loading
Step 2: Carefully remove the putty
Go around the window with the razor blade inserting the blade between the wood and the glazing putty.  If the putty is old it should be cracking away from the wood and can be picked or snapped off.
The two things that you need to look for are
  1. Glazer points
  2. small bumps of putty stuck to the wood
Try to locate the points there should be at least one per side but there could be as many as three or more.  See picture for the different types of points you my find.
Cut down.  Take your time make several passes don't rush don't push against the glass.  Make sure their are no bumps of putty that will hold in the glass.  There should be a knife thick grove between the window and the wood.  Watch out for points dulling the razor.
When i have broken the pains it was because of these bumps or hidden points.
<p>Hey,</p><p>Have you done the solar melter? If yes .... any plans of the project? Thanks!</p>
<p>I did make them and started an intructable but have not published it yet. I have also made a new extractor using a treadmill. </p>
<p>It's a very helpful Tips for <a href="http://www.instructables.com/id/How-to-replace-the-glass-in-a-wood-frame-window/" rel="nofollow">Glass Window</a> replacement ,Thank you for your nice feedback.</p><p><a href="http://www.instructables.com/id/How-to-replace-the-glass-in-a-wood-frame-window/" rel="nofollow">DC glass repair</a> so Professional and clean.</p>
<p>It's a very helpful Tips for <a href="http://www.firstglassandwindows.com/" rel="nofollow">Glass Window</a> replacement ,Thank you for your nice feedback.</p><p><a href="http://www.instructables.com/id/How-to-replace-the-glass-in-a-wood-frame-window/" rel="nofollow">DC glass repair</a> so Professional and clean.</p>
<p>thanks got my glass out of the window and I didn't even break any!</p>
<p> I use a sharpening stone. They can be found at most hardware stores or hunting &amp; fishing aisles in big box stores. Some have a rough &amp; finishing grit on 1 stone. Another option is emery cloth pulled tight on a block of wood. Do not just wrap the emery cloth around the glass pane &amp; think that you can do both sides of the glass at one time or you will end up with scratches that paint will become trapped in.</p>
Some are sharp some not. At glass shops they have grinder i think sandpaper or a dermal would work.
Hi, <br>Once the glass is out of the frame, do you know a way to buff the edges so they aren't sharp?-- i.e. so you could use it without putting another frame around it? I have sheets and sheets of glass taken out of an office building, and I'd like to use some of it as a worktable of sorts, but can't figure out how to smooth the edges.
A cool glazer trick it to use a heatgun or torch on particularity hard putty. It helps a bunch, but will bubble paint or scorch if you leave it there too long. I repair these things on a daily basis. Mostly I just attack weak spots with a utility knife when I'm at someones home.
Good suggestion. Be careful when the paint starts to bubble the fumes are toxic. Ibbles get exponentially more views when you add flame or explosions.
About This Instructable
51,942views
11favorites
License:
More by turbobug:The Fold Flat Trebuchet on the Cheep  Hot Belvita The Pizza Box Or The Box Pizza
Add instructable to:
