3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to remove a tick
In this instructable I will demonstrate how to easily remove a tick from your dog without pulling it out. The tick will crawl out on it's own and you won't have to deal with 'did I get it all out?'. This sounds like a magic trick and you might even think it is, I did. My sister inlaw had been telling me how to do it for quite a while and I just never tried it, because I didn't think it would work. One day when I was at the vet getting my dogs their yearly shots, my vet found a tick and removed it using this method and I was sold.
I easily remove about 20 ticks a year from my two dogs. When I used the old way, which was get your tweezers as close to the head of the tick and pull straight out, it would often leave parts of the tick behind. Ticks seem to like areas near the eyes and ears, which would leave marks and scars that wouldn't ever go away.
So how do you do it?
Rub the tick in a circular motion and pretend you're trying to make the tick dizzy. I generally stick with one direction, clockwise. It usually takes less than a minute, so if it's not working, make sure the body of the tick is moving around. Remember you can't get dizzy unless you're actually moving in a circle, quickly. I doubt the tick actually gets dizzy, but they sure don't like something about the movement and they crawl out on their own.
This was too difficult to document with photos, so here's the video.
Step 1More information
More information
The only troubles I have had with this technique, is when you catch the tick early in it's attaching process. It makes it harder to actually get the body of the tick to move around and you feel like you're just rubbing the tick. If it won't come off, I will usually wait another day instead of risking leaving part of the tick behind in my dog.
This method should work on people as well, but I haven't had the chance to try it out. I don't think it will work as well, because you generally catch the tick early on and there's no body to move around. It's also easier to get parts of the tick out as you can use tweezers and then just like removing a splinter, get the rest out.
Once you have the tick out, wrap the tick in a piece of tape to kill it. If you're taking it off yourself or another person, you probably want to put it in a jar of rubbing alcohol and get it tested for Lyme disease.
494 comments
1-40 of 494next »
Dec 8, 2011. 10:44 AMmrichmond3 says:
Haven't tried this yet -- but I will at the next opportunity.
For the sake of those who, for whatever reason, have trouble getting this method to work, here is another method that has been 100% successful for me, allowing me to get the tic out whole every time.
1) Cover the tick in vaseline. This stops them from getting air through the spicules in the sides of their bodies and they die in place if you wait about 60s before going to step two. Wait at least 30s so they will be sluggish, if not yet dead.
2) Now that they aren't holding on anymore, grab their body, none too gently, with the tweezers or a pair of pliers (easier to use, frankly) and turn counter clockwise. Tics are threaded. I'm not joking. They come out within two or three1/4 turns.
3) Wipe up the excess vaseline with a kleenex and its all good. The vaseline cleans up remarkably easily.
If the tic is in a very hairy place, you can put tape on the dogs fur to hold the hair back away from the tic before you apply the vaseline. Doing this will make it easier to grab and turn the tic without getting the tweezers tangled up in the hair. Yes, some hair comes off on the tape, but they don't seem to mind much.
Apr 25, 2012. 6:52 PMesty4ever says:
this information is also very useful thank you soooooo much
Mar 19, 2012. 4:45 AMscottishquine says:
Sorry but this is just about a "HOW NOT TO REMOVE A TICK SPECIAL" and more like how to ensure you dog gets infected.....You should NEVER smother a tick with Vaseline or any other substance, infact nothing should ever be put on a tick. Vaseline does not suffocate them...as a tick only breathes once an hour, there is a major flaw in your removal technique....the tick will back out when smothered but not before it has regurgitated it's gut contents, bacteria and all into it's host....also squeezing the body is totally wrong, and never ever turn a tick unless using an O'Tom Tick Twister. The weakest point is between the mouthparts and the body and you will most likely leave in some of the mouth parts doing it incorrectly., Also using the tool is quicker and safer for the dog..not to mention more comfortable. I have attached a link showing how a tick should be removed. Please read it. I am a voluteer for the charity, and we raise awareness about ticks. My husband had Lyme for 10 years before it got diagnosed...and he removed ticks in a similar manner to you. We did used to be told that was how to remove them...but after a lot of research we now know better....and trust me you or your dog don't want to contract Lyme Disease.
http://www.tickbitepreventionweek.org/tick-removal.html
www.bada-uk.org
Apr 25, 2012. 6:50 PMesty4ever says:
This information was soooooooooooooooooooooooo useful i was crying because at first i thought my dogs "wart" was a tumer but since i found this information i now know its a tick im so greatful for this thank you soooooooooo much !!!!
