Step 3Cleaning time!
Next, check the circuit for damage. You should be able to work out something thats stopping the circuit from working. A good indication is rust or broken wires. Where possible, just try to replace the parts. If you haven't got spare wires or a soldering iron, just use wire cutters to strip wires and twist the ends back together. If the switch is broken, you can cut it out and twist the wires together. If the LED isn't very bright, you could consider taking it out and replacing it with a new similar LED of your choice if you know how to.
Add Comment
