: Activated charcoal does NOT remove chloramines (read up on chloramines), but you can add vitamin c crystals in with the activated charcoal and it WILL render the chloramines inert. This is very important. </p>
<p>Great article. Have been using activated carbon in fish tanks and now understand that it's the same stuff in the brita filters. Thanks!</p>
<p>Informative and Great Article! We should have used this technique in the past to refill Brita filter, until we realized that it does not do a lot, expect filtering or eliminating some of the Contaminants such as Chlorine. We believe Brita is one of the Cheapest and <a href="http://www.saferowatersystem.com/best-water-filter-pitcher-reviews/" rel="nofollow">Best Water Filter Pitcher</a> out there in the market, though it is one of the most inexpensive filters. According to a stat we read on internet, there are about 87 common contaminants and impurities contain in the water. Water filter are handful compared with Reverse Osmosis. However, using filter can save a lot of money.</p>
<p>what type on ion exchange resin can i use ?</p><p>can i use this ion exchange resin to filter drinking water they say it is for fish water tank</p><p><a href="http://www.aquariumonline.co.uk/reverse_osmosis_and_water_purifiers/resins_for_water_treatment/water_softening_resin_1_litre_P3447.html?gclid=CK-Z_ZrBiL8CFfMgtAodtUcAog" rel="nofollow">http://www.aquariumonline.co.uk/reverse_osmosis_and_water_purifiers/resins_for_water_treatment/water_softening_resin_1_litre_P3447.html?gclid=CK-Z_ZrBiL8CFfMgtAodtUcAog</a></p>
<p>To each their own. Now, with that said:<br>The meat and dairy are not the 'evils' that everyone touts. It is what is allowed to be (and almost forced on farmers to be) done to the animals. The animals (and most crops) are chuck-full-o' all kinds of antibiotics, steroids, hormones, and other chemicals. Those of course are in the parts we eat and any product that comes from them. Try for a month to eat organic foods mostly (especially meat and dairy) and see how you feel after that. The difference is amazing. OH and everyone that goes on about 'it so much more expensive'; that it may be, but the taste and nutrients that you get have been compared at: 1 organic apple = 3-5 conventionally grown apples in nutrients. The meat? Take a 1/4 lb of each and make a patty/burger. Cook them the same way. You will see that the organic hardly shrinks while the other will shrink 1/3 - 1/2 its size. Then try the flavor and you will be sold. So, you are actually getting more of you money worth by going this way. <br>If you feel good living as a vegan then good for you. If you want to be healthier but like your meat, then I suggest giving this a try. After all you filter your water; why not try the equivalient to your food by taking out the poisons/chemicals/etc? </p>
<p>I personally can't do the vegetarian thing but if you can you'll find no grief from me. That said, I liked the write up and it was an interesting idea I hadn't previously considered. With that in mind, I have a couple questions I'd like to run by you (and or everyone in general as I'm not having a lot of luck via googling).<br><br>A) Have you or anyone else tried Activated Alumina in the mix? What ratios would be appropriate if so? (For those unaware, Activated Alumina removes flouride from water in a similar manner as activated carbon removes chlorine as I understand it and can also be used dry as a dessicant.) I'm not sure if there are any safety issues surrounding it either but I do know it's found in some other filter offerings.<br><br>B) Has anyone used this for alcohol/liquor filtration per chance? There used to be a few carbon only pitcher offerings and they do wonders for cheaper Vodkas for example. I bring that one in particular up as my wife hates my choice/preference in Vodka tho I must admit 2-3 rounds through charcoal makes a fairly dramatic difference.<br><br>Anyway, I have a few different pitchers (both PUR and Brita) and I believe they have the old filters in them so I'll have to give them a try. Thanks for the write up. </p>
<p>I have an easy solution for the stopper. With a scissors I cut a square from a flat portion of a plastic milk carton that was a little larger that the hole I drilled in the filter. Then made two parallel cuts about 1/8&quot; apart on two opposite sides to create two tabs. Slide one tab under the edge of the hole, then the other.</p>
<p>Ingeniously sweet!</p>
<p>I'll add myself to your list of vegetarians.</p><p>I stopped eating ALL dead animals in 1972 and I do eat home made yogurt.</p><p>I supposedly had get my tonsils out when I was 8, which was in a hospital. </p><p>That was my last hospital visit. No sickness since way before 1972 and 1 cold 6 years ago and no memory of one before that. I learned exactly how to prevent or cure a cold or sickness also in 1972.</p>
Looks like Carboneze on EBay has gone out of business. <br> <br>There are quite a few options on Amazone. What might be the critical features to look for?
