3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to refinish a drum
Step 5Lightly sand
Once the glue is removed, it is time for some sanding. I used 220 grit sandpaper to go over the entire surface of the shell. This is done to remove any small bits of glue that may not be visible, or was just missed.
Be sure to sand in the direction of the grain in the wood. Also, be careful sanding close to the bearing edge. The are several different ways a bearing edge is done, so try not to sand on them. A good rule to use is to not sand it if it wasn't wrapped to begin with.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:frugal
