After only one season a fan may be covered in enough gunk to give the illusion that the 'motor' is worn out, when really all that is needed is a good cleaning to keep it running for a lot more hours. I have often picked these up on trash day, and gotten years of use from them. Rarely I may have to replace a knob, but usually they are functioning, but the blade speed is about half of normal.
Remove these ads by
Signing UpStep 1Tools
Screw driver
Paper towel
Dusting Brush
All Purpose Cleaner/degreaser
Finger Nail Brush
green kitchen scrubbies
steel wool
~ ED
if everyone would fix their fans, computers, or even replace the fuses in their fridges or ovens, we would waste a lot less, in most cases a $3 fuse makes people throw out and buy another $400 appliance.
its actually kind of sad, when you think about it.
you could also get some Automatic Transmission Fluid or 30 weight motor oil and thin it down with some kerosene. Using ether straight (neat for UK readers) would not be the end of the world, it would only be not ideal.
Sewing machine oil
And BTW, WD-40 is a solvent mixed with a lubricant. It also worked a lot better as a diesel starting fluid back when it was pressurized in the can with butane.
WD40 is not just a solvent. It is a solvent with a lubricant. The solvent helps pull the lubricant into the tight places. Once the solvent evaporates the lubricant is exactly where it needs to be.
In the States it is largely sold in pressurized cans. Actually, I can't remember when I last saw it in a consumer squeeze can. I've seen it in a gallon container though.
The following isn't particularly relevant, but...
I use to volunteer at a bike rehab clinic. We used a motorcycle chain lube on the bikes going out into the world. We knew that they would see additional time on the streets and were unlikely to be maintained.
There's some guy who does tutorials both on youtube and Instructables. He just trips daisies if you even mention WD40. They behave like it is fuming acid sprayed on your bike. To him you need the expensive chain lubes that you dutifully dot into every link. And you must use certain greases only in certain areas in a bike's headset, etc. It's a little intense.
And the moral of the story...
Use what you have, because you already have it.
*The fixie stuff gets under my nerves as well. I want to strangle a person when they offer a lame beneift of "it's so much less maintenance." They aren't. Modern drive trains are incredibly reliable. I wish they would just admit it's for fashion. Then I would just think it was their choice.
*I agree with you once again. Ride what you got. And keep it cheap. My road bike is 6 years old, and will be fine for another decade. Mix it up and have a nice time. Buying something too expensive makes you nervous about damage and theft.
*For the oil I would honestly say that WD-40 works fine. If you want to step it up a notch use Gt 85 http://www.gt85.co.uk/ I've used it for years and it is available in your local bike store. But honestly, WD-40 is fine. Just don't tell the bike police!
*I do think that the bike mechanics have a point, but they are confusing correlation with causation. The bikes that have been lubbed with WD-40 come in an awful state. So they make a connection between trashed bikes and gunked chains. But I personally think it's really a situation of those who use WD-40 don't know how to maintain a bike.
