So easy you'll slap yo' mamma!!!
This instructable covers removing tint (and stickers) from windows. It is specifically geared to removing tinting from 5th generation Honda Preludes from 1997 to 2001, but can be used on anything from Kias to Hummers, to house windows.
Background:
I recently bought a nice 5th generation Honda Prelude with tinted windows. I always liked the way that tinted cars looked, but didn't think it was practical because most of the driving I do is at late at night. The new car also had radio reception problems. The antenna in my car is a thin wire layer on the back window above the defroster lines. Asking around I learned that the tint in my rear window was likely causing my poor reception (it was). These two reasons drove me to removing the professionally installed tint the car came with.
After calling a tint shop and getting a quote of $140 to get the 5 window (2 doors, 2 rear quarters, and rear window) tint removed I decided there had to be a better way. I did some research online and prepared myself for a messy painful process. It turned out to be easy, so easy I figured I'd write it up for you.
The advantages of this method are that you do not need to cut the tint off at all (no razorblades = no mess) and so it is safe on your rear window without any fear of messing up your rear defroster or antenna lines. The method is also significantly faster, cleaner, greener, less messy, and less hazardous to your health.
General idea:
The goal here is to steam the window and tint so much that the glue releases itself from the window. Then all you have to do is slowly pull the tint off of the window (as you continue to steam) and the glue comes with it - no mess!
References:
This write-up is a basic version of the special technique used by the professionals at Tint Removers (tintremovers.com). Tint Removers uses a specialized green method of tint removal that does not leave toxic chemicals for professional car, home, commercial office and store window tint removal services. This write-up is based on an interview with Tint Removers. If you are interested in professional service or have specific questions for Tint Removers, they can be contacted at quotes@tintremovers.com. Feel free to reproduce this article but make sure to include a link to this article.
Disclaimer:
Steamers release extremely hot steam... which translates to hot condensate. When combined with tight spaces and or the use of beer as a motivational tool, injury can result. Use common sense, don't burn yourself with the steamer.
Tint will make your car look better to the opposite sex, protects from the UV rays, and wards off thieves. Removing it however, will make it easier to actually see while driving, sometimes important.
Thanks for all of the positive comments. If you liked this article, please rate it, and include your pre-tint-removal & post-tint-removal pictures! (if you didn't like it, let me know what is missing)
Keywords:
Window tinting,remove tinting, tinted, car tint, prelude, steamer, window steamer, remove tint, removing car tint, removing window tint, removing tinting, tint removal, bubbling tint, old tint, how to remove tint.
Remove these ads by
Signing UpStep 1Gather Supplies!
- Cheap clothing steamer (hey, it works on your clothes too!)
- Long extension cord
- Bottle or cup of water (so you don't have to go inside to refill the steamer every 10 min)
- Some rags
- Windex
- 6 pack of beer & a good CD (to keep you entertained while steaming the windows)
This is the lynchpin of the entire operation.
A couple of weeks ago I bought a cheap clothes steamer on sale at walgreens for $12.99 to stay stylish, and I figured it just might do the trick on my tint too. Apparently, I got quite the deal, when looking for examples for this write up they were all about $25-$30. If you want to find a deal, you might try your local thrift shop, Ross, Tuesday Morning, yard sales, Kohls, TJ Max, etc.
Here are some examples of fabric steamers
Target: SteamFast Compact Fabric Steamer $24.99
Walmart: Conair Portable Garment Steamer $29.93
Walgreens: Conair Compact Fabric Steamer $29.99
Sears: Conair GS16 Hand Held Fabric Steamer $22.49 (on sale)
- if going to steam, I suggest using a strong steamer that can deliver steam continuously (mine was small and weak and could not do this)
- it was easier for me to lift and pull the film with tweezers than with my hand
- for my situation it was quicker to use a hair dryer and use more force with the tweezers. The glue was left behind and it was easily removed with ammonia/adhesive removing product
Your handheld steamer is a better option.
http://asd-market.com.ua
I picked up a new (old) driver's side door for my poor, wrecked car from the junkyard today, and brought it home to find old, grody tint all over the window once I rolled it up. Since I'm fortunate (?) enough to have the door currently sitting on my living room floor and not attached to a vehicle outside, steaming off the tint with my iron worked like a charm, and it only took about 15 minutes tops (and not even half a beer).
Oh, and I didn't bother removing the panel, just gave the sheet of tinting a good tug once I reached the bottom of the window, and it all came right off. Probably again because it's old, so YMMV.
Thanks for the instructable!
I didn't have a clothes steamer but had an iron with the steaming capabilities which worked.
thanks!
This method works on MOST applications, but not ALL.
If you are pulling film and all the glue is staying behind, you're just as well off to snatch the film off and save the time with that step and move on to the adhesive removal process(es).
Good article overall though and very close in process to one of the ways a professional does it!!
So as most of you probably did, I searched the internet for "easy" ways to get tint off my windows. I came across this and tried it last night. I actually did it with the steam from an iron, which worked very well. It took me and my husband about an hour and a half to get the tint off.
I DID use an S.O.S. pad toward the end to get the last of the glue off and it worked WONDERS as well with NO scratches whatsoever. I tried the alcohol... it just dried it out. I tried the WD-40 and no luck. I bought a bottle of "Simple green" and it worked better than the other three, but it was still taking a TON of elbow grease. So I took my chances with the SOS pad and was amazed at how quick it came off. I did use Hot soapy water to wash them off after scrubbing. When I was done I shined them up with glass cleaner and "TAAA-DAAA" it was done. Pretty painlessly.
Please people, whatever you do, DON'T do this!
SOS pads will scratch the hell out of automotive glass - I can guarantee the windows on this car are now COVERED in a fine scratch haze.
STRAIGHT alcohol is used for LOCATING glue spots, not REMOVING it. The alcohol makes the glue turn white and easily visible. Water and a few drops of soap in a squirt bottle and a razor blade are all you need to remove glue from a side window. #0000 steel wool (NOT SOS!) can be used on a rear glass. WD-40? Really? wow...
BTW - 12% would be DARKER than 28.8. By ALOT. The lower the number, the darker the film.
One thing I was to use a long pair of tweezers the one shaped like forceps to pull the tint. Kept my fingers away from the steam.
I know this post is old, but to me it's new!
Cheers,