Apr 12, 2012. 6:58 PMmzeigler simpson says:
Thanks so much for this advice! It worked great!!!!!!!!!!
Apr 4, 2012. 7:32 AMshadrag says:
Thank you so much for this video. I discovered a tick on my border collies' face almost exactly same position as in your video. The dog has only ever had one before and for that we had to take it to the vet (£16 straight away), dog was stressed out its eyeballs ,cos hates the vet, but he did remove with a tick remover tool.
So rather than pay yet again, despite being extremely queemish about these things ,i decided to don the latex gloves, put a muzzle on the dog (well you never know do you) and give it a go, and i just can't believe it , it just fell away into my hand after about 30 seconds, think the dog actually quite liked the experience. Decided to check all of its coat and found another little blighter behind its ear, (well i say little, it was huge), but again the technique worked a treat. Double checked the tick has its head on removal, put in small clear bag and stomped with my foot. Horrible, horrible little things and i am itching just typing this, but i'll defo be using this little trick from now on. thank u again.
Mar 30, 2012. 10:20 AMscottishquine says:
Xeroshield are doing a online questionnaire about ticks and Lyme disease, the information gathered from this will be shared with BADA-UK so will be of great benefit to us....if you live in Scotland and can spare a few minutes to fill it in that would be great...
On the subject of ticks and Lyme disease, you may be interested to know that a leading Scottish life sciences company called Xeroshield is currently looking for members of the public who live and/or work in Scotland to take five minutes to fill out a simple online survey as part of a major new study.
Xeroshield is exploring the development of a device to remove ticks from humans and pets, combined with a laboratory service for the detection of Lyme disease in ticks collected and immobilised using this device. The study is designed to assess the potential market for such a product and service. But it is also expected to generate valuable data about general awareness of ticks and Lyme disease in Scotland.
The survey asks a series of very straightforward questions about people’s own experience of ticks and Lyme disease in Scotland. Xeroshield is keen to hear from anyone who spends long periods of time outdoors for work or leisure and is therefore at higher risk of being bitten by ticks.
At a later stage, Xeroshield also plans to carry out more detailed interviews and focus groups and would be particularly interested to hear from anyone willing to participate in these later this year.
If you live and/or work in Scotland, would like to find out more about this project, and to complete the ticks and Lyme disease survey online, please visit: xerolyme.wordpress.com
Mar 21, 2012. 8:48 AMscottishquine says:
Here is a photo of a tick, the mouth parts are the barbed parts in the middle of the photo. This is the only part of the tick that enters a host. It is similar to an upside down xmas tree. If the tick isn't removed properly some of the barbs can be left inside the host, and can become infected.
Mar 19, 2012. 10:08 PMmrichmond3 says:
Dear scottishquine. You are so confident and experienced, I'm hoping you can help me.
Although the smother method has worked well for me so far, its clear from your response that tick removal has become an emotionally heated and controversial topic. As I've gone around the web looking for more information I've found absolutely no studies -- no actual data. All I see is opinion and salesman ship for clever little tools.
Even the CDC and FDA website reference no actual data. Perhaps you could point us to some better websites or references?
I'm particularly interested in finding out what we really know about ticks -- what makes them panic and what doesn't and when they regurgitate. It seems to me that all of the tick removal methods would be equally likely, or unlikely, to cause a panic in the tick. Do we really know that upsetting a tick causes regurgitation? Why would it do that? How would this help a tick from an evolutionary point of view?
Also, if alcohol and vaseline and soap don't actually smother a tick, why do they all, none the less, cause him to let go and go limp? I can't find any data on that either.
Finally, since the "rolling" method above results in the tic choosing to let go and walk off, why is it thought that this is more likely than the alternative, prying and pulling, to cause regurgitation? It is fairly obvious to my that prying and pulling is more likely to leave body parts behind so ....
Oh one more, since timely tic removal seems to be a big part of this. Exactly how long after a tic digs in does lyme infection occur? Because if it occurs immediately, another 30s-60s or so won't matter. On the other hand if infection occurs after say, 30min, then I can see why we'd want to get the tic out right away, because who knows, we may be within the 30min window.
Very confusing.
Mar 21, 2012. 7:03 AMscottishquine says:
There have been various publications which look at the risks and benefits involved in methods of tick removal. Most agree with, or cite, an evaluation of methods of tick removal by the acarology laboratory, department of entomology, college of biological sciences, the Ohio State University (Needham G.R.).
This study concluded that it is not unusual for a tick to continue to salivate for several minutes after removal, and if it is infected, the possibility of accidental inoculation with a disease agent is increased with careless handling of the tick. Longevity of the microorganisms outside the tick then becomes a critical factor in the degree of risk involved.
It also concluded that occluding the tick's air supply with substances, even for several hours, would not be expected to affect it because of its slow respiratory rate and, in practice, appeared to impede self detachment.
It also concluded that hot objects may induce the tick to salivate or regurgitate infected fluids into the wound because heat in the form of infrared radiation will stimulate partially or fully fed ticks to salivate. The same theory now applies to freezing agents as fluid is likely to be forced down the hypostome of the tick and into the host.
As an organisation, BADA-UK must comply with current official advice in terms of the preservation of human and animal health. All official disease prevention sources state that the only recommended removal technique is by manually removing a tick with fine-pointed tweezers (to avoid compression of the body) and to lift / lever outwards with a stead, even motion, without twisting or jerking. Until such time as new advice is adopted by such authorities, this is the advice that BADA-UK continues to offer.
Hope this clears things up for you.
Mar 19, 2012. 4:49 AMscottishquine says:
I meant to add, that leaving ticks on your dog for longer than needed is a bad idea. The longer a tick is feeding the higher the chance that your dog could become infected. Remove ticks as soon as you find them. Also the "remove your tick before it has been on for 24hrs" thing is incorrect. Firstly you have no idea when the tick attached completely, and secondly ticks don't wear watches!...treat all ticks the same. My comment below gives you more advice and where to find other bits of very handy information.
Mar 19, 2012. 4:36 AMscottishquine says:
Hi guys, just had to comment on this....this is exactly what NOT TO DO!!! by doing this you are stressing the tick, their defence mechanisim is the regurgitate it's gut contents bacterias and all into the host, and then back out..which is when you can also become infected with diseases the tick carries...the rough number in the UK is that 1 in 3 ticks are infected with Lyme Disease....
I volunteer for a self funded charity that raises awareness about Tick and Tick borne diseases....for example Lyme. The safest was to remove a tick with with an O'tom tick twister...it doesn't leave any mouth parts behind. Also you shouldn't touch ticks as they can pass on diseases through breaks in your skin or if you touch your mucas membranes after.
I have attached a link showing how you should remove a tick....and the link to our normal website too. As a charity we have worked very hard for our good name, and will only ever give our best practise advice, and will only recommend things that have been proven to work. If you have any questions feel free to ask of contact us through our website. Thanks for your time
http://www.bada-uk.org/
Mar 19, 2012. 1:04 AMkazza690 says:
This is the first time my dog has got a tick and fortunately came across this first when googling how to remove ticks. I did use a tissue to rub the tick as did not want to touch it with my fingers and hey presto came away in less than a minute...brilliant tip !!
Mar 15, 2012. 8:02 AMCroy9000 says:
I picked up a tick on my leg in park while running yesterday, and this method worked perfectly. It dropped off after about 30secs of rubbing. Thanks a million for posting this!