<a href="http://www.bulkactivatedcarbon.net/Activated-Carbon-for-Water-Purification.html" rel="nofollow">http://www.bulkactivatedcarbon.net/Activated-Carbon-for-Water-Purification.html</a><br> <br> I bought from the site above, and it cames cheap and good.
well, i tried it and... [drumroll, pls] - it totally works!!!!! bought a litre-sized carton of charcoal for $12 (everything is expensive here) and from the look of it, i'll get 4, maybe 5 filter refills. <br> <br>i didn't even have to buy a plug: i cut a c-shaped flap in the top and the plastic is durable enough to press back down. naturally, that will snap off after another time or two but for the moment, it's good enough.
oh - the water? delicious!
actually it wont work on the (pur) water filters cause they use a 5 layer set up. itill work on brita cause thats a 1 or 2 slayer water filter.
First, thanks for your instructable. It was very good and as another has said, well thought out. However, in your final comment touting the advantages of veganism is fine for those that can handle it. I can't (not that I haven't tried it). I was a vegan for 1 1/2 years. The beginning effects (first 3 mos.) were great....cleansing, detoxing... However, I stuck to it out of perisistence and nearly ruined my health. I was not getting enough of the protein/amino acids I needed. My muscles were wasting away and I was experiencing excruciating pain as a consequence. Each person has a particular diet type that works best for them. My advice: find what works for you and eat healthy. What works for me? protein, fat and vegetables (very low on fruit & other sugar sources).
same there - in three months, i was so severely anaemic that the doctor was considering hospitalizing me for a week or so for IV treatment. <br> <br>turns out i cannot absorb non-haeme (non-blood sourced) iron. red meat three times a day keeps my iron levels on the low end of normal.
Great and informative article. I would have used this in the past to refill my Brita filter, until I realized it doesn't do much, other than filter out chlorine, and a couple other contaminants. There is a reason this <a href="http://www.aquasafecanada.com/store/water-filters" rel="nofollow">water filter</a> is the cheapest on the market, because it is one of the most ineffective filters. There are over 87 common contaminants in our water, not including the uncommon ones, and this filter removes a handful. But those intent on using this filter, this is a great way to save some money.
i use the brita filter bec we have municipally treated water that while is safe enough to drink, is hard enough to chew and stinks of bleach. the brita filter works well - but does not last in any way near a month - more like 2-1/2 to 3 wks.
People with the Maxtra filters in their jugs - don't cut a hole in the top. You run the risk of totally ruining the little plastic mesh that they've put there to stop the big holes from letting anything larger in. Make your hole on the side of the cartridge instead.
Very informative instructions! I actually tried, but was not too successful cause 1) my drill probably is not too powerful; 2) I was afraid i could get hurt; 3)hard to add the carbon to the tube<br> <br> I got inspiration while stopping by at Bed Bath and Beyond. I made another version of Home made Water filter refill: no skills or extra tools needed. Perfectly fits people like me;)<br> <br> http://teabeyond.blogspot.com/2013/06/how-to-make-water-filter-refill.html
<a href="http://www.ehow.com/how_6916584_regenerate-activated-charcoal.html" rel="nofollow"><strong>How to Regenerate Activated Charcoal&nbsp; eHow</strong></a><br> <br> Activated charcoal is carbon in extremely porous form. It is usually derived from charcoal. It has a large surface area and is used for chemical reactions as a catalyst. It is also used in fish tanks as a filter or to filter distilled alcohol. Activated charcoal is an expensive product. It is cheaper to regenerate the charcoal than buying new activated charcoal<br> <br> <strong>Instructions<br> Chemical Regeneration</strong><br> <br> 1. Soak the activated charcoal in a solution of 9 to 10 percent hydrogen peroxide. Handle the solution by wearing gloves as it can cause burns. You can also use <a href="http://www.ehow.com/list_7357498_differences-betweeen-distilled-deionized-water.html" rel="nofollow"><strong>distilled deionized water</strong></a> instead of the hydrogen peroxide solution.<br> <br> 2. Stir the mixture every 15 minutes.<br> <br> 3. When the solution has been absorbed, add more solution to the container. Repeat this many times.<br> <br> 4. Bake the charcoal in an oven at 225 degrees Fahrenheit for an hour or two.
Very informative!
Great article. A little tip. You can easily source plastic plugs as free samples from large manufacturers. They are pretty useful all round so definitely worth ordering a few. Who knows, one of your ideas may go into production which they'd sure be grateful of! <br> <br>My automatic coffee machine requires a filter at all times to work so this is perfect. They are bespoke, cost a fortune and are also expected to be replaced monthly. Despite the worries of some, this is much better than never replacing the filter.
