With the increased accessibility of high quality 3D printing thanks to Shapeways, you can get your Bugaboo back on the road for $25, not bad considering I was quoted $250 for a repair.....
Following is a step by step guide to repairing the handle lock, without which the pram is near useless.
I 3D printed my replacement parts in stainless steel using Shapeways, you could try ABS and do it much cheaper but I really recommend stainless steel.
Remove these ads by
Signing UpStep 1Pry Off That Hub Cap
You need to pry off the hub cap to get access to the broken part.
I would recommend using 2 flathead screwdrivers, but a swiss army knife and a bottle opener will do the job,
Take care not to transform the surrounding plastic into a gnarled mess, the wife will appreciate that.
If I were factory supervisor, I would send these (obviously cheaply made) parts for free to the customer who has ability to do the job himself. Anyway, your fix is better and you have made an interesting job.
BTW: eBay has two sellers selling these in UK. Other one is made of stainless steel and the other one of hardened aluminium. Seller of the aluminium ones says that he has f ixed over hundred prams last year! What on Earth!
Be aware that replacing metal parts with another metal part in a critical application you have to know that the structural properties are the same or exceed the specs of the original part.
The material I used to 3D print with Shapeways is 420 Stainless steel which is really quite strong .
http://www.azom.com/article.aspx?ArticleID=972
There is a far greater likelihood of the small plastic pins that the steel component locks into failing before the stainless steel would.
That being said, as per caitlinsdad, you have to watch out anytime you are changing materials, especially if it were a more critical application. 3D printing is awesome, but people need to be aware that sintered materials do not behave the same way as other metals, for example rolled steel, and more importantly, they don't fail in the same way. Sometimes, hard or rigid metal parts are good, sometimes it's the opposite of what you want.
If you do not have CAD skills you could even trace it in Illustrator and use the Shapeways Image Popper to extrude it to the right depth.
http://www.shapeways.com/blog/archives/816-Introducing-Image-Popper,-a-new-way-to-easily-3D-model-and-3D-print.html
The only slightly tricky part was getting the angle and radius right, but modeling and printing (on paper) 1:1 to check made me fairly confident...
I do some work for a Wired Magazine blog called GeekDad. Would you be interested in doing a short interview for a posting? If so, get in touch with me as roy-at-geekdad-dot-com (you know how to parse that ;-) ).
Proof of identity is here:
http://www.wired.com/geekdad/author/rrwood/
The STL file is available to download if you want to tweak or print at home?
The tricky bit was measuring the angle off of the curve and the radius off of the angle.
