Step 4Filling & using the housing.
Rinse the housing thoroughly when done soaking... there's no need to dry it. Place the funnel in the hole and fill with activated carbon. You may want to tap the housing on your counter to settle the granules and top it off, allowing room for the plug. Once plugged, you now have a filter that is more than likely more effective at taking out impurities than the original. Why? because you filled it fuller and you used ONLY pure carbon with no fillers. It should filter more water before needing changed than an original filter.
You also may want to poke some holes in the "dome" on the top of the housing to allow water to flow into that area of the housing. A hot pin or needle works well for this. This replaces the holes that we cut out and plugged in step 3.
Treat this filter just as you would a new one... soak it in water for 15 minutes to make sure the carbon is saturated. Expect that there will be some fine charcoal powder that settles out in your first couple of batches or so. This won't hurt you to drink it with your water or let it settle out.. :-) When your filter is not in use, put it in a ziploc plastic bag and store it in the fridge to prevent it from growing funk. I haven't tried storing them in the freezer yet... that would definitely slow any growth down, but I don't know if it would cause the ice to break the carbon into finer particles that could escape the housing. I just haven't tried it yet.
This is my first instructable... questions, comments and critique are welcome and encouraged. Enjoy.
(still stupidly expensive, as someone says up there, there is silver in them? the price of silver has tripled in the last few years so thats probably why)
I'll shall try this instructable - thank you!
I'd look into alternate uses for the spent carbon.
The actual brita filters what do they say their effect on heavy metals like arsenic? The town I am in now ( just got here last week) has found one of its supply wells has Arsenic in it which they are working to fix. Besides" it only effects about 200 houses". Ahh yeah right, ok which two hundred and is my apartment one of them. So I am buying bottled water now.
May consider buying a large osmotic unit for under the sink, for coffee and cooking.But over all a great article on how to. Thanks
http://www.mikexstudios.com/archives/2006/12/06/analyzing-the-effectiveness-of-brita%C2%AE-water-filters/
The obvious conclusion is that if you want to remove more of a contaminant, filter it again. The second time it filters out x percent again, and again, until you reach your desired decontamination level. Remember, though, it is never zero...