I don't know about that. Ever since I switched to filtered water and or bottled water I have had no cavities. Plus I decided to experiment and slowed down on brushing yet always asking people about my breath. ( I can accept constructive criticism). I do not like to jump to conclusions and especially one that affects all Americans but could it be that a capitalist society has decided that putting something in our drink that would promote the economy is atleast possible? Fluoride and cavities creates many jobs and has an almost snowball effect. I did my own personal experiment and my results indicate that I would rather not have fluoride.
By chance have a new source you prefer, that ebay store is long gone.
I have the faucet mount Brita water system. The filters are different than pictured. Can this be done to those type of filters? Thanks!
I do community recycling and these things are a major pain the the butt. The actives carbon has to be garbaged but the shell can be recycled. They really make a mess. Thanks you for doing this.
Awesome money saver, thanks so much!
If you're looking for the ion exchange resin search Amazon.com for &quot;ion exchange resin&quot;. As of this post (Feb 19, 2012) they have 2 pounds for $17.50 and 25 pounds for $185. The &quot;Product Features&quot; for these products says that they can be used for water purification.<br> <br> If you look at the &quot;Customers Who Viewed This Item Also Viewed&quot; portion of the page which comes up it shows other types of similar(??) resins.<br> <br> It's been a long time since I read these comments so what I apologize if what I'm about to ask has already been answered. If it hasn't been answered, <strong>can someone please tell me if they know hold long (as in how many gallons) the ion exchange resins in a Brita filter are designed to last?</strong> In other words, do the ion exchange resins &quot;wear out&quot; at the same rate as the charcoal....or do they have a longer life span?<br> <br> I plan on building my own water filter out of an upside down 2 liter soda bottle with the bottom cut off and hole(s) poked in bottle cap (and possibly other places)....and if I don't have to, I don't want to toss out the ion resin beads every time I change the charcoal.<br> <br> Thanks for any info you can give me about the life span of the resin beads!!.....:)
I am with you on not wanting fluoride in my water, but where do you get the idea that PUR puts timed release sodium fluoride in their filters?? I have searched the web, including PUR's own site AND the anti-fluoride sites, and there is nothing saying anything like this. Instead, they just say their filters won't REMOVE fluoride - which is okay with me, since my area doesn't fluoridate the water. <br><br>Please provide a source or edit this line out - I would love to know if it's true, but if it's not, it shouldn't be causing alarm to people like me who use PUR-filtered water for me and my pets.<br><br>Thanks.
I only had a brief look (I'm on lunch). but would point out that the ion exchange resin also reduces 'scale' problems. I used to live in a chalk area where scale was more of an issue than taste so i still buy the filters new for the resin aspect. the top slits/holes are also for air to escape more easily - thus increasing flow time. most of these products use silver in the activated carbon as a bacteriostat - that is to stop bacteria growing whilst it is in storage and is not a source for treating bacteriological waters. in fact with time these filters can provide very good growth conditions, so if you do reuse old housings you really should disinfect. <br> <br>nice concept. good for tast and odour issues (and pesticides).
Where do you arrive at the 50 cent figure for refilling a cartridge? <br><br>All the activated charcoal I have seen is very expensive. A standard container even from the big box stores is about $8 for 9 ounces. This would maybe fill three Britta filters. One of the links to a bulk charcoal website lists 4 pounds for $52, that's $13 per pound while charcoal for BBQs is about 27 cents per pound. Is there a manufacture of filter grade charcoal that will be in the middle? Please post a source or link or don't make such a claim.
It not the kind of thing that you're going to save money on re-filling just one cartridge. In the long run, this is the smartest way to save money and keep your water clean. Just searching in google for &quot;bulk activated charcoal&quot; should point you in the right direction. It's pretty easy to find it under $5 per lb.<br> <br> You could always just find some <a href="http://britacoupons.com">brita coupons</a> if you want to take the easy way out.
BBQ charcoal can contain heavy metals, toxins and other general nasties. Unless you are planning on using the &quot;all natural&quot; charred sticks that still retain their original shape(of a burned stick) then you would be poisoning your water rather than purifying it.
About This Instructable
444,977views
691favorites
License:
More by IAMSatisfied:Paracord Chair: Simple, Comfortable, Adjustable & Collapsable How to refill a "disposable" Brita brand water pitcher filter with activated carbon.
Add instructable to:
