The keyboard & mouse were easy to clean - I removed the electrical bits and poured boiling water over the cases. The rug and trousers were not so easy.
The usual method for de-waxing carpets found on the internet involves picking at them with a knife, maybe after chilling with ice, then applying heat & absorbent paper. I didn't think this would work on my rug because a lot had soaked in deep.
I used:
Washing-up liquid (detergent)
Hot water
An empty food-can (and can opener)
A bucket
A bath
Remove these ads by
Signing UpStep 1Preparation
Apply a little detergent to this area, which should help wet the fibres and allow water to penetrate rather than roll-off.
Using a can-opener, remove the other end from a empty can (sweetcorn in this case) to give you a steel ring. This will help guide the hot water you are about to apply to the back of the rug.
Place the rug over a bucket, preferably in a bath or over a surface which will not be harmed by water. Level and flatten the rug on the bucket. In this position water should be inclined to move straight down, rather than to one side.
L
I leave you to consider which is and which is n't.
The Truth like Gold is Rarely Found,
But lies, The Gold Of Fools Abounds,
Anon.
http://www.instructables.com/id/How-To-Freeze-A-Lock-Off!/
I take it that you have now conceded to the fact that "Yes, a can of compressed air. You know, the kind that you buy at Office Depot to blow dust bunnies out of your computer." can indeed freeze things.
But it has been fun discussing it with you.
If you looked at the Instructable which you posted a link to on the 16th you might have noticed that he wasn't using compressed air at all - look again, step 3.
L
Most people (like yourself) seem to think this stuff is air, which is probably why it was referred to as "air" in step 1. It isn't.
See this product - clearly marked as being flammable - not air.
Or this FAQ on Dust-off - "Q: What is actually inside the duster can, isn't it just air? A: No,"
L
