How to refill a "disposable" Brita brand water pitcher filter with activated carbon.
Step 3Making the hole.
Making the hole.
You will notice on the top of the Brita filter cartridge some radial slots for allowing water into the filter. The overall diameter of the slot pattern is just under 1/2". I've drawn a black line where you'll want to make your cuts. As the plastic is thin, be careful not to get too happy with the knife... stay calm. :)
Dump out the original contents. You will notice what look like little glass beads in with the charcoal... I believe these are resin beads and are primarily used to remove heavy metals. Have your water tested to see if you have heavy metals that you would want removed. If so, you'll likely want to go with a filtration system that includes these beads.
As a side-note, the PuR filters (owned by Proctor & Gamble) now come with a timed release version of sodium fluoride, which is toxic to mammals. You can read up on the fluoride controversy here ( http://www.fluoridation.com/ ), or you can Google the terms fluoride + poison.
Once you've got the hole roughed out, you can smooth it round with your knife, or you can use a 1/2" drill bit to ream out the hole. If you use the bit, set the drill on the higher gear range, as the faster bit speed will make a smoother, rounder hole. While you want a fast bit RPM, you want to insert the bit into your rough hole slowly so that you don't end up with tears in the plastic. You can actually use the fast moving bit to melt the hole, which will preserve the integrity of the plastic. Reversing the drill will provide friction/heat & help prevent tearing the plastic.
Finish up this step by trimming any excess plastic from around the hole and dry-fitting your plugs. Adjust the hole diameter with your knife as necessary... this isn't rocket science, the hole simple has to be tight enough to retain the plug so that the rim/shoulder of the plugs sits parallel with the surface, as shown in the photo.
13 comments
Aug 27, 2008. 9:53 PMMark Rehorst says:
Fluoride is put into water to protect teeth. The small quantities added to public water supplies is NOT toxic. Find actual scientific information, not paranoia, here:
http://www.cdc.gov/FLUORIDATION/benefits.htm
Jan 4, 2012. 11:52 PMArtanis_Regnis says:
Yea...Never, ever question the government. They always tell the truth.
As if the government wants to save your teeth. What a laugh.
The fluoride is called a "slow kill".
Jan 11, 2012. 2:49 PMkc8hps says:
YES it is a slow kill, funny how my father was removed from drinking city water due to the affects it could have on kidney functions.
I think all people over 50 should be wise and use good judgement on how much water they consume form municipal water sources.
Just sayin.
Jan 5, 2012. 8:02 AMMark Rehorst says:
Why do you think the government wants to poison you?
Jan 5, 2012. 7:54 AMMark Rehorst says:
Many people subscribe to the conspiracy theory of dentistry- that dentists are out to screw people out of their money by lying to them about their oral health. Yes, there are some dentists who put commerce over health, but they are in the minority. The vast majority of dentists are genuinely concerned about their patients' health and do their best to provide them with quality care.
The unfortunate thing about people who are suspicious of dentists is that their suspicion leads them to avoid dentists which in turn leads to poor oral health which eventually leads to a dentist telling them that they need extensive work, often at a high cost. Their suspicion thus becomes a self-fulfilling prophecy.
If we start with two basic assumptions
a) pain and infection are undesirable for overall health and quality of life,
b) having teeth is better than not having them
and we look at the disease processes that result in oral pain and loss of teeth, we eventually reach the inescapable conclusion that the mouth requires regular maintenance by highly trained professionals. It is a very rare person whose diet, lifestyle, immune system, anatomy, and genetics all align themselves in favor of perfect oral health.
Finally, the scientific method is unquestionably the greatest invention of the human race. Every other human invention around you exists because the scientific method works, and works well. I've provided links to the science behind the fluoridation of water. I can't force you to read it or believe it. It is up to each individual to choose truth or ignorance. I hope for your own sake that you choose wisely.
Jan 5, 2012. 8:38 PMArtanis_Regnis says:
I certainly can't force you to believe that putting poison in your water is indeed a "slow kill". There is no conspiracy theory. It's a fact. If you think for one second the local water municipality under direction of the federal government, intentions are for better oral, who am I to argue with you. I certainly won't change your mind. Drink all the fluoride laced water you wish.
What's important is people are waking up and they are making choices based off the information of their own research.
For me, I indeed choose truth. Wisely.
Jan 5, 2012. 10:25 PMMark Rehorst says:
I wish you a long, healthy life and the best of luck in all your endeavors.
Jan 14, 2012. 11:44 PMArtanis_Regnis says:
Information is piling in regarding the toxic poisoning and SLOW KILL of the American people through fluoride. New research reveals a startling new finding: fluoride is likely contributing to the epidemic of cardiovascular disease by stimulating calcification of the vascular system, including the coronary arteries.
In a study published in the journal Nuclear Medicine Communications this month (Jan. 2012), researchers assessed fluoride uptake and calcification in the major arteries of 61 patients who were administered sodium fluoride, the active ingredient in most fluoridated toothpastes.
Here is the link to the study;
http://www.greenmedinfo.com/article/there-association-vascular-fluoride-uptake-vascular-calcification-and-coronary-artery-diseas
Jan 15, 2012. 1:36 AMMark Rehorst says:
Articles in medical/engineering/scientific journals are aimed at readers who have the educational background to understand them. It is very easy for people who do not have that educational background to make mistakes interpreting the information presented. The link you posted is a great example of how people misinterpret such articles.
The first clue to the problem is that the linked abstract is for an article published in a journal of nuclear medicine. Why would there be an article about fluoride and arterial plaques in a journal of nuclear medicine? Why not in a journal of cardiology?
The answer is that the article is NOT about a causal relationship between fluoride ingestion and formation of arterial plaques. It is about using a radioactive fluoride compound as a contrast agent to improve image quality on PET/CT scans. The fluoride in question is swallowed or injected into the patient prior to performing the PET/CT scan. The article is saying that the fluoride compound contrast agent appears to be taken up in the plaques rendering them more readily apparent in the PET/CT images.
Here's a link to a reliable site that explains what PET scan and contrast agents are: http://www.radiologyinfo.org/en/info.cfm?pg=pet
Here is another article that explains the use of a fluoride compound as a contrast agent for detecting breast cancer using PET scans (NO, it doesn't imply that fluoride CAUSES breast cancer!):
http://radiographics.rsna.org/content/27/suppl_1/S215.full
The people who posted the link at greenmedinfo.com apparently didn't read or didn't understand the article whose abstract they published. They simply saw the words "fluoride" and "arterial plaque" and leapt to the incorrect conclusion that fluoride causes arterial plaque.
Jan 5, 2012. 11:41 PMArtanis_Regnis says:
Thank you, Mark. You too.
Apr 22, 2009. 10:37 AMstickelt says:
CDC , they are a joke. You need to do your homework. Show ME where Fluoride is GOOD for your teeth with studies.... Good luck chuck. Scam Scam, my wife and her siblings had zero vaccines, zero fluoride and are the healthiest , strongest kids and now adults.. Fluoride is toxic, causes brain damage , causes hypothyroidism .... Mercola.com #1 health site used.
Jun 25, 2009. 6:54 AMbaneat says:
You're using about 5 subjects as basis for your analysis. No offense, but you need way more. Zero vaccines is just a stupid idea.
Apr 23, 2009. 11:41 PMMark Rehorst says:
Here's a web site that has a lot of good information on the science behind fluoridation of water, written in language that is easy to understand by people who are not scientists:
http://fluorideinfo.org/index.html
It also has some information about the sort of nonsense being served up as science at mercola.com and other antifluoride web sites.
Notice that the FIN site doesn't try to scare you then offer to sell you pills/potions/filters that will save you from the thing they were trying to scare you about.
Cheers!
Apr 22, 2009. 3:29 PMMark Rehorst says:
Here's a reference to start with:
Petersen PE, Lennon MA. Effective use of fluorides for the prevention of dental
caries in the 21st century: the WHO approach. Community Dent Oral Epidemiol
2004; 32: 319–21.
The bibliography lists many peer-reviewed scientific papers that will update your knowledge on the subject. I recommend you peruse the Cochrane Collaboration web site (http://www.cochrane.org/#). It is considered the gold-standard for quality, peer-reviewed medical and dental science.
Those healthy, unvaccinated people you mention have the people around them who have been vaccinated to thank (and lady luck!) that they have never come down with the diseases those vaccinations prevent. Look up "herd immunity". I wish them continued luck.
Here's another page to read that may help you in your journey:
http://www.freeinquiry.com/critical-thinking.html
I wish you the greatest of success in your effort to educate your self!
Mar 5, 2009. 3:18 PMriqhowell says:
Tyler, check out the info on fluoride available at mercola.com. Also don't forget that fluoride can be from multiple sources besides tap water, such as toothpaste, green tea etc.
Sep 2, 2008. 6:52 AMthewaytolos says:
Ok last comment on this topic... One word Monsanto.... Oh yea I went there.....
Sep 2, 2008. 6:49 AMthewaytolos says:
lol you quoted actual scientific information and (dot gov link) in the same sentence. That's pretty freaking hilarious. Serious Rofl OMG I just noticed your name Tyler Durden.... Re-read the book and free yourself from the machine which you so openly obey.. No disrespect love you!
Oct 31, 2010. 9:35 PMAgnis says:
No need to make the hole really really smooth and then punch holes in the top to ensure water flow into the canister. Make a hole, make sure what you are plugging it with won't come out, but a few little spaces at the edge really don't matter. As I said in the previous comment space, I use corks. Just make sure they are tightly in, so they don't float up and out.
Mar 27, 2008. 11:49 PMBdixon says:
Those 'bead' are NOT filler but ionic-exchange resin. See: http://en.wikipedia.org/wiki/Ion_exchange_resin
They help eliminate lead (copper) and some chlorine compounds. Therefore your instructible is NOT a 100% functional replacement for a Brita Filter. They are very expensive ($100 for 50g on ebay... so probably would add a $ or two to cost of refill).
Mar 28, 2008. 12:56 AMkcoldie says:
I have the same concerns. Charcoal filters out organics leaving any chaged ions, e.g. metals, remaining in the water.
Mar 27, 2008. 9:17 PMkd1s says:
And because of more stringent public water supply regulations, the Providence Water Supply where I live has been chlorinated for about 12 years now. It never used to be until the stricter testing and regulations went into effect.
Mar 27, 2008. 3:57 PMendolith says:
Fluorides are different from fluorine, and the toxicity depends on what you compound it with. The fluorides used in water are compounds of fluorine and other elements, such as sodium hexafluorosilicate or hexafluorosilicic acid. The beneficial effect on teeth was discovered from natural mineral deposits dissolving into drinking water in Colorado.
Mar 27, 2008. 3:14 PMfirelizzard says:
Chlorine is poisonous and it is in our water. Unless the amounts of Fluorine used are significantly more poisonous than the amounts of Chlorine used, there is not much of a difference. In some places, Fluorine is used instead of Chlorine to sterilize tap water.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:IAMSatisfied