Mar 3, 2012. 8:23 PMrbstar55 says:
Just wanted to say THANK YOU SO MUCH!!!! Just found a tick on my little dog and had already gotten out the alcohol and swabs when I had a thought to check online for another way to remove ticks. Google had your article at the top of the search list. We got the tick out, head and all, in less than 60 seconds!!! I will be passing along this great info to all my dog loving friends. Thanks again for sharing your easy trick!!
Mar 2, 2012. 5:11 PMsadiefae says:
oh.my.god. just want to thank you for writing this, i am so glad this is the first thing Google produced for me.
it took a long time, that tick did not want to leave my dog... but it finally fell off.. and as soon as it did my dog started to shake and run and i lost it, luckily i did find it after much frantic searching...right where i had to pin my dog to let me rub it out, and it does come off head and all i put it in a zip-lock bag and that nasty pincher face is still there legs still moving and all.
if i could i would hug you right now.
Mar 1, 2012. 2:11 PMupnightz says:
That was freakin' cool. It worked on my little dog.
Feb 26, 2012. 10:14 AMtmbucz says:
UNBELIEVABLE !!! Worked EXACTLY as described THANK YOU !!! Proof is in the attached picture right after it fell out.
Feb 19, 2012. 10:54 PMmochrie71 says:
dang it! I should have read the whole way thru your instructions. I just found two ticks on my dog after hiking in the local foothills. One embedded and the other roaming. I removed the roaming one no problem. The other, I tried this technique but it only embedded within the last few hours so it wasn't engorged yet. I didn't read far enough to see that I should wait until tomorrow. I rubbed it pretty hard and think I may have killed it. It doesn't appear to be moving at all. I guess I'll have to wait 'til tomorrow.
Feb 16, 2012. 11:27 PMfelix-marieb says:
That was FABULOUS!!!!! I was skeptical but it worked exactly as you showed on the vid. Thanks!!!!!
Feb 4, 2012. 2:57 PMoakiedog says:
I CANNOT BELIEVE HOW WELL THIS WORKED! My wife and I pulled out the vaseline, rubbing alcohol and tweezers. We were ready for some really messy and gross work.....and we tried this method and the ticks just fell off....onto the ground...no bloody mess, nothing. It took a deep breath to start massaging the tick...but after it all started, the damn parasite fell off very quickly.
THANK YOU!
Jan 26, 2012. 9:47 PMInfernooo says:
http://entomologs.ru/udalenie_klesha.html - written here as to remove the tick
Jan 8, 2012. 7:43 PMmastersja says:
Although there are many, many comments here, I wanted to add one for our dog Lilly.
Lilly had a big tick on the side of her face, and after finding this instructable, my wife put on a rubber glove and used her index finger to twirl the tick around as described here.
30 seconds, and the tick came right off, head and all, just as advertized!
Thank you for making a gross job easy for both my wife and our dog Lilly.
No stress on the tick picker or on the pooch.
Dec 25, 2011. 8:57 PMalleydog says:
Not working for me. Tried it on 2 ticks. HELP
Dec 12, 2011. 11:29 PMgbond1 says:
Wow thanks mate the clockwise rubbing worked a treat.. It took about 60 seconds or so but teh Tick just fell off.. Well done for posting this.. !
Cheers,
Gary.
Dec 8, 2011. 7:12 AMshompens says:
This technique was a lifesaver for me (and my dog) when we were on the road couple of months ago. I removed a tick from the forehead just as shown in the video, This morning, I noticed another tick in the underside / thigh area of my dog - the moving the tick around in quick circular motion surely dislodged the tick in about a minute. The tick fell off its own accord, was alive with its head intact. Thanks a lot for sharing this wonderful technique.
Nov 24, 2011. 8:23 PMjbrawn1 says:
Amazing! I really didn't want to play with tweezers and the cat--it's Thanksgiving after all. My daughter held the cat, and I did this trick for about 30 seconds. You saved the night!!
Nov 24, 2011. 5:28 AMpryingling says:
Just found a tick in the sensitive inner rear leg area of one of my scotties...got set up with the usual tweezers, alcohol and swabs, anti-biotic. After struggling to get at the lil parasite for a couple minutes, realized I'd need an assistant to help distract the hottie scottie! So while I was mulling the situation over, I absent mindedly started running through some tick removal websites and happened upon this site eventually.
Read through and watched the video....I was skeptical...but something about it felt right...like maybe I'd heard about something similar to this yrs ago...
Anyhoo, I decided to give it a shot as I was getting nowhere quick with my muzzled (for safety!) black beauty.
I isolated the tick (it was at about half size engorgement) and commenced the rotational rubbing action...being very light on the pressure and careful not to crush the tick...
After about fifteen seconds I stopped and felt the tick and assessed it's attachment...still attached. I was a bit disallusioned... I started up again with the circular rubbing action when suddenly I realized the tick had suddenly detached and fallen onto the counter top with a satisfying little sound...like a raindrop hitting the ground!!!
I was absolutely astounded>>>and ecstatic!!!! If this proves to be safe ( I will watch for signs of infection etc) It'll be one of the best tips ever for tick removal!!!
The removal process in the past has always been successful....but also stressful and quite the PIA !! Plus, I think Rory may have enjoyed the whole process! Thanks for the excellent info!!!!!
Nov 19, 2011. 7:33 AMmarkgog says:
Lebowski - your simple tick removal method saved my weekend. No calls to the pet store, no grappling with fido or alcohol rubs....the flicking thing worked in under a minute, once the dog was still.
Thanks again.
Nov 14, 2011. 3:29 AMsusiereardon says:
FANTASTIC! I wonder if it would be possible for you to send me a link to your video, so I can pass it on to the OEMC Great Dane rescue etc. UK Many thanks. Susie
Nov 13, 2011. 6:42 PMCalliesdad says:
I'm frustrated after seeing the easy video, then seeing 50 comments from people saying the did it so easily. I rubbed and twirled for a couple of minutes, didn't work... came back in a few minutes, tried again, didn't work. I wish I knew what I was doing wrong. Nothing is happening.
Nov 13, 2011. 11:41 AMclucian says:
Thanks for sharing this information. All dog owners should know about this. It is so easy both on you and your dog. This is the first dog I have had that has had this problem and it worked beautifully. I am so happy and so is my dog Charlie. He is back to his normal self.
Nov 12, 2011. 2:08 AMmjcoe says:
I'm so glad I saw your website!! It worked GREAT, I just took two ticks off my dog. To bad all dog owners aren't aware of this. Thanks so much!! :)
Nov 5, 2011. 11:27 AMmmartinez33 says:
thank you very much. it was my 10 year old yack russells first ever tick i've seen and it was relatively easy. Thak God for Google!
Nov 2, 2011. 2:49 PMehall9 says:
Brilliant method. Painless for both me and Taz. Thank you so much for this information and video.
Nov 1, 2011. 6:45 PMdsgrisham says:
Absolutely fantastic! Worked in about 5 seconds. I thank you and Bandit thanks you,
Nov 1, 2011. 5:50 AMyinglinglanette says:
Just took an engorged tick off my dog this morning with this method! My husband didn't believe that it would work and I had my doubts. However, with about 10 seconds of rubbing, the fat little thing dropped right off!! AMAZING!! I hope that anyone who reads this explanation will at least try it. Thanks for posting :)
Oct 30, 2011. 11:17 AMbsimuncak says:
Wow! worked perfectly..thank you so much for posting. My first time ever removing a tick.
Oct 26, 2011. 11:18 AMgheath3 says:
Thank you, thank you, thank you. This works brilliantly. I have a tick tweezer which I'd mislaid so in deperation turned to the internet. This is better than the tweezers. After 30 seconds or so it came out WHOLE! All its nasty legs were waving and it starting crawling off, in a wavy line it must be said! I'm now enjoying watching it drown in some brandy! How satisfying. I will never use any other method in the future. Brilliant advice. Thanks again.
1-40 of 494next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
49
Author:lebowski(Instructables.com)
Usually making something on this site. lk
